2 - The pilot house does not have a 'U' shaped bench, but has two separate ones.
This is the way the kit has it
The following is what is re-created for the model to look like the actual boat.
Vellum template
Took out the back partition and glued in the pilot house.
The benches laid in.
Next the stern combing, finish all the vertical planking and sand the whole thing.
Marc
Very nice work, Marcus, as is your commitment to replicating the original.
I gotta say, "who doesn't like a catboat"? I know I am certainly a sucker for them and your's is no exception.
Cheers and all the best!
Patrick
Edited by Omega1234
Hi Marcus, I'm still way behind you but finishing up the hull planking. I was just wondering what you thought of the idea of running the sheer plank 1/8 inch above the deck to provide a back for the deck planks? The plans simply show a strip laid against the top of the sheer plank - it is probably mahogany and likely why they do it that way but I'm thinking that extending my walnut plank up would be structurally better. Anyway, just musing and I miss your updates of late.
Edit: I've answered my own question. Rather than mess your log up Marcus I'll post in mine. Let me know if you want me to remove this post.
Best, Ian
Edited by Seventynet
Best, Ian
All comments welcome and you are not messing up my log. I will give the above idea a thought.
Marcus
Been working on and off on the boat. Five minutes here and there. I completed the hull, cabin and pilot house. It needs a little bit more spackle and then the final sanding. Paint the hull and the roof separate. Glaze the windows and then glue the roof on.
The mirror with the door glued on. Once the roof is on shine a flash light in the cabin to see the interior.
Pilot house.
I forgot to step the mast, so I took a dowel of the same thickness as the mast to measure it out.
Figured out the angle of the mast by making 2 templates from scrap wood and comparing them to the drawing. I proceeded to shove a lot of wood putty in the mast hole until it was pretty full. Put the dowel in, angled it with the templates, let it dry and while turning pulled the dowel out. Let it completely dry and now you have a cylinder to put the real mast in and at the correct angle.
Due to the added weight of the wood putty in the bow I added similar weight of putty under the benches. It is almost a solid hull.
Marcus
You've been busy, Marcus. She looks very good to me. With the added weight, you'll not need to be afraid she might be blown from the table, when it's drafty inside
Cheers
Carl
Hi Marcus, that's a rather ingeneous solution for those of us who forget to step the mast (ahem). I may just be doing the same thing. By the way, how are you planning to attach the boom?
Just the way the plans show. The templates for the mast come off once the mast is at the correct angle.
Marcus
So for the last 3 months I've had little time compared to the last week. Work is slowing down especially with the 95F (30 something C) temperatures and who wants to shop for plants in this heat. I am also taking 2 days a week off as well.
After all the spackling and sanding the boat is relatively smooth. Tapped up areas that need to show the wood.
Now comes the part of building a ship I hate the most. It is called painting. I have never been good at it. I read all types of 'How-To's', I have many articles about this subject. It is just not for me. I try to avoid it like the plaque. But,..... this boat calls for it so after reading some and practicing some I put on the first coat using a can of paint with the correct color. Darkish sand.
Looked good after the paint job was on but after it dried I noticed several spots that were drippy.
Sanded that down and did another coat. As of this morning it is still a problem here and there.
When I look at the hull with a magnifying glass (overkill) there are all sorts of dips and bubbles. So I have decided not to be anal about this and do the best I can. It is a model and I am not trying to win a contest in best paint job.
I can paint little items, but when it comes to what I do now, I get anxious.
Marcus
Good to see you back at it. Your paint job looks very good to me Marcus.
Best Regards, Ian
Marcus,
First of all, great job. Don't put yourself down.
I expect you are working with primer first. Sand it as smooth as possible, then take out the putty. The advantage of primer or paint, is you see the dips before, and after sand the hull. Smooth them out with putty. Another light sanding, and another layer of primer.Sand again ... Check again. if smooth to your liking, last layer of primer. Light sanding and you can finish it of with the colour of your dreams ...
You'll make her shine, I know you will
Cheers mate,
Carl
Marcus,
Cheers mate,
Did the primer only once and sanded it somewhat. Should have done what you suggested. More layers of primer and sanding.
So I did the painting already and I did notice the dips are disappearing. I don't want to paint to thick either. Many edges of the boat will be covered with 1x1mm dowels.
Thanks for the tip which I will use in my next boat (I have a pond Yacht - Solingen 1 waiting).
Marcus
Hoi Marcus, just caught up with your catboat build.  She's really beginning to look very nice.  Bully to you catching a few errors and correcting them.  For a fellow who hates painting you did a splendid job on her.  Your sister will be very pleased, I'm sure.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Hey Marcus, painting hulls and doing the "fill, sand, prime" thing several times gets a little monotonous but it looks like you have it cased
I have been sanding - spackling and painting. She is starting to look good. I have more than 10x thin coats on her. There are still some little depressions here and there but I am leaving it at that. I am pretty happy with the results. Planning to do a few more coats of this same color. It is a very light sand color. Could not get a darker sand color in a can. Maybe in the future I will invest in air-brush equipment but I don't do a whole lot of painting.
Good work Marcus,
the boat is beautiful !
Nils
Current builds
-Lightship Elbe 1
Completed
Here I am creating mast hoops. I use this excellent book a lot for ideas.
The metal pipe is a roller which I scavenged out of a HP printer. The paper is from a paper bag. I start by rolling the paper to form. Attach one end of the paper with a drop of CA to the metal tube. Heavily coat the paper with Elmer's white glue and slowly roll wrap the paper around the tube. Remove excess glue. Once dry, heat tube and pull the paper off.
I still have to cut it with a razor saw. Once done the book mentions to dilute CA and coat the hoop with it to strengthen it.
I use the metal tube because when I heat it, the CA glue lets the paper go. Don't know the chemistry of it, but it works.
Marcus
Looking really nice Marcus! What a simple solution for mast hoops. I'll definitely keep that in mind.
Regards, Ian
She looks good and a great idea for the hoops
I am done painting-sanding-spackling. I have also removed the tape from the windows and the walnut veneer.
Here I am prepping the boat for a rust red bottom and have marked the rudder with tape. I will first paint the rudder several coats of the same color as the rest of the boat and then the bottom of the rudder will be rust red.
I taped the rudder to the benches to keep it straight and then to be able to draw a straight paint line.
I taped a little level to a dowel which will go temporarily where the mast goes.
Having the stand level on the table and part of the stand where the keel goes into, I can move the boat up and down and keep an eye on the bubble. This is where I need to keep the boat level to draw an accurate paint line.
Marcus
