barkeater
NRG Member-
Everything posted by barkeater
Nice solution on bow and bulwarks. Looks good.
- 64 replies
- badger
- caldercraft
I'm a bit confused which is not unusual for me. I have a micro table saw which works well for mm size ripping. With .5mm I have to go slow so as not to split or break the plank. My saw will not cut 1 inch thickness satisfactorally. Do you havea standard table saw in which case .5 mm I think would be really tough? With my micro saw I would cut to the larger thickness 4 or 5 mm and then do the .5 off of this. A better idea would be to buy 1/8 or 1/4 inch planks and rip them which would give you 3 1/2mm and 6mm planks roughly. If you want to be more exact plane them but with the naked eye I don't think anybody would notice. Rich
Protective topcoat over blackened brass?
barkeater replied to Mike_In_RI's topic in Metal Work, Soldering and Metal Fittings
I have used Testors Dulcoat. As the name implies it does not give a shiny surface. Some people don't use any coating but I do feel it helps maintain the blackenig. -
Looking good. The Badger is an interesting vessel both historically and physically. I like your choice of 1/48 as it lets you add detail. Good luck with your build and I look forward to following your bujild.
- 64 replies
- badger
- caldercraft
I like your revision of the fife rail. Much more workable.
- 110 replies
- le renard
- artesania latina
To bad the bulkheads have been glued otherwise you could cut another frame by tracing the existing onto plywood or wood. I would use the scrap filler to fully correct the bowing. Your fairing will be more difficult but you can shim were needed. Is it a double plank model? If so you have two layers to play with which would help. If you are going to use treenails and correct spacing for plank butts a single plank model might be a problem as your butts would be asymmetric however with a double plank this would not be a problem as you are gluing to the first planking and not the bulkheads. I do two plank bulkhead construction but add false frames for my second planking and just glue to the first plank.
Jamie, that is a puzzler. I don't see why or how you would fair bulkheads unless they were glued in place since they need to be faired in relationship to one another. Blocking you can either install before fairing or after fairing and the fair them in. I prefer putting the blocking in first and just fair once.
Looking good. Very inventive on your clamping.
- 110 replies
- le renard
- artesania latina
Woodfiller and glue
barkeater replied to Kyak's topic in Building, Framing, Planking and plating a ships hull and deck
Using wood strips for flats and hollows works well. If you have a smaller irregularity you want to correct, use wood putty and then sand with a fine grit. You do want to have as much wood to wood contact for gluing when you lay down your second planking as possible so don't go to overboard with filler. For wood to wood gluing use wood glue pva. Only use ca when you are bonding metal to wood and be careful as it stains the wood and is tough to sand out. -
Poly after gluing to deck...
barkeater replied to mpk73's topic in Painting, finishing and weathering products and techniques
If you are worried about sheen try Testors Dullcote on a piece of scrap wood. I find it does not give an appreciable sheen and can be used to dull down a sheen from a poly undercoat. -
Getting back to your question on which edge to taper, I always taper that edge which will abut the existing plank. This way you know right away if the plank you tapered was done correctly and has a good angle to fit in smoothly with the existing plank and you always keep the opposite edge straight and true to lay your next plank against. Also concerning the placement of bands. Here, I am bit of a nonconformist. In the first planking I measure in millimeters the entire length of the run up the bulkheads where I need to plank instead of breaking this up into multiple bands. Then I divide this by the width of the planks I'm using. This lets me know how many runs of planking I need to do at each bulkhead and how much taper I need at each bulkhead over the entire hull. I can then start to do slight tapers before I need them rather than possiblly more severe taper at some areas which I would need to do using bands. As an example I can start to do a 1mm. taper on a plank before I need it rather than a more severe 2 or 3 mm taper if I wait. I do a few runs of planks and then remeasure all the bulkheads and readjust. This way I can do a hull without dropping a plank or adding a plank. I plank to scale on my second planking which for me at 1/48 is 5 inches in length. I draw on false bulkheads in between my existing bulkheads on the second planking which allows me to follow rules on plank lengths and number of planks between butts.
My two cents. First you say that the planks are laying flat on the bulkhead but in the pictures it really looks like they are laying flat on only one edge not across their breadth which would go along with your pictures. If they were laying flat across their entire breadth you would not get the step appearance which is seen in your pictures. Planks being of equal thickness, there would be no step. Your mistake in this case appears to be, as has been said, that you did not let the planks assume their natural curve. At the bow, the planks will progressively overlap one another so you have to taper them going forward or drop a plank. It looks like you did not taper but rather fit the plank in at the bow and then tried to bend the plank to match up to the other bulkheads. I would take them off and redo them. If you don't correct mistakes early in planking especially with a double planked hull it will only increase your problems later. I would look at the planking tutorial in the forum for more clarification. It is tough to asses the beveling or fairing of the bulkheads in your pictures given the problem with the run of the planks. If you do still have a problem with beveling, which I don't think you do, after you fix the tapering problem this would be easy to fix. You just glue on a strip or two of scrap planking along the edge of the bulkhead where you have taken off to much wood and bevel or fair it again.
Holes in Stem Post
barkeater replied to acaron41120's topic in Building, Framing, Planking and plating a ships hull and deck
If I read this right, one could possibly be for the bumpkin shrouds and the other for the mainstay collar. A picture would help. -
I use wire for eye bolts, ring bolts and hooks. I use sterling silver half hard wire as I like the strength. I solder rather than twist for the eye bolts. My eye bolts are 26 guage and I go up in size for the ring in ring bolts. The silver can also be hammered to make other fixtures such as door handles. I work in 1/48 scale. All my lines standing and running are thread.
Nice looking shot. As far as I know these odd shot types were stored below decks in the shot locker. They would have been used by larger vessels at least frigate size and brought up on deck when needed. I hate to bring it up but I seriously doubt that chain or bar shot was used in the battle of Valcour Island.
