mtaylor
Moderators
Everything posted by mtaylor
  1. I'll bet that our parents said that about us. :D So, did you roll over and go back to sleep or listen to Her Majesty calling you?
  2. Trust me, Nenad, I have more than my share of the "oh crap" and "you idiot" things. That's many of the reasons I started this ship over. So far, the ones that I have found haven't hurt... yet.
  3. I think most of use bees wax. Some will run the waxed line over a lightbulb to set the wax. I'm thinking that you can use what works for you. There might be a downside to candle wax but I have no idea what it would be.
  4. Piet, I love it. Small parts yet large work and they look great. I'm not sure is the brass monster is a new beast or the beast under workbench has a varied diet. Mine like wood (all flavors), brass, steel, copper, even potato chips.
  5. Actually, to me it is fun. Almost as much fun as building. I'm excited...new book coming, new plans to look at and study. Hopefully no new "oh crap" things.
  6. Even better then, Chris as bulkheads are a faster method than frames. I was looking at Frolich and he doesn't mention bulkheads.
  7. Chris, Sharp little schooner that is. The downside is that you'll have to loft the frames as I recall. Which, might be something to energize you...
  8. Ammonia fuming? Thanks for that tip. I have some wood I would like darker. This ship is even smaller than your others? Makes my eyes hurt just thinking about it.
  9. Still slogging away in the shipyard... aft half-frames are still a work in progress. However, I've been doing research and discovered via some very nice PM's with Mr. Delacroix that I have errors... and Hahn also.... other than the framing. 1) I've had to correct the history on the first page of this log. This vessel was never known as "Unicorn" while in the RN service but as "HMS Licorne". It was sold out in 1783. 2) From Hahn's article, he was advised to use the Le Venus information for rigging and certain other bits and pieces. I've been advised to use La Belle-Poule for rigging and best practices as it is closer in time and more correct. I've placed an order for the monograph from ANCRE and eagerly await it's arrival. 3) The breeching rings on the bulward should be through bolts with washers and forelocks on the outside of the hull. 4) What I thought was an air port between gunports 11 and 12 is actually a window/light port. It will be glazed. 5) Referencing port lids: In the French Navy frigates have no port-lids to their port. They are eventually closed by false port-lids in bad weather, simple square panel of light wood pierced for the passage of the gun. Nothing in common with the real port-lids. It was not until the early nineteenth century to observe French frigates with port-lids. I am indebted to Mr. Delacroix for this information. So.. back to cutting and gluing frames for now.
  10. Mick, The thickness is variable and by that I mean that it shouldn't flex. You can use thinner material but you'll need to use more spacer bolts. I hope I'm interpreting the question correctly.
  11. HI John, We have "group builds" for selected ships and boats but not a team modeling as such. What usually happens is that those building the same model visit each others build logs to discuss issues and solutions, etc. And the log gets visited by those interested in the model either because they have it on the shelf or they built it. So.... open a build log when you're ready.
  12. No worries, Tony. MSW is a big place and it's easy to misplace a post.
  13. It sounds promising, Toni. I like the choices in wood although I'm partial to swiss pear on the planking.
  14. Yeah.. I'm having a senior moment on the title.. IRA types as I recall, bomb expert. Had a real Rube Goldberg to blow up the freighter he was living in... Edit: Just found it... Blown Away.
  15. Sweet work, Bob. I never would have guessed the wheel was metal.
  16. By all means get the plans and starting setting about the build. Then at some point, you will probably pause and say "I need to get Confed off the bench as I need the room." I suspect motivation will come. If not, just put a placard on it that says "under construction". And I think keeping up with the twins would be an energy sapper.
  17. Good to hear that, Alan. I think we all were perplexed. I guess you're getting closer to making sawdust?
  18. Dave, You're right about the bamboo. it looks great.
  19. I'm not saying much so far. Just watching in awe.
  20. Thanks Dan. I hope your being away was for fun. As for the gunports... necessity is the mother. I don't think this would work if only a small amount of framing needed removing.
  21. It wasn't blown up at the end of the film was it? Tommy Lee Jones movie as I recall.....
  22. Tony, I'm moving this to the kit log area and adding a few things to the title. It really should be in the kit log section.
  23. Clarification as Kevin brought up a good point. I've heard it said that we are two countries separated by a common language. I think, lining is only done on POB models as there aren't enough frames. If one looks at the fully framed and the real thing, the sills and the frames provide the port linings. Usually, the ship was framed and the ports cut while in frame. They would plank her and then cut or at least finish fit the planking around the ports.
  24. Ah.... ok.. No offense taken. I think I answered rightly then. No lids, no rebates, no frames.
  25. Thank you for the nice comments, Pete, Michael, Mij Good question, Kevin. I'm not sure on either point. As built, she had lids and the appropriate rebates. At the time of her capture and after a major rework, I can find no sign of lids. There are sills, but again, no indication of linings as kits have them. The frame is the side linings. I'm not sure "rough" would describe the ports.. they'll be filed/sanded smooth as will the sills. The internal and external planking will be to the opening and smooth. Things are still pretty roughed in at this point with more work coming once all the frames are in place.
