I got a little more work done on the Monte, like the chain plates, lanterns and rubbing strakes. There was a piece of thin plywood that I didn't care for the color of the wood, so I decided to paint the pieces brown. I would have rather left them natural, but it wasn't meant to be. I was a bit disappointed in OcCre's choice of wood for the Plywood though.
mike
Nice work Mike, that must have been quite the job getting the rudder on. Looks great
hahahahahaha, You are right Don, the rudder was one of the hardest things that I had to do on this ship model. Fortunately, I have done so many of them, I knew enough to know that it was going to be a little tough. So I waited about as long as I could. Getting the rudder sanded down, plated and installed along with the chain was about a 6 hour day. Now on with the masts and then the rigging. I will start with the Bow sprit. For the actual masts, I use a building board, which I mount the mast to in order to build it from the bottom to the top. I then hang a plumb bob from the ceiling of my building room where I have a hook installed that when the time comes to install the pre-made masts, I place the ship model on the floor which is perfectly flat. I then install the mast using the plumb bob as a guide to get them straight and even with each other.
mike
I have gotten the bowsprit and masts pretty much lined up after drilling out the holes with a 3/8" spade drill bit. some of the walnut dowels have a few curves in them but not as bad as a snake. I think I will be able to use them after cutting off the worst parts of the masts, which I'm glad because I wanted to be able to leave them natural wood color.
mike
Nice repair, looks like it was meant to be there
I'm continuing to go up with the mast. Here is my make shift sander that I use while making the mast and spars. I used this setup on the Victory as well since I sold most of my modeling tools several years ago when I got out of the hobby for a while. Yep, it's a Craftsman belt sander clamped upside down to my old Black and Decker workmate.
mike
I see patent pending. ;)  Necessity is the mother of invention.  Every tool is multipurpose if you stare at it enough. :D
Tom
hahahahahaha yeah and I was staring at that bugger for a while. It's not as good as my bench top 36 inch belt/disk sander was, but it does the trick in a pinch for sure. I've had that old work mate for about 40 years. It's not like the newer ones, this one weighs a ton and not that cheap metal ones they sell today.
mike
Edited by mtdoramike
I'm currently working on the chain plates. I wrap the deadeyes in brass wire and then twist it. I then slip it into the hole in the chain plate board, cut it off and then bend the end up into a hook. Then I take one of the long length eye bolts that I found some time ago at Hobby Lobby and hook it into the fashioned hook on the deadeye. I then cut eye bolt to length bend it, drill a small hole into the hull and slid the end of the eye bolt into the figure 8 fastener and then into the hull with a spot of glue. I then nail the bottom of the figure 8 fastener. It seems to give me the best and cleanest finish as far as the chain plates go.
mike
