Patrick,
Just catching up - great work - your swivel guns are brilliant indeed.....
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Thanks for the nice comments.
Finishing the anchors.  With the anchors of the Mary Rose as an example.
The stock is always slightly shorter than the anchor
The stock has been sanded to the correct shape. And there is a combination of tree nails and bolts
make the rings.
This is not soldered, the risk of melting plastic is too great. The rings are wrapped with black thread
20221220_134341.thumb.jpg.91fce877a672e58a23fe7f417f848098.jpg20221220_134822.thumb.jpg.d5bae887e45fe6b4a5316979a12ab1c4.jpg20221220_164537.thumb.jpg.f9930c6938ae54d536b170481ba5edff.jpg
Painted.
the wood is collored with thinned light grey and polished.
The metal (plastic) is first painted in black, then a wash met thinned metal paint. And last a wash with rust color
20221222_184324.thumb.jpg.b0726d5132bc25a49e7b701cd40598da.jpg20221222_184419.thumb.jpg.c6fd7d66a66ca0ffa9830de0817f7b64.jpg20221222_184512.thumb.jpg.3b8652dafe3e485adde03eb158df62a5.jpg20221222_184526.thumb.jpg.d4cf4eed733c75b07146f5a102a11dec.jpg
And, finally decided.
The next project will be the Mary Rose scale 1/48
20221217_170059.thumb.jpg.3be6ca80c50f48fcf8a8b368975720ca.jpg20221217_170152.thumb.jpg.ce7dff9ff12873538840b136fbc4120e.jpg
Thanks for following
First, a happy 2023 for everyone.
The anchor cable.
I made this about 2 years ago.
https://modelshipworld.com/topic/14188-pelican-later-renamed-as-golden-hind-by-baker-scale-145-galleon-late-16th-century/?do=findComment&comment=787113
Lesson learned. Never treat a rope with diluted PVA glue before using it, as the rope will become stiff and unmanageable. But,too late to change now.
The anchors are in place and secured to the cable as best as possible.
20221230_093049.thumb.jpg.c7294e707d54fe2c7b29a7d311b2b204.jpg20221230_123802.thumb.jpg.a1df733a147a862e9cdeafb315f00538.jpg20230101_110117.thumb.jpg.eed91124c2315fa045d2c5d04254e7da.jpg20230101_110202.thumb.jpg.4c3ede276f61c44cec85429e9d447f77.jpg20230101_110222.thumb.jpg.f3cb19e3b74398f83b3cbe2b090d3e14.jpg
The anchor David is on deck. The crew still has to store it in the hold (after the New Year's party 😉)
20221226_130359.thumb.jpg.ad6a233cd74b1b16301e502b57fe603e.jpg20221230_125702.thumb.jpg.cde81e24a7bb7abb89ebfbe371d0fa42.jpg20221230_125710.thumb.jpg.750c4b0eba887ce1085f5280efd1c4ff.jpg
next flags (still experimenting for now)
5 hours ago, Roger Pellett said:
Patrick,  a really wonderful model!!
thank you very much Roger.
The only thing that bothers me is that anchor cable. the size and shape really don't seem ok to me.
Fascinating work Patrick,  I have  been over  one of the  replica's   at  Brixham  UK   -   its  a  loverly  little  ship.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Thanks  OC.
The anchor cable :  part 2. or better, plan B
Looking in my Mary Rose books I found this.
Thinner cables are ok 👍
And ... Cotton rope of a reasonably correct diameter
20230102_140405.thumb.jpg.e127cee982aed58b7245071e2419b2ac.jpg20230102_140409.thumb.jpg.8a19a00b6f1b2d605c2dcf05ffe2b318.jpg
This flexible thinner rope gives me the opportunity to do this way of tying
Testing. Still needs to be treated and wheatered.
Looks better to me.
Anchor cables, 2nd edition
The old anchor cables have been cut off and hidden in the hole.
The 2nd edition looks better than the first to me.
20230107_113727.thumb.jpg.4e3ae2bef7d87e7b3006741184c08fd8.jpg20230107_113833.thumb.jpg.e43f711d0cee3efa5de3e2dea78a4353.jpg20230107_113802.thumb.jpg.bc5e905b9ac9720767203613f80df30c.jpg
2 anchor buoys have been made.
Like the other anchor accessories, they still have to be stored in the hold.
20230103_182924.thumb.jpg.94c65243dd7a78b3e59297dff12ef600.jpg20230105_185004.thumb.jpg.c10b5daf08337e5241fcd689c10ffeb0.jpg20230105_185605.thumb.jpg.d4b53bc1915f028572aed9b8772a8a45.jpg20230107_113649.thumb.jpg.7935256f30f834497a62bc7afcbee172.jpg
The flags
First some research, the "what did they look like and where to place them"
Design.
The only things I can handle a bit on a computer are Word and Excell. So I made design in excell.
These are printed on the printer at work. I can print them there at in one time with front and back.
The alignment took a while (paper, ink and labor at the boss's expense 😇.) It is a pity that this printer only accepts paper.
This excel file will be posted next week at work
flags, further experiments.
Based on a great idea from 72Nova  (post 164)
Today I managed to attach tissue paper to plain paper and print it on the work printer.
Flags can be printed on the front and back of the (standard) printing paper.
Or just on one side to be glued together.
Excel is free to use
vlaggen.xlsx
@72Nova  Thanks for the idea
Edited by Baker
Patrick your work is always so inspiring 😊
Cheers as always
Michael
Under the table:
Completed:
Vasa-Corel -
Thanks for likes and comments.
Flags
At first sight a successful experiment :dancetl6:
the tissue paper is taped to the standard printing paper. And came out of the printer without getting stuck.
The tissue has been cut loose
the flags are glued together and somewhat wrinkled.
after drying overnight.
Now attach these to the masts.
I'm going to follow this method, it's the most common.
from the book "Prins Willem" of Herman Ketting.
And this man probably knew more about ships than I do.
Edited by Baker
Hi Patrick, huge congratulations!
The model is wonderful, but just as good is your ability to finish a very long, arduous build. Have you noticed that, for some reason, it is only sailing ship models that are suitable for beautifying prestigious spaces like living rooms in houses or halls in residences?
You said another one was the Mary Rose...?
Thanks,
My co-worker has started his next project.
But he is also looking further ahead...
Edited by Baker
The finished model.
Thanks to everyone for the following, likes and positive comments throughout this long build
This was my first time building a ship model from scratch.
It was fun, and worth repeating.
20230116_130237.thumb.jpg.872b55e9c25fbc3a59dcb74af9935c04.jpg20230116_130309.thumb.jpg.444936b7ac223cd1a7ed97960d7dc4a4.jpg20230116_130342.thumb.jpg.b36544c26e656a5bf5c3bb8bce171fc2.jpg20230116_130408.thumb.jpg.d61e5ef4c76e4827d2f170bfbe186801.jpg20230116_130433.thumb.jpg.61799c216321284af5e517eb886b3bd8.jpg20230116_130500.thumb.jpg.d390de8482aafa6d19f2786f72c5c187.jpg
  Outstanding !  Your build log will be a real help for anyone doing a ship of this type  ... very inspirational !
thank you very much
Patrick,
I remember several years ago when you began this model and were shaping the hull with an angle grinder thinking,  “This isn’t going to turn out well!”🤣  Was I ever wrong.  Your skill, perseverance, and intellectual curiosity has produced a beautiful and historically plausible model.  Well done!
 I have enjoyed following your progress and am looking forward to Mary Rose.
Roger
1 minute ago, Roger Pellett said:
Patrick,
Roger
Thank you very much.
And yes, the trick with the angle grinder was indeed  a little scary for me too 😇😉
27 minutes ago, Jeff T said:
Congratulations!   Your model is absolutely beautiful!
Thank you 👍
Patrick,
SO enjoyed and I learned following this log. Big congratulations indeed.
Cheers,
Michael
Under the table:
Completed:
Vasa-Corel -
Superbly done Patrick,  watching this build come to fruition was very enjoyable and educating, thanks.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
