Posts posted by giampieroricci
On 2/14/2022 at 10:15 PM, Kevin Kenny said:
The details are fantastic. Perhaps slightly out of scale but at these sizes its almost impossible to get this absolutely right. In many cases if the scale was correct i don't think the pieces could be built. One of the models i submitted recently for judging, one of the points i was heavily criticized for was as the hole size for the seine in the boat was too small. It was the best i could find, and yes it was smaller than the real size for the seine , but the only other option was to leave the seine out all together. It was a fishing boat that used a seine so i am not sure what sense that would have made.
i am rambling. Makes me wish i had done this with the Thorn.Thanks Kevin! I follow your work very closely and try to get inspiration! It's a new type of construction for me, which I had never approached and I try to do the best I can.
The hinges are indeed a bit out of scale but functional; the alternative was to make them fake. -
The block and the pitch and tar rooms:
- Siggi52, Jorge Diaz O, mtaylor and 26 others
29
4 hours ago, dvm27 said:
Such a pleasure to see your work in progress. While I included every detail in my Swan class build as well it is a sad fact that most of your current work will not be visible on the finished model, even with partially planked decks. If I had a do-over I would seriously consider adding LED lighting in some of these areas (such as the lanterns in the light room). I know nothing of these things but it seems very doable at your scale.
It wouldn't be a difficult job and I'm thinking about it. I have already done this in my Amarante
you are doing a great job, Oliver!
- mtaylor and Oliver1973
1
1
You're doing a great job!
You are my source of inspiration! -
I started the construction of the beams of the lower deck;
everything is provisionally positioned:
- KARAVOKIRIS, Robp1025, gjdale and 16 others
19
2 hours ago, scrubbyj427 said:
Beautiful work! What wood did you use for the frames?
Pear wood
- billocrates and mtaylor
2
HMS PEGASUS by giampieroricci - Scale 1:36 - Swan-Class Sloop from plans by David Antscherl & Greg Herbert
Sorry to disappoint you, but I won't be filling these drawers, just as I won't be filling the holds with barrels...... 😜
