Everything posted by mtaylor
Thanks for the likes and comments. Thanks Steve. I suspect that you're right except cannon balls might have been an issue. Nice to you see back Vivian, it's been awhile, I hope all is well. After looking over the cannon barrels carefully, the thinking light came on.. and sometimes I hate that when it happens. It does look like a little work and these could be pure French cannon. I'll have to take one of the extra 4 pdrs, and test when I get a bit of breathing space.
There are no words for this... it just has too much "Wow" in it. I've played it 6 times and every time I see more detail. The two men on the yardarm and one in the top, the movement on the deck, even the view through the gunports. I shudder to think of the render time to get all this in there.
If your goal is to maintain the historical integrity of the model, then do minimal work... touch up only on painting, repair (preferable) or replacement of parts. I wouldn't radically change the look as that will change the model (if that makes sense). If you decide to go all out, then go ahead and don't worry... just follow your heart.
Welcome to MSW. We have quite a few cardboard/paper models underway or finished. I hope you'll do a log and let us watch over your shoulder.
Post a log for the restoration in the Scratch Model area with the keyword "RESTORATION" at the end of the title. Have some fun with this and good luck.
Dan, Marvelous work you're doing. It's a real pity they don't build cruise ships (or ocean liners for that matter) like this anymore. That ship is a work of art, IMO.
- 287 replies
- michelangelo
- ocean liner
Bumpkins
mtaylor replied to bluenose2's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
I went here: and had a look for your ship. There's a couple of logs but note that the Mantua is also a Corel kit as I recall. I 'd check those logs and see what they did while waiting for an answer here. -
Thanks for the likes and the comments everyone. Big day today... the rings came in and so did the guns from Chuck. I ordered 24 of the appropriate size for the 8 pdrs and also ordered the 6 pdrs. Yes, they're for an English ship but given the actual size and normal viewing length, I think they'll work perfectly. Here's a couple of pics. I will have to make quions now that I know the proper dimensions for them. This should be a lot of fun. Time go dig out the Birchwood-Casey and start blackening everything. I do plan on blackening and fitting the guns (temporarily) to the carriages but not actually installing the barrels until the upper deck and the channels and iron work for the shrouds are in place. I'll put the carriages in place and lock them down with glue and a "safety" post through the deck. Having a cannon and/or carriage come loos after the deck above it is in place is not fun in my book. Been there, done that, built my vocabulary in an ungentlemanly way.
Thanks for the answer. It just seems puzzling that everyone says "remove the char" and then bang.... no need to. I'm all for not needing to myself.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Rigging tools how are they used
mtaylor replied to Telp's topic in Modeling tools and Workshop Equipment
Andrew, you can cut the eye on the needle such to give you an open area to lay the thread into the eye rather than having to feed it through the eye. This useful when trying to "catch" a line that has one end secured and you need to belay the other end. -
Bumpkins
Which ship? Makes a difference as to size, shape, etc. If you're using wood, bending can be done via water and heat although there's been a lot of discussion lately on bending planking (use the search for blank bending and you'll see what I mean). The size (thickness) of the material could me that the wood should be cut rather than bent if it's too large and doesn't work well. As for wood... another "depends" moment. Pick a wood that will match/contrast or look good with the rest of the ship. -
And here I thought you were doing a fine job on the build... So a second time? Why does that sound like something I'd do????
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
You're becoming a master of the very tiny ship's boats, Nenad. Looking great.- 4,152 replies
- cutty sark
- tehnodidakta
Thanks for the comments and the likes, everyone. I cleaned up the laser char on one carriage and assembled it. Now to wait for the guns from Chuck... <patience grasshopper, patience> I forgot how tiny and fiddly they are to assemble. So when the guns get here, I'll adjust as needed and make the quoins so that they will all be at the same elevation. I think this will be a slow process as it took me a couple of hours to clean off the char and fit everything. Hopefully with a bit of practise, I'll pick up speed.
Hi Aldo, great to see you again my friend. Computer crashes don't help do they? What the others have said as far as solving the computer problem might work. I'm not sure why you'd want to plank over what's there. I think I read that right? Looks pretty good from here. If you don't have access to the plans here at MSW, ping an admin. I'll be glad to vouch for you.
For a look at other restorations, go to the scratch area and also the kit area and search using "restoration" as your key word. Some should pop up as there's been more than a few. You should get some ideas of methods and how-to's.. I'd recommend you open a log which will let us follow along and also you'll find it's a great way to get help and advice as well as make a few friends.
