Everything posted by mtaylor
Grating dimensions
mtaylor replied to KobusBeukes's topic in Building, Framing, Planking and plating a ships hull and deck
Per Lavery's Arming and Fitting of English Ships of War, the opening was about 3" (76 mm) at full size. Other sources say 2.5" (63 mm) All say the wood should be about the same dimension. -
Hank, Looks like everything is planned and ready to go... I hope you don't mind if I pull up a chair. When did the New Jersey leave RVN for the last time? I arrived in the middle of December, 1969 and several times over next 6 months, we saw the flashes at sea and heard the shells roaring overhead. I was at Marble Mountain... puzzlement as I remember someone telling me it was the NJ. Now I'm wondering if it was another BB or maybe a Heavy Cruiser.
- 187 replies
- new jersey
- trumpeter
John, You might try painting your bricks and mortar before gluing them in so there's no bleed over. Once glued, weather. As always, test first. Ah yes.. I sense it.. the force is strong in this one. The darkside has cookies...
- 2,250 replies
- model shipways
- Charles W Morgan
I'm hearing calliope music and the gentle splash of a paddlewheel coming on....
- 1,038 replies
- King of the Mississippi
- Artesania Latina
Beautiful work, Rusty. Looks like something that would be both fun and a bit scary at the same time.
- 421 replies
- granado
- bomb ketch
The handles should be a bit stiff but they do loosen up. I suspect it's the grease they put them at the factory. Once you have it located, bolt it down. The CG is pretty high especially when you raise the upper assembly to install bits, etc. The red isn't grease is it? As far as I know, MM is the only one who offers this particular model. I've seen the red grease on some other mills and on lathes.
Richard, By the way..go buy some extra fuses. Just a hint... I think I blew 5 learning to use this thing. Once I got some knowledge and good feel, I haven't blown one since.
Japanese Super Submarine From World War II Finally Discovered
mtaylor replied to mtaylor's topic in Nautical/Naval History
Interesting, Brian. Either the plans were out there, or this story is dated... -
Piet, Check Micromark also. They have a lot of model RR stuff and used to carry quite an assortment of miniature hardware.
Richard, Milling is basically milling... So... visit: http://www.littlemachineshop.com/default.php and hit the "Learning Center" as well as the "Info Center". Good, solid, basic info. The other good one for basic info is: http://www.mini-lathe.com/Mini_mill/Main/mini-mill.htm While they don't cover the mini, they do cover methods. Edit: I just noticed that The Little Machine Shop is now starting to cover the mini.
Keith, What Pat said... it's a hobby of "improvement". The true modeler in all of says: "the next one will be perfect". And it's usually better just from the skills we pick up along the way. And I'm with Pat on commenting... too many excellent logs, too little time.
Richard, Which MM mill? The mini or the R8? I can't imagine the R8 being that inexpensive.
