mtaylor
Moderators
Everything posted by mtaylor
  1. Good points all around. Sometimes it's just best to let them hit the wall. Then be there to help them off the floor. We all learn, sometimes from words, other times from running into the wall.
  2. Thanks for all the "likes", comments, and "just having a peek in". Update time.... All three decks now have their clamps in place. I've checked from side to side and they're close but need a bit of touching up with a file to get each side level with the other. I've also started making up the beams for the lower deck. The pictures show the first two beams shaped on the ends and also sitting in place. I'm still planning on an almost full lower deck with the following exception.. the aft end planking will end after the partition and door for the gunroom. I may change my mind as get more into this area but I'd be winging it to put any thing after that wall basically be sheer guesswork including the beams. There's (according to the plans) two "cabins" in the gunroom but I'm thinking they're storage. The hull in the area takes on some serious curves. As I said, I may change my mind once I get into the deck planking. I'll also put in the mizzen mast step, the main and fore mast partners, the oven, and the three hatches (two have gratings). There will also be the cabins (empty), bread rooms, and storage rooms along with the forward partition that's behind the foremast. The anchor point for the bowsprit will need to be installed and the opening in the bow opened and shaped for the bowsprit on the beakhead. Anyway, here's the pics... I'm open to critique, ideas, and thoughts as always. Have a great Friday and weekend.
  3. John, I'm happy to have been of help. We all learn from each other here. I'm just glad you found what works for you.
  4. Hmm... I've never had success with the boiling or microwave way of bending. I soak and then use a curling iron... rinse and repeat as needed. I tried Chuck's method and some woods worked well, others, not so much. Plus, I don't have space to work with the heat of a heat gun. My workshop is pretty packed. The key is to heat until it's pliable and then bend and lock into position until cool.
  5. It's a pity the owner of the real ship can't see this, or hasn't seen this.... Most impressive, Patrick.
  6. I would think the yard dogs deserve a tot or two of rum or perhaps, being French... wine. It seems a plan is coming together.
  7. That is one fine looking model, Dick. Your research and efforts are really paying off.
  8. Lazy, Denis? I hate to be around for a busy time in shop. Sorry to hear the car is giving you fits, but the shipwork looks great... if that's any consolation. Edit.. we were cross-posting. That gasket looks like the real thing.
  9. HI Kurt, I'm not sure what you mean by "the best/preferred way to proceed"???? There's planking tutorials pinned here: http://modelshipworld.com/index.php/forum/14-building-framing-planking-and-plating-a-ships-hull-and-deck/and in the database here in the Planking and Framing section:http://modelshipworldforum.com/ship-modeling-articles-and-downloads.php I hope this is what you're looking for.
  10. Have a great trip, Pat. Endeavour is looking fantastic in her home for now.
  11. I don't know if he's abandoned this build or if life really got in the way. His last login was the day of his last post.
  12. You could be right on that Joel. As I understood it, it was needed for the first load (if the guns were unloaded) and then if there was a mis-fire or if for some reason it didn't recoil. It would make sense to me, not have excess clutter on the deck.
  13. Will, There's a scale "ruler" shown in your last photo. Check it with your ruler and see if it measures up, so to speak. If so, that would be the fastest way to see if it's the plans or the cutting that's off.
  14. Michael, They do have inhauls. Depending on the navy and even the captain, they might or might not be rigged until actually needed to run in a gun. They were usually not rigged until the call for "action" except for maybe an inspection. They would be something else to trip over.
  15. I've seen quite a few posts referencing that these exist and apparently some are having a hard time to find them. I hope Chuck doesn't mind but I'm putting the links here.
  16. John, For this, you're choices are spiling or bending... or a bit of both. Chuck's system works very well... I checked Youtube and he must not have loaded it up there. He basically heats the wood until pliable and then bends it using clamps to a table top and let it cool. I do it a bit different in that I soak the wood for a bit and then use an old curling iron to bend and shape. Lots of ways to get the same place. Edit: Found them... These really need to be put some place on the site..... Edit of the edit... I just posted these to the Planking sub-forum. I hope they help.
  17. I'm finding that the more I do, the more I'm willing to try on this ship... Not sure if that makes sense, but truly is a journey. I'll need to make several measurement per beam and adjust the ends as needed.. pretty much customize each one to fit the hull shape. Not just the angle for the meeting the hull horizontally but also vertically due to the tumblehome. It should be interesting. All that jig does is give me the flat spot I need and beam thickness at the clamp. The MM R8 is the same as the Sieg except for motor power and the Little Machine Shop has a rigid post. The smaller mills MM sold are, shall we say, illegitimate step-children? There was almost nothing they sold that fit them easily. Sherline isn't out of the running but I need to re-examine their offerings. I really would like to have the drill press feature as my drill press sits in the corner, on the floor since there's no bench space for it. HMS Visa is recovering but if things work out for a trip to the NRG Meeting, she'll back in drydock afterwards. If things don't work out for the trip... the mill is mine.. bwahahahahaha.... I think you're right on his tool, Grant. Vote acknowledged.
  18. You might try asking about flags and sails here: http://modelshipworld.com/index.php/forum/16-masting-rigging-and-sails/ Some use cloth (thin or well worn sheets with a high thread count) and others use paper products.
  19. Nice save, Al. A lot better than ripping off planking.
  20. Thanks for the "likes" and comments. I didn't get to where I wanted to be today, but clamps are on 2 out of the 3 decks that need them. Spales are "in work". Richard, The Sieg is made by the same folks that make the MM mill. There are differences but both use the R8 taper for the chuck or collets. The accessories (other than collets and chuck) should fit those and the Sherline and the LittleMachineShop mills. The only thing I'd have push out the door with this mill is the collets as the holder is an MT1 taper. All the other accessories will go either way. I'm thinking the way you are.. drilling also. I don't need a pivoting head, like MM as that does add some play.... I'm still on the fence.
  21. That's true in today's world with insurance, etc. The ships going near Somalia were using hired guards who brought their own weapons. I'm not sure when it became common for merchant's to not carry weapons... late 1800's maybe?
  22. Good luck on the carving of that crown, Chuck. I did some cutting at 1/32" and carving can be done, but just use an extreme light touch. Beautiful work on this barge.
