mtaylor
Moderators
Everything posted by mtaylor
  1. Hi Louie, Up at the top of the page, hit the little downarrow to the right of your name. Then hit "Account Settings" Then click on "Display Name". You can change it there.
  2. Welcome back home, Thomas.
  3. Ainars, I'm not sure of the question. The full-build has the plans for those parts (mast, etc.). Are you needing a reference book? I'd suggest using the full build plans and for the details just reference the build photos where those parts are added.
  4. I'm taking it that Andy's link (2nd post) isn't a good starting place????
  5. Welcome to MSW, John. Just one bit of advice... Have fun! Yeah, we all have those "oh crap" moments but overall this should be a relaxing and rewarding hobby.
  6. I would explore what Phil suggested first. If you're not staining it or finishing it, sometimes white glue and water (50/50) as several light coats will stiffen wood. As always, test first. Note, generally this method works for hardening up balsa wood.
  7. There's other names for that wood so if you can't find it under abachi, check the other names: http://www.woodworkerssource.com/online_show_wood.php?wood=Triplochiton scleroxylon
  8. Well... I dare say that you build the ship full side using Ed's books and plans. Here's the link to his build: A quick search shows other build logs using Ed's books and plans.
  9. Wand? Like a curling iron? I use an old curling iron (and properly grateful to the Admiral) and heat both sides. Start with the inside, hold the bend, hit the outside and then repeat as needed until the bend is proper and stays in shape. Others may use a different method but like many things... this is what works for me and "your mileage may vary".
  10. If the pigments came from different locations then, for example, there might be a difference between red ochres. Also the person who missed could influence the color. But generally speaking, they should be close.
  11. Latex is the current base for most model paints. The difference between house paint from the hardware store and model paint is the size of the color chunks. They're larger in house paint. Model paint makers grind the paint color into smaller pieces.
  12. Been there, done that with the wood supply. I now mik the wood and run it through a thicknesser before using. A PITA but it pays off in the long run.
  13. Yikes... you weren't kidding about that warp. I'm glad they are replacing it for you.
  14. I wish both of your children well. It sounds like they need to find a good place to be for work and life. There is nothing better for a child than a supportive parent. I hope has many good adventures ahead.
  15. Beautiful work, Cabrapente.
