The gun mounts look good. No headaches working on them is a good thing. I ran into that some years back, building double hung windows for some houses in N scale (1/160). The magnifying visor works a charm.
Ken
Started: MS Bounty Longboat,
I have one of those opti-visors.........have never used it.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Lemme tell ya popeye ... if you ever goin' to do sumthin' with small brass part'cles ... you'd better put them on mate ...
Carl
I think that's one of the hardest things you'll have to do Cog, whilst I could see it, alignment at that size is a nightmare. Then you have to tap every assembly to make sure it's stuck down properly.
Greg
22 more chances to get it right Greg. When I look at it without macro, it seems alright. When you get in close (macro/magnifier) suddenly it doesn't look that well anymore. The main problems are the delicacy of the material and the size (glad I'm not at 1/700) The first requires careful manipulation (bending it the wrong way initially makes you end up with a broken part - been there, done that), the latter making it hard to handle. I have to bend a 7mm long 3mm wide piece lengthwise ... doesn't leave much room for pliers/tweezers ... a whole new experience I might add
How on earth can you tap any assembly at that size ...?
Carl
Just gently tap on the bit you have glued down with the tweezer head, if it falls off then it will fall off late and you'll lose the piece. I find about 10% of all assemblies do this as the glue has not been put on correctly. Better to fix it then than when it's on the model.
Greg
Hello Buck,
Welcome aboard! You could send that firy overseer to have her get some experience with the bling, bling. Good on her resume ;)
Carl
Not much done last week. Have done the base of the 25mm AA guns. Hope to finish the gun parts this weekend ...
repetitive work ... hardly!
got some more tweezers and pliers
Carl
Ever so right Sam. For the gun one piece alone has 12 bends folds to it :wacko: two others  four, and one more three two ... hope to get them done without loosing any. Even a carpet monster won't be able to find them ... Besides that, if I overbend and correct it breaks ... no extra's so I'll be in dire straights so to speak ... No beverages but coffee with these parts!!!!!
Cheers
Edited by cog
Carl
Greg,
I thought you would have some fabulous solution ... bummer ... I found one in my keyboard though!
Got another bummer: Yesterday evening (no bottle isn't empty), I bent a piece a bit to far, and had to correct it ... now it's two parts instead of one ... Will have to try CA but doubt if I can manage it, ordered some spare parts to. At this size they should, at least for the small items, add some spares ... No pictures yet, still not ready. It feels like one of Hercules' challenges!
Cheers
Edited by cog
Carl
Thanks for the tip, Greg. In this case I'm hard pressed to cut even that to size ... I will have a go at it though
Cheers
Carl
:) ... now I need to find a supplier, preferably Dutch. Thanks, Greg, yet again. You are my brass guru!
Carl
Greg, Carl would 'powder' and thin CA along the joint for reinforcing also work?  I know Rocket make this stuff but I have heard that using talc would also work?  The card modellers use this technique a lot I believe?
cheers
Pat
Greg,
Not included
Right, it's the material of the kit's plastic parts itself ... should have known it was that easy!!! Found the description of it on a British site, and how to use it (http://www.aeroscale.co.uk/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=146894&page=1)
Let's blame it on the language barrier ... (or that I'm simply stupid)
Edited by cog
Carl
Pat,
Sounds interesting. Where could I find an example?
Cheers
Carl
Hi Carl,
There are a few discussions about the use of Talc and baking soda/powder with thin, and with "old' CA as a filler and/or strengthener, but also as a backing in crevices to support small pieces etc.  See http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/13/t/90424.aspx  or http://www.tested.com/art/makers/573280-shop-tips-mixing-superglue-and-baby-powder/  or  http://www.whatifmodellers.com/index.php?topic=33125.0
Note in the latter discussion it states that once sprinkling the powder over the CA, let it set but to sand it sooner rather than later as it sets very very hard.
This is an example of the commercial product (no associations nor have I used it yet - just aware of it).  i do not know if it works better or not than baking soda  https://www.deluxematerials.co.uk/en/rc-modelling/30-roket-powder-5060243900159.html
cheers
Pat
Edited by BANYAN
Greg,
The stretch sprue worked, still, hard enough on this scale, but doable. Today I added the barrels, and the amo thing. Tomorrow the last bit: Straps or harnesses ... a mere 22 to go. After that the twin 13 mm guns ... I keep on saying: Brass is fun, brass is fun, brass is fun, brass is fun ... ;) Why on earth did those Japanese engineers have to install so many small guns ...
Edited by cog
Carl
Probably something to do with our American friends trying to sink them. I can't imagine the courage of those young men who flew into its teeth. Glad it worked for you. May I suggest you tackle something else to rest your temper? I'm still trying to get consistent paint flow for my panel lines.
Greg
Could it be related to the marksmanship of the ship's gunners ?  You know if you put enough lead into the air you are bound to hit something sometime. :D :D That's how the US Navy's new Phalanx system works against incoming missiles.
Jack
Current buildUS Constellation
