Old Collingwood
  1. Evening all, a bit more done this evening - I added a few bits to the Bridge and a bit more PE, I have added a few items in the pic for scale the coin in a Ten Pence Piece and my glasses. OC.
  2. Thank you kindly Mike, boy is it fiddly and delicate - and can not be rushed, I use the old fashioned way to remove and bend the PE - sharp blade then blade and tweezer flat end to hold the PE while I use the blade to bend it, then holding it with tweezers to glue in place is tricky - takes great skill to keep my hand still enough during this. OC.
  3. Yep - I have put a swear box on the side of my table - bet we would all fill one with our builds or discover words we never knew exsisted. Good to see you back on here mate. OC.
  4. Thank you kindly Alan, just to think there is Four seperate sub-assemblies making up the conning tower - each section will be airbrushed then brush painted Corticene. The binoculars - I might try to use some of my acrylic water to create the lenses .........." I dont think so" lol. OC.
  5. Welcome to the Model zone - what a good start you have made - looks like you are off to a fine start, looking forward to more of your build. OC.
  6. Evening all, I did a bit more work with my tissue origami still on the conning tower - so more rails and ladders oh and a few details - binocular stands etc. OC.
  7. Hi all, I had my normal Saturday off so I could relax infront of the tv, anyway onwards on Sunday where I will be battling with somemore Paper Extreme (PE) with a few more sections of Railings and short ladders on the conning tower. OC.
  8. I so love your detail and painting Greg - its getting to a ridiculous stage now where the model is merging into realism - due to a craftsman's skill - lovely to watch. OC.
  9. Thank you so much for saying and doing that - so very kind of you. OC.
  10. Just did a calculation - those railings are a Huge 1.2mm tall - no wonder thay are hard to handle. OC.
  11. Splendid work Kevin - that piping and those rocker arms look Superb. OC.
  12. Evening all, today was "trying the impossible" time - bending and fitting some conning tower rails, I fitted one of the ladders - that was "easy peazy" but the rails - boy was it difficult as its all ready been mentioned this PE is tissue paper thin and if a fold line is bent to much it breaks off, I am not even attempting to fit a couple of levels up - but think what I have fitted is ok. OC.
  13. Thats coming along really well Alan - love the touch with the headlamps - I did similar on my Chally 2 build I used a bit of that acrylic clear water I have, you really are mamking a really interesting looking vehicle here. OC.
  14. Thank you kindly Alan, yep all the small parts are seperate - takes the utmost skill just to cut them away from the spru's - then you have to hope they dont "ping off" mind you I have found a certain way of gluing them down - I make a small pool of glue on the side of my cutting mat then while holding the part with my teezers I touch the part to be gluid in the glue then place it down, if I tried to use the Revell glue needle even that is too wide and too much glue would come out on the area to be glued. OC.
