Looks great, Kevin! I have this kit on my shelf and to do list. My wife and I are heading out to Mystic Seaport in September to check her out along with the other treasures at the museum. Well done.
Jim
Current Build: HMS Winchelsea, Model Shipways Mayflower
Completed Builds: NRG Half Hull Project
                                   Model Shipways 18th Century Armed Longboat
                                   Dumas 1954 Chris Craft 36' Commander
                                   Dumas 1940 Chris Craft 19' Barrel Back
Scuffer or scupper?
Alan O'Neill
Love the wipe on poly. Makes the planks have a finished appearance highlighting how the wood takes the poly and changes the color. Now the trunnels really become part of the visual experience. Very nice Kenny
HM Cutter Cheerful  Syren Shipmodel Scratch 1:48 scale
On Hold:
Syren by pearwill Model Shipways 1:64 scale
1776 Washington Row Galley scratch scratch from NRG plans #121  1:48 scale
Completed Build:
Erycina 1882 Fishing Trawler by Vanguard Models 1:64 scale
Charles W. Morgan by Artesania Latina circa 1988, Lowell Grand Banks Dory 1:24 scale by Model Shipways, Norwegian.Sailing Pram 1:12 scale by Model Shipways, Muscongus Bay Lobster Smack 1:24 scale by Model Shipways
Well now, you made that look easy.  :rolleyes:
Alan O'Neill
Harbor Freight 4” saw blade.
I forgot to say i purchased a 4” saw blade with a 1/2” arbor  for the Jim Byrnes saw and it works great. Its a bit noisy but i can  now make 7/8th cuts when making bulk stock.  It is a bit noisy but works great. At $5.00 how can you go wrong. In the past i used my Proxxon to do this work  but it would struggle when making large amounts of stock.
A couple guys in the MSON use old hacksaw blades to make their scrapers.
Heat it with a torch to cherry red and fast quench in water to anneal it and then file the teeth away and cut molding shapes into them.
Edited by AON
Alan O'Neill
I am doing all that Alan, its the scale that is giving me the challenge. Also on the Mill its difficult to see the depth of the cuts. Ive made some 10 scrapers so far but not happy with the results. Today i am going to see of i can hook up one of my cameras and blow it up on a monitor to get a better feel for the depth of cut. My Turbo carver is small enough to cut the curved surfaces on the hacksaw blades but my smallest files are useless.
I didn't recognize the piece to have been a hacksaw blade. Seemed much deeper than what I use but is probably just camera and scale.
Toni Levine had made a wonderful presentation on making and using scrapers at a MMS or NRMMS Club meeting. I'll check my files to see if I have anything useful from my screen captures. I believe she used a hand held dremel and metal cutting disc.
Get back to you in a couple hours.
Edited by AON
Alan O'Neill
Kevin
I emailed you five slides from Toni's PPT presentation that I saved for my personal library.
I do not have permission to post them.
Alan
Alan O'Neill
Hi Kevin. You could look into getting a set from Artesania Latina and on there site they call them Micro Shapers and comes in 3 sets, A,B,C. I have all three and get good result's when using them. At least look in to them and may save you from pulling out your hair. Good luck Gary
Edited by garyshipwright
Kevin, it is much easier to use a Dremel than the lathe.  I think your biggest problem is the disc.  It is much too thick.  Greg Herbert told me about these; their original use was in a dental lab.  They are brittle, so wear glasses when you are using them.  I can typically get three molding from each disc.
Toni
Member IPMS
                           Utrecht-1742
