Posts posted by giampieroricci
16 minutes ago, dvm27 said:
It's a treat for me to see the ship built at this scale. The stern geometry looks great!
The measures all add up.
I just have to make a few small adjustments.
I was particularly afraid of this part of the construction, which was not at all simple!- druxey, mtaylor, billocrates and 2 others
- 5
great job, Albert!!!
- FriedClams and mtaylor
- 2
Museum model! Very impressive!
- archjofo, mtaylor, FriedClams and 3 others
- 6
after some time I have completed the laying of all the frames:
- druxey, shipcarpenter, CaptMorgan and 26 others
- 24
- 1
- 4
I placed a few more frames. In this type of carpentry to be able to set up a frame it takes a lot of time!
To give the structure more solidity, I thought of using some steel nails placed transversely at the base of the frames:- GrandpaPhil, Robp1025, scrubbyj427 and 19 others
- 20
- 2
I don't understand: Why??
- FrankWouts, druxey, bruce d and 1 other
- 4
While waiting for inspiration, the two mascon decorations remained pending; I decided that it was time to complete them and to make the figurehead as well.
- Archi, ChrisLBren, Gahm and 14 others
- 17
I started square frames. These constructions take a long time, each one is different from the other, each component has a different thickness, in short, a real challenge!
- PeteB, muratx, billocrates and 13 others
- 16
I have finished the installation of the cant frames.
I hope I have interpreted well the shape of the rising wood !- muratx, Siggi52, chris watton and 20 others
- 23
Thanks Greg!
I treasure your suggestion!- FrankWouts, mtaylor and druxey
- 3
Thank you, Allan and Glenn, and for all your likes!
The work seems to be going well, even for all the measurements that I look at at least three times before operating ....
I have finished the arrangement of the fore cant frames. The arrangement of the fore cant frame n. 11 is very particular because it has a cast timber:- muratx, Ryland Craze, billocrates and 15 others
- 18
sills:
I continue with the fore cant frames:
and aft cant frames:
- Edwardkenway, GrandpaPhil, dvm27 and 18 others
- 21
8 hours ago, dvm27 said:
If you don't screw up at least one of those mortises over the course of framing the hull...I'm going to hate you. Getting a fair line was the most challenging part of the build for me.
I am undecided whether to continue in this way, as David also suggests in his book, or open the gunboats after fixing all the frames. I wanted to try with the ventilation door .....
- FrankWouts, druxey, Saburo and 1 other
- 4
HMS PEGASUS by giampieroricci - Scale 1:36 - Swan-Class Sloop from plans by David Antscherl & Greg Herbert
Thank you all!!
The helm port and the lower counter:
