Everything posted by druxey
Certainly a striking 'Captain's Fancy' color scheme!
- 209 replies
- cheerful
- Syren Ship Model Company
Do let us know how this goes!
- 209 replies
- cheerful
Problems brass blackening using Jax Pewter Black
druxey replied to mrmdpc's topic in Metal Work, Soldering and Metal Fittings
This topic comes up time and time again. Apart from cleaning the brass well, the blackening agent need to be diluted with water about 8:1. It works more slowly, but the black will not come off as you are experiencing. -
Your experience with brass chips makes me wonder if the type of brass you are using is 'free-machining brass' or another type? I've found that, at the right feed rate and speed, the brass comes off in long curls. Those embryo guns look very nice.
- 728 replies
- le fleuron
- 64 gun
Help with Proxxon MF70
druxey replied to Bluto 1790's topic in Modeling tools and Workshop Equipment
Glad you solved your problem, Jim! Now, enjoy your machine. -
The blocks illustrated appear to be internal iron-stropped ones.
AUTOCAD 18 DELUXE
druxey replied to yamsterman's topic in CAD and 3D Modelling/Drafting Plans with Software
Don's advice is very sage. -
Only add tools as you find you need them, or you'll end up spending money on items that gather dust. Certainly surgical (Swann Morton) scalpel blades are far superior to X-Acto ones, in my opinion.
Well, you've eliminated one possible cause, Jim. Now it is the turn of looking at the gibs on the ways. Antony's advice is good to follow. -
What kind of model are you building? If you can supply more details, perhaps we can provide more helpful answers.
As Toni has said, the 'generic' set of plans and CD from Admiralty Models has all the information for building a properly framed 'Swan' class hull. If you wish to build a complete model of a specific ship, you will need additional plans. These are copies of the original draughts, often showing complete details of carved works, that are held by Royal Museums Greenwich, formerly called the National Maritime Museum. The plans you will need are Sheer and profile Forecastle, quarter deck and upper deck If fully detailing below: Lower deck and platforms (Optional is the Disposition of frame plan)
Cutter Cheerful 1806 by rafine - FINISHED
druxey replied to rafine's topic in - Build logs for subjects built 1801 - 1850
Lovely. I'm sure that in the real world, the two sides would be slightly different, so your model is super-realistic!- 525 replies
- cheerful
Remove the table again. Are there screws holding the base plate to the green sub-base that are loose? I'd check that before messing with the gib screws. I don't think your problem is anything to do with the ways and gibs. -
Those adjusting screws are gib screws. They control the tightness of the slides by varying pressure on the metal pads. The are usually satisfactory straight out of the box. The rocking you describe sounds abnormal: the x-y table should be rock-steady. Are the Allen screws you used to attach the table to the base too long and bottoming out before the heads tighten down? -
You are right: the binnacle on Victory is a Victorian creation. Your 'take' on the binnacle from Amazon looks perfect, Siggi.
Possible significant maritime find in England
druxey replied to BANYAN's topic in Nautical/Naval History
Thanks for these informative posts! -
ancre Le Fleuron 1729 by rekon54 - 1:24
druxey replied to rekon54's topic in - Build logs for subjects built 1501 - 1750
Thanks, Mark. All my reference books are packed for moving, so I couldn't check. French ships must have lost a lot of rudders! -
And there is the Echo cross-section scratch build as well - check that out!
Beautiful work, Rekon. Question: does the lower end of the rudder actually extend as far as the bottom of the false keel? In English ships, the rudder was always shorter, in case the ship touched ground. -
Bilge Pumps 1870/80
druxey replied to GAW's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
So, you were able to track down drawings of the Wallace and Crawford patent pumps. Well done! The working version, as well as the 1:96 one, looks exquisite. Congratulations.
