Everything posted by mtaylor
1/48 Italeri Hawk T.1A (On Hold)
mtaylor replied to Old Collingwood's topic in Non-ship/categorised builds
Looking great, OC. Your attention to the detail of gap filling and cockpit details are super nice. -
If Jim doesn't have any, PM me. I have some of the 0.21 from Model Shipways (rebranded Mantua line).
For English speakers.... https://www.theguardian.com/world/2021/oct/30/ancient-maya-canoe-found-in-mexico-could-be-more-than-1000-years-old Quite a few articles on this one besides the ones that have posted.
Broken link to the NRG store
mtaylor replied to EricWilliamMarshall's topic in NAUTICAL RESEARCH GUILD - News & Information
I'll ping this for the admins to look at. -
Go up to the top of the first post.. there's box labeled "follow" Click it and you'll get notifications.
- 536 replies
- Quadrireme
- radio
That's good news on your doing a log, Ron. I'm looking forward to seeing it.
Which first, hull or deck
mtaylor replied to ubjs's topic in Building, Framing, Planking and plating a ships hull and deck
I'd suggest paint the hull first and then build the deck and fittings and paint as you go on these items. Do keep extra paint handy especially if you mix your own colors as normal handling while building my damage some paint and require a touch up. -
I don't think MSW is going anywhere soon so you should be be good on that point.
- 2,677 replies
- heller
- soleil royal
(and 9 more)
B.E. I suspect you're right B.E. Those are tiny parts. Looks like Gregory as found a way.
- 857 replies
- Sphinx
- Vanguard Models
Yeah.. I see where you're coming from on this. I was given Autocad, a computer and some other software when it first came out and told "use it... it'll be great for the art in the tech manuals". Err... yes and no. The mechanical things it was great. A PITA in many ways to get final art for a manual but schematics? Nope. On the bright side, I, one other tech writer and our manager lead the company kicking and screaming into the computer age. Fun times.... mostly. There's still a lot of "crap" out there sadly. Seems sometimes there's more crap than good stuff but I guess it depends on one's needs. As for ships, I suspect there's not much out there that's fit for purpose but probably a lot of custom "fixes" by some creative types. Problem is, finding those "fixes".
I've been giving this some thought (a bad sign, I know). I'm thinking of cutting the axle "short" and un-touched (no rounding). Then put a small piece of dowel in to wheel. Musing out loud but might work.
- 857 replies
- Sphinx
- Vanguard Models
Go back in history a bit. Autodesk was one of the first drawing packages and had a big impact on CAD. They sealed their reputation back then with lots of companies jumping up and using it. Their core market has been hardware design used by manufacturers. I suspect that ship building and the special features needed really never was a core part of their business. Shipbuilders might use their programs for ship equipment but I doubt very much if the hull is designed in it.
Harold Hahn method
mtaylor replied to Essayons's topic in Building, Framing, Planking and plating a ships hull and deck
Keep in mind what Roger says as Hahn did go for artistic on the framing not actual practice. A s for the base board, you'd need a set of lines drawings and from that, the bulwarks and all the framing could be drawn to set up your build board. Jaager is also right about wood waste unless you drew the frames in segments, cut them out and assembled them. Hahn mentioned that he was given a large amount of wood and if he hadn't got the wood he would have build the frames up using segments. -
Harold Hahn method
It might be the big hurdle. What Hahn did was extend the frame tops in the straight line such that the keep and jig base were equally spaced at both ends. Use the keel bottom as your reference and go from there. His jig was pencil and paper.... once he had that, he just did all his framing drawings. From there, the he could drawing the jig itself with the notches for the frame tops. Like many other things, this is probably easier said than done as I've not seen anything on how he did his drawings, only on using his jig. -
Thanks for the answers Kevin and Henry.
