mtaylor
Moderators
Everything posted by mtaylor
  1. I'm sort of stuck here. I'm seeing two different styles of carriages for the French 8-pdr cannon. I'm also under the impression that this applied to the 4-pdr's also. See picture. The upper one has both axle trees connected by a beam and the side supports sit on the axletrees. Note the rounded cutout at the bottom of side support. The lower one has a large "plank", if you will, that side sit on and then this is affixed to the axletrees. Which would be right for for the 1760's-1770's? I have detailed plans for both and just need to find out which one to use.
  2. The old lanterns were either large candles although some were oil fed via a wick down either in the Great Cabin, or the deck below it. So, the flame would have been yellow. This era was before the red/green navigation lights and the lanterns were more for position within the fleet at night. There was somewhere, a small lantern that would come out after dark for a couple of hours to inidicate it was ok for the crew to break out their pipes and smoke... the smoking lamp. So clear glass and not colored. If illuminating via LED, then use a yellow one.
  3. Email AL. Use Google translate to translate into Spanish as apparently they don't respond much to English emails.
  4. Hello Dave,
  5. Looking good, Bob. Just curious... are plans proper size? I had some distortion in the Licorne plans.
  6. Hello Miles, Welcome to MSW. By all means, when you're ready open a build log, as it will be the best way to get help and also over those "blah" moments. Semper Fi.. '66-'70 HMHT-301 & HMH-463 (RVN)
  7. Congratulations on a beautiful build, Sjors. Very well done.
  8. David, Have a look here and follow the links on some of the posts:
  9. It's great to hear from you Nenad. Those beasts are more than ball of fur aren't they?
  10. Hi Sterling, Welcome back home. We have some new paint, the decorators have been in, but it's still MSW.
  11. Nice looking frigate. I had to look twice as the pictures show enough detail to be a much larger model.
  12. I'm beginning to think you need to start a tool company, Michael...
  13. Nice work. She looks like she's been out on the river for quite a while. And like the way you didn't blacken the stacks but added some rust
  14. Nope... not going to like that. What Denis suggested for fixing. Before drilling in "new" material if you decide to scratch build it, paint the wood with white glue and water (50/50 mix). When it dries it hardens and strengthens the wood.
  15. The detail on that wheel alone just blows my mind. I won't even get into the rest of the detailing at this point.... Wow!
  16. Thanks for the support with comments and likes. I've become a believer that ripping things out and re-working them works best for me. I can think of too many places on this ship that it was make, finesse, offer up and scrap box. Some areas were pretty radical or seemed at the time, but worth it.... like those pesky stern transom timbers, etc. I ended up taking up more of the planking than I originally thought. Things just didn't look right on the drawing so.... ripped and redrew much of the planking. I received a much needed re-supply of boxwood from Jason at Crown and was pleasantly surprised at how fast and how nice the wood is. So... I did more research and staring at other people's models on the web for inspiration along with Frolich's book. Seems to a bit of a pattern in that plank butts on one beam must have 2 strakes between them. If possible 2 adjoining planks must have 2 beams between them. But... there's the random factor. So, had to think like shipwright in the yard and look at the pile of what was available. I took 5 planks varying from 25 feet to 50 feet in length and then randomly picked one up. Drew it on the drawing and the repeated the process until the whole strake was cut and installed. Duplicated that strake for the other side. Lather, rinse, and repeat as they, until done. There's some gaps that need attending to, but I'm sanding and scraping away. Getting there.... The char on plank sides seems to be working out. Just lightly sanded off the loose stuff. In the pictures, the lighter "caulking" is where everything came together perfectly. The black caulking still needs more sanding to get the fit flush. There's a few areas that need some filling. Overall, I'm pretty pleased with the deck. Here's the pics.... as always, I'm open to discussion and learning.
  17. Yep.. it's easier with a kit and with fewer headaches... unless you're bashing it.
  18. Keith, I'm far from perfect and just a newbie at scratch building. I didn't know you had departed from authenticity, but the work is still beautiful and pleasing.
  19. Your choice on the hull planking. I completely planked for several reasons and am happy with it. I can see the merit of either way.
  20. Tony, your cannons look great. One has to remember that macro is not our friend and usually no one ever gets that close. Excellent work on the frapping.
  21. All I can do is echo the others Bob on your masterpiece. Congratulations.
