pete48
Everything posted by pete48
  1. Thanks David, I dont want to do as much sanding and fairing on the next one , so the profile needs to be correct Thank you Omega, I am pleased with the painted plank ends and varnished transom , I will still need to round off the top of the transom Thanks Jay, The Bow is fuller , and the stern did change as well , the original numbers got off somehow, ( I think I was to conservative with the bow section on the original ) I am old school and like to make the drawings by hand . ( plus I have no idea how to use CAD ) the new one looks alot better than the original, ( almost O.E. )LOL Best Regards, Pete
  2. And here is the original lofted lines drawing, huge difference in the bow
  3. It is Raining once again here , So finish work will have to wait. It was however a great day to re-loft the 12 1/2 , and create a new lines drawing with the corrections . I feel alot more confident going into the next 12 1/2 Build with the new plans ( the Scale is 3/4" = 1' - 0" ) Here are the results
  4. Amazing work and detail Nils, Beautifully done , Very impressive Best Regards, Pete
  5. ok thanks for the clarification, I just want to see more of your beautiful boat Best Regards, Pete
  6. Hi Matti, looking forward to seeing pic's of the gunports Best Regards, Pete
  7. The planking is looking good Frank, Nice job Best Regards, Pete
  8. Thank you Dave, the 12 1/2 has beautiful lines ( thats why I am drawn to this Boat ) Thank you David B, I am thinking a gloss white on the hull with a blue waterline and sand color for the deck , all the bright work in cherry Thank you Michael, I appreciate it , These Herreshoff Boat's Have been fun to build Here are a few more shots Best Regards, Pete
  9. Thanks Michael, I realy like this Wood Stain, its made by DALYS chery # 45 it works well with Epifanes Varnish Best Regards, Pete
  10. Hi J , Nice job on the Masting , She looks Sweet Best Regards, Pete
  11. Thanks Geoff , she's starting to taking shape. ( this one has been a bit tougher than the Buzzards Bay )once the new Profile drawing is made, with the corrections . the next one should be easier to build Best Regards, Pete
  12. Today, I started by staining the Transom Cherry Red, Then apllied 2 quik thin coats of varnish ( we were in the 90's today so thing dried quik) ) after about 2 hours I was able to mask her off and spray 3 coats of flat white Krylon, as a barrier coat ,( sanding with 220 inbetween coats ) Hey I just realized that I made it to Captain ( That's pretty Cool ) then its only fitting that I worked on Capn' Nates 12 1/2 . Here are the results
  13. Thank you Robert, She is a beauty, This build has turned out alot better than I had hoped for , The only thing that is not Plan correct is the Cockpit floor , I raised it thinking that I could hide the radio gear in the bilge, as it turns out she is a bit small for raidio gear .However I will still take her Sailing . Best Regards, Pete
  14. Thank you Bob, Getting closer to Sailing Thanks David , This one is right on the money,( I have a full set of plans for the Buzzards Bay 14 ) When I was Talking to Geoff , I was refering to my 12 1/2 proto-type, The 12 1/2 is the Boat that I intend to do a 1 : 1 build, I am still developing the Plans, and have another model to do, once I have made all the corrections Best Regards, Pete
  15. I am in agreement with all of the above, the grating looks fantastic Best Regards, Pete
  16. Hi Omega, The other resource I use is the Mystic Seaport museum here is the link : www.mysticseaport.org/ I also found this link wich may be helpfull : www.ingomar.info/ I hope that helps Best Regards, Pete
