Everything posted by mtaylor
Rusty, Ok.. forget the lathe for second... or two. What Rob said about the blank. No expensive tools needed... sandpaper, files, maybe a chisel if you feel dangerous. Oh.. and time.
- 421 replies
- granado
- bomb ketch
Storing and using those tiny drills
mtaylor replied to Modeler12's topic in Modeling tools and Workshop Equipment
Jay, I do use a similar method for my milling bits.. a block of wood with holes drilled in it. For my bits, I just leave them in the tubes until I need one. If I break one, out comes another. When done, back in the proper tube. ME sells bulk bits in packages of 10 in sizes... like a tube of #75's. $2.99 per package currently which beats MicroMarks price. There's some topics around here that mention other places. -
I guess I went the expensive route. I ordered a set of 61's through 80's that come in individual tubes and all in a wooden box from ME. I replenish as needed... -
I agree with Nils.. no need to second plank. Looks great!!!!!
- 55 replies
- mercury
- victory models
Moving right along and going well. What I meant by taking lots of pictures is to see the parts and things through the camera. You need not feel pressured to post them. I take lots of pictures, examine them, see what needs to be fixed and later delete the photos. I'm not the best builder here. Far from it. But it's part of the learning.
- 188 replies
- latin caravel
- artesania latina
Nice work, Hamilton. I'm happy to hear all is well with the little one and things are settling in.
Rusty, I agree with Grant. It depends on what your future plans are. Lathes do have their uses for other than cannon. Otherwise, use the drill press method. I did some small cannons (1:85) using a Dremel and files. The drill press would just be "bigger".
- 421 replies
- granado
- bomb ketch
The aluminum can idea for flags was, I think, Harold Hahn's. I and others open the can, flatten it, bend it into a nice shape and lay the cloth/paper flag on it. Then starch or dilute PVA the life out of it. When it dries, it's in the shape desired.
- 396 replies
- Idea
- Bright Idea
I'm not sure what you're saying here?
Budget Lathes in UK; Advice please!
mtaylor replied to Phoenix_63's topic in Modeling tools and Workshop Equipment
Scott, Congratulations. My advice is simply this: go here: http://www.mini-lathe.com/Default.htm and follow their tune-ups. Also, check the run-out on the spindle. Also, check out the link at the very bottom of the home page... for HOME SHOPS. More excellent information. While none of these may be your exact machine, the principles are basically the same. -
Plank on frame ship cross section kit.
mtaylor replied to mikeaidanh's topic in Wood ship model kits
There's also been some bow sections as kits... such as Victory. Otherwise, there's been several scratch builds that were cross-sections. While they're all well done, one of the more fantastic is Karl's Bonhomme Richard. -
Augie, Sweet planking. I'm sending you my ship for planking.
- 2,191 replies
- confederacy
- Model Shipways
Sam's right... You're hooked Vivian. One tool you already have... a camera. Take photos at every step and look at them. The camera sees things our eyes don't. It gives you a chance to fix things while they can be fixed and you'll be happier. Nice work on her. I think you're doing great. We all make mistakes and as we build, we learn. The great thing about MSW the other eyes of folks looking in. It makes the learning easier.
- 188 replies
- latin caravel
- artesania latina
It looks like maybe Corel makes a Victory Cross-Section that might fit your question. Also, there's a Constitution and a Santisima Trinidad cross-section kits. I'm not sure if those are fully-framed or partials. -
Was here on MSW? I know there's the scratch group build of the Triton and the Echo. As far as kits being plank on frame for a cross-section, maybe someone else can help. -
There's some clarification in the discussion over here: http://modelshipworld.com/index.php?/topic/3513-builders-of-small-boats-please-read-this/ Basically, the designation "small" has nothing to do with model size. It's based on the real thing. So, "small craft" would be the definition... a small smack but not a trawler, etc. If you open a build log and are unsure, let us (the moderators and/or admins know. We'll try to help sort it out.
I have a smaller version of that from the local home supply store. It's the same as the picture which the one MicroMark sells but Lowe's had it on sale for a lot less. Very handy and works very well. I think that for what we do, many times smaller is better. Drill presses and scroll saws are a different critter, however.
Who did you order it from? You might try them first.
