Posts posted by Old Collingwood
Evening all - so the work carries on, in order to complete the inner section some detailing is needed on the rear most cabin walls above the rear ramp, all the detail is molded on but needs painting/shading and highlighting, some decals need to go on the inner padding then they can be glued to the floor.
Oh - I drilled out the framework holes also - they were there but not very deep.
OC.
- lmagna, GrandpaPhil, Edwardkenway and 6 others
- 9
Really nice work - looking super.
OC.
- Lt. Biggles, Egilman, Canute and 1 other
- 4
- lmagna, thibaultron, Egilman and 1 other
- 4
- lmagna, Kevin, popeye the sailor and 8 others
- 11
2 hours ago, Egilman said:
That's an RAF bird at an airshow, open to the public.....
They always get up on their housecleaning in that situation......
Gotta keep up appearances you know....
Indeed bro.
OC.
- popeye the sailor, Canute, Egilman and 2 others
- 5
1 hour ago, Canute said:
Nice looking red seats, OC. Do you have lap belts for those seats. They're usually strewn all over the seat bottoms. The pax just up and leave them wherever and the crews in the cabin have enough other duties to worry about neatness. You're doing great work on this beast, sir.
Thanks Ken, the ones already on the backs are molded on but not very good - I could have a go at replicating some with tamiya tape, might work.
OC.
Just sorted my pics out of my current stage - I have started working on the fabric bench seats in the cabin, these are plastic and are painted flat Red and Alum - I will place a few rows and leave the end sections in the up position (just for a bit of variety).
The inner hull section is just leaned against the seat to show how it will go.
OC.
- Canute, popeye the sailor, Egilman and 8 others
- 11
4 minutes ago, Egilman said:
Coming right along brother, looking good....
Thank you kindly bro.
OC.
- mtaylor, Canute, popeye the sailor and 1 other
- 4
Evening all, so - more work has been done (you know me I don't like to rush things) anyway I finished off the cockpit by painting the seat cushions a nice mid Grey colour, then when Dry I fiited the decal seat belts (no fuss to these - not as good as pe ones) then I brushed on a few coats of flat clear to blend them in - then I fitted the pedals (Four part buddies they were). Then after painting and weathering these I gave the whole area another coat or Two of top coat, then the cockpit bulkhead was glued in.
OC.
- Egilman, GrandpaPhil, lmagna and 6 others
- 9
50 minutes ago, thibaultron said:
Nice! I have a vac form kit of a 1/72 B-17 YB, the first production model, and am terrified of it! Maybe some day I will tackle it. I have the complete series of 1/72 kits (all the A thru G variants), and would like to build the vac kit, when I finish those. I even have a card version kit of the prototype. Probably not enough years left to finish all of my stash.
Come on Ron, you know you have an audience.
OC.
On 7/11/2020 at 1:45 AM, Louie da fly said:
I've put this build on hold for the time being - I'm putting all my efforts into the dromon build at the moment, trying to get all the oarsmen completed. Once that's done I'll be able to do some more on the Great Harry.
I'm "abit" late to the party but it came to me - Isn't the Marry Rose similar? could you not use her plans to help with your hull planking?
OC.
54 minutes ago, VTHokiEE said:
This is really incredible! Great work on that cockpit!
That is so nice of you mate - to be fair its not a bad kit.
OC.
- Egilman, mtaylor, Edwardkenway and 1 other
- 4
5 hours ago, Keith Black said:
Most models, beautiful as they maybe, are static and a bit cold. Louie, yours, one can hear the shouts from the crew and the grown of the oars. Congratulations!
Thats why I put a crew on my Pearl build.
OC.
- Keith Black, mtaylor, Jeff T and 1 other
- 4
3 hours ago, Landlubber Mike said:
Super cool! Lot of nice detail in your skilled hands.
Thank you Mike.
OC.
- Egilman, Canute, Edwardkenway and 2 others
- 5
Amazing work you have put so much effort into this amazing build you should be so Proud.
Congratulations.
OC.
- Canute, yvesvidal, mort stoll and 2 others
- 5
Keep an eye on your wood decks - mine had a habbit of trying to lift slightly around fittings - just a case of making sure its all pressed down.
Looking really good.
OC.
2 hours ago, Kurt Johnson said:
That’s interesting. Thanks, I learned something. I have never seen roof like that before ( which isn’t saying much at all). I am definitely of the newer isn’t necessarily better crowd. I’m a back to basics person, if anything. There was always a good reason why things were done the way they were done at the time. We are definitely not any smarter today. Irregardless I still like the look.
Kurt
I would also have said - the aging of the roofs/materials as timbers bend and sag with age (I have seen it myself with old/er buildings you should have seen the roof in our old 17th century cottage we used to live in, it would have made a good roller coaster.
OC.
- 5
15 minutes ago, Louie da fly said:
It's been an experience. Now to figure out where I go from here . . .
How about a 18th Century British Frigate with a Full crew ?
OC.
- Keith Black, mtaylor and Cathead
- 3
Not sure if this might be of use - its decribes and shows the main RN colours - scroll down till you see POW (Ita alphabetical)
OC.
https://www.sovereignhobbies.co.uk/pages/british-royal-navy-colour-schemes
- Lt. Biggles, Canute and mtaylor
- 3
Just found your build - the hull planking with the first planking (I assume you will be laying a second layer of planks over the top as its normal procedure) is always a tricky/fiddly/nerve racking procedure - even the pro's like to get it out of the way.
With your deck You have done a fine job - its neat and tidy and as others have said its easily sanded even with pencil in between the planks as the sanding action cleans as you are going.
Keep at it you are doing fine.
OC.
- rkwz, Obormotov, Ryland Craze and 1 other
- 4
HMS Kent 1942 by RGL - FINISHED - Trumpeter - 1/350 - PLASTIC - heavy cruiser
"Berries berries" where's the berries😛
OC.
