Everything posted by mtaylor
This is terrible news. I pretty much agree with Jan. Maybe.. put the wood pieces in a 250 (F) oven for a hour but that's pretty radical and unpredictable. The what happens when it dries is a real wildcard.
- 22 replies
- notre dame
- hydroplane
I'm going to ignore the 2mm blocks on the guns. I've ordered 3mm and 4mm blocks from Chuck. I hope the 3's work but I'll with the 4's if I have to. What ever's left over will used for rigging (along with another order to Syren. Very slow going at present so no pictures or updates until the cannon are in place and rigged.
- 7 replies
- li
- lone island
Could you make your own blast bags? Maybe a clay? The Bismarck is really coming together well and you're doing a great job.
Hi Mario, Looks like a good plan coming together. I do have question on the transom pieces. Is there a reason for not preshaping the exterior of them? Looks to my like you'll have a lot of sanding and shaping to do on them. Maybe I'm wrong and missing something here.
Beautiful and inspirational work, Nils.
- 692 replies
- eagle of algier
- chebec
I hope the only thing you hurt in your fall was your dignity. Atalanta doesn't look any worse for the battle damage. If you hadn't told us, we never would have known.
- 1,449 replies
Quincy, Welcome to MSW. I'll go along with what Chris said about a build log and the tutorials.
makeing sense of rigging plan abbreviations ?
mtaylor replied to spongbob's topic in Masting, rigging and sails
Not sure if this can help but do you have any other plans for the rigging? These all appear to be the same sheet. I'm winging it but B0 appears to be the bowsprit. The rest appear to be as you sorted out based on size. Edit: Appears I was staring at the prints when Jim posted. Aeropiccola is Italian so that might help. If the text is in Italian, then Google Translate is your friend... but with the usual caveats that it's not a perfect translation. -
I've been using thin (very thin) CA to stiffen the block before drilling. Seems to work for me.
MS is pretty good about things like this. I'll keep my fingers crossed you can get the plans.
What company produced the kit? Go ahead and sent them an email or call. Some companies are very good about sending out replacement parts and plans.
Home Made Sanding Blocks
mtaylor replied to Osmosis's topic in Modeling tools and Workshop Equipment
Great idea and follow up. The rounded one would work inside the hull.... which is a very fiddly thing to sand. -
Old Floquil paints?
mtaylor replied to MEDDO's topic in Painting, finishing and weathering products and techniques
Maybe drinking from a garden hose explains a lot about our ages and our chosen hobby? -
Have a look here: http://www.admiraltymodels.com/ You can see some of them under "Models".
- 6 replies
- swan
- sixth rate
- (and 4 more)
I'm pulling up a chair, Marcus. I'm not familiar with these so this is something different and should be an interesting build.
Jim, No preference from me. I'm liking and loving all your pictures. Superb work.
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
It might be playing to you, but it looks like artwork from here. Nicely done with interesting imagery.- 4,152 replies
- cutty sark
- tehnodidakta
Welcome to MSW, Spider. To answer your questions... the lower two decks are using "dummy guns"... not full fledged cannon with carriage. The dummy just goes into the the hole at the back of the port. Do paint the port flat black before install the barrel. As for the upper decks... you should probably read ahead on this. Could be the deck will need to come off to give you access or....??? Disclaimer: I've not built this kit but the lower ports and dummies are standard on a lot of kits.
