mtaylor
Moderators
Everything posted by mtaylor
  1. Steve. I gave mine away as I realized I wasn't using it that much. Shortage of bench space and having to set it up wasn't worth the time to me as right next to where I would use it was my mini table saw. More functionality with the table saw (for me) and less hassle all around.
  2. Marcus.... check the link at Ebay... https://www.ebay.com/itm/SCHEEPSMODELLEN-1700-1900-W-K-Versteeg-SC-Dutch-Text-1972-GOOD-Illustrated/370681173936?hash=item564e51d7b0:g:hkMAAOxy0rZRGEvC
  3. I received mine today. They look and feel promising. I'm at that point on my build that these will come in handy so I'll be doing a life-fire test as such.
  4. Joe, I reaching into the dark recesses of memory here so bear with me. The ball was filled with powder as was the fuse. I believe there might have a different powder used for the fuse that burned a tad bit slower. After determining range, the fuse would be cut and hammered (gently) into the ball. The whole thing was put in the mortar and when the mortar fired, the fuse was lit by the blast. Note that this wasn't precise and something the fuse didn't ignite or heaven forbid, it was a fast fuse and blew the shell very early.... They were using the same type fuse on all shell guns not just mortars.
  5. Hello Miroslav, Welcome to MSW.
  6. Neil, I'd have a look at the other Ballahoo logs and see how they proceeded. At the bow and stern, many builders will use filler blocks. If you'll go here: you'll find a searchable database on the kit builds on MSW.
  7. Hello Neil, Welcome to MSW. Diana is probably the same manufacturer as your Ballahoo unless it's the Spanish Diana frigate. I hiope you'll start a log as it's the best way to meet folks and get help when you need it.
  8. Hello Jorge, Welcome to MSW. Nice work on the hull as it's turning out great.
  9. Sweet work. Nice, clean, and beautiful. It's good to see you back.
  10. Marc, I remembered that turned my Constellation guns from something weird (the stock guns in the kit don't even resemble actual cannon) into Parot Rifles, etc. I just need to chuck them up in either my Dremal or lathe and carefully use a fine file. I should be able to remove the reinforcing rings and reshape the snout a bit to match the French guns of the period. I just need to find the time.
  11. So far, so good. Shows a lot of promise. BTW, there's no need to quote yourself, just drop to the bottom of the page to the reply box and start typing. You can add photos, etc. When done, hit "submit reply".
  12. As far as I know, if acrylic paint is dry, you can't resurrect it. This site says it can be but with cautions... http://www.how-to-draw-and-paint.com/how-to-reactivate-dried-acrylic-paint.html
  13. Thanks for the likes and comments. Thanks Steve. I suspect that you're right except cannon balls might have been an issue. Nice to you see back Vivian, it's been awhile, I hope all is well. After looking over the cannon barrels carefully, the thinking light came on.. and sometimes I hate that when it happens. It does look like a little work and these could be pure French cannon. I'll have to take one of the extra 4 pdrs, and test when I get a bit of breathing space.
  14. No such critter this time, Aldo. They come in big and if you upload to the max, they kit out and open a new window (in Chrome at least) of the full size picture. Easy on the eyes it is.
  15. There are no words for this... it just has too much "Wow" in it. I've played it 6 times and every time I see more detail. The two men on the yardarm and one in the top, the movement on the deck, even the view through the gunports. I shudder to think of the render time to get all this in there.
  16. If your goal is to maintain the historical integrity of the model, then do minimal work... touch up only on painting, repair (preferable) or replacement of parts. I wouldn't radically change the look as that will change the model (if that makes sense). If you decide to go all out, then go ahead and don't worry... just follow your heart.
  17. Looking at this, who'd even think it was paper/card. Expletives fail me.
  18. I, for one, don't see a problem using it. Use what works for you.
  19. Welcome to MSW. We have quite a few cardboard/paper models underway or finished. I hope you'll do a log and let us watch over your shoulder.
  20. Post a log for the restoration in the Scratch Model area with the keyword "RESTORATION" at the end of the title. Have some fun with this and good luck.
