17 minutes ago, popeye the sailor said:
 is there to be any type of fastenings done to those brackets?   I'm imagining the dead eyes are attached to them. ;)
Aye Aye! There is a deadeye pair attached to the top of each one, which then connects to the shrouds. On the real ship the connection was hidden in the middle of the double handrail. I thought about doing that but there is only about 3mm to work in so with a 1mm gap either side its nigh on impossible.
Chainplates and handrails now all fitted so its onto the deck. I ended up making the rifle proof conning tower out of plasticard, as I defy anyone to bend the 2mm plywood provided to the required shape without it delaminating, splitting or warping. It was then lined with 0.8x3mm stripwood.
Conning tower, compasses and main vent dry fitted to the deck
s20170531_084148.thumb.jpg.3b9a4092484a132b325ee09d08491103.jpgs20170531_084159.thumb.jpg.0731be970c2d54090d95d8d7c5d64ca2.jpg
Now fabricating the deck stairs and capstan.
I've missed this topic. The Warrior is really looking good. And if you want to get some information on some obscure detail, Wiltshire's not that far from Portsmouth (he says, as an Australian where a trip of 878 km between Melbourne and Sydney is all in a day's driving).
By the way if you want to continue the Portsmouth collection without having to build the Mary Rose (as dicussed earlier), there's always https://en.wikipedia.org/wiki/HMS_M33
Steven
Steven
Thanks Steven,
M33 may well be the pigeon. Once the Warrior is finished we shall see.
Best,
Philip
Forward bridge complete and fitted. This is a time consuming and fiddly job to say the least! The decoration that runs around the bridge edge is made by twisting three strands of 1 mm brass wire together then hammering them flat on an anvil block. The handrail is 2 mm brass wire hammered flat.  These were then bent into shape using a forming template. Billing's instruction for the edge decoration was to use rigging thread - yuk!
  • 9 months later...
HMS Warrior: Am just finding out (I am a Cypriot) that her sister ship (were two identicsl ships,  both  build and lunched as ironclad class ships between 1859-1861) HMS Black Prince, with his captain, then the Duke of Edinburg, was one of the ships that came to Cyprus, when back in 1878, the British Empire was to take over Cyprus from the Ottoman Empire. It was a squad of 7 or 8 ships coming from Suda bay (Crete Greece) under Vice Admiral Lord John Hay and his flagship HMS Minotaur.*
Not as HMS Warrior,  Black Prince was twice renamed after 1901 and finaly sold as scrap in1923.**
* Sir G.Hill’s book: “A History of Cyprus” Vol III. Cambridge 1952
**other sources
Edited by MESSIS
  • 9 months later...
Glacial or not, you have still achieved some significant progress and it is looking very good.
cheers
Pat
wow!  some really nice progress since I last looked in :)    she looks awesome!   this one is on my list.........once I can afford her ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hello Phil, Just found your build. I have always been a fan of Warrior ever since I  first visited her about 20 years or so ago. I have visited many times since. I will be pleased to follow as you complete your build.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
the one thing I see is that the dead eye attached to the top,  isn't captured on both sides.  when the shroud line is rigged,  it may pull to one side and might offset the looks of the assembly.  running the fotock line though the hole,  capturing the dead eye,  and running it back though the same hole,  would do the job better I think.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 1 year later...
did this build continue?
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Not that I can see, Kevin.  His last visit to MSW was shortly after his last post.
  • 2 years later...
Visited the Warrior in Portsmouth about a couple of years before covid hit.    What an impressive ship!   Also William Mowll's fantastic model in the reception area.
This model that Phil is building will be a cracking good model from what I have seen of it so far.  Looks enormous!
Might be on the cards as a build sometime in the future if only I could find a kit in 200th scale! I have heard of another company named Constructo making a kit of Warrior to check out the scale of.
The only other Warrior kit I have heard of is a small resin waterline kit.
The CSS Alabama also appeals but the Bluejacket one is 1/96th scale, so again an enormous model! I think that the Mamoli 1/120th scale one is not much smaller either.
Looking at Andrew Bowcock's 1/192nd scale drawings in his book seems a nice size to make a model in. Not too big and not too small so that it can be fully detailed.
Edited by NoelSmith
