Hi Alex,
guess the technique you are using for the hull made in CNC milled sections and then fitted together is like the professionals do for "builders models", or for the watertank drag test hulls...... ;)
The models look fantastic !!
Nils
Yes, it really looks like ... But on a fantastic result too early to speak. While all invented goes according to plan (no more). Let's hope and try to get an excellent result. I'd like to ...
Hi Alex - Fabulous subject and very nice CAD work especially like the Hotchkiss. I look forward to following you on your high tech journey  Cheers Pete
Your hulls are huge! That was a great idea to use that milling machine. Your hulls look great!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Alex,
good metal work on fitting of prop tubes, anchorchain tubes and sleeves for stand spindles....
Nils
Current builds
-Lightship Elbe 1
Completed
 Nils
I found a very good brass pipes in the network. different diameters, good brass (LS 63) of the pipe body thickness of 1 mm. These pipes will be very necessary for the manufacture of ventilation ducts and other parts. He spent almost 200 euros. However, I had to buy three times more than necessary. Diller sells pipe only 3 meters long! I had to buy more than is necessary.
Edited by AlexBaranov
Alex,
you`re right, thats a very costy solution, Are there no Hobby shops in the near surroundings where you live ?
Are you able to buy from German web-shops for receiving through the postway ? If you wish I can give you some links for the web-shops I use.....
Nils
Current builds
-Lightship Elbe 1
Completed
Alex - a really fascinating build that I have been following silently for a while. I look forward to future posts.
In terms of tubing this link may be of interest...... http://www.cornwallmodelboats.co.uk/acatalog/Assorted_Selections.html
I'm not sure they ship to your part of the world but they do seem to send to most countries. Their assorted metal tubes come in handy for making a lot of fittings.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
  • 2 months later...
Excellent work Alex.
Michael
