Masts are done -- now on to the yards.
Regards,
David
David Robinson
Boston, MA area
Completed:  Constructo J.S. Elcano, Artesinia Latina Sanson, Dumas Mt. Washington, Bluejacket Nantucket, Amati Revenge, Artesania Latina  King of the Mississippi,
Amati Grand Banks Heritage 46, Amati HMS Fly, Amati Titanic, Dumas Chris Craft Commuter, Mantua Cutty Sark, Mantua Bruma, Kolderstok Batavia, Vanguard Models HM Cutter Alert, Caldercraft HMS Victory, Dumas USCG Fast Response Cutter, Amati Bismarck, Occre Jupiter Locomotive, Caldercraft Brannaren
Currently Building:  Mantua/Panart Amerigo Verspucci
First yard done and mounted -- lower main yard.
I hadn't run into stunsail booms before, but really like the interest they add to the yards.
I know that some modelers pin the yards to the mast, but I'm always concerned that I will "prang" them during rigging with a random elbow or hand strike (and have done so many times), so I installed a pin on the back of the mast and "hung" the yard to that, which supports it but still allows for play in the yard.  This one is lashed to the mast, but the next one above it will be installed with parrel beads and ribs.
One yard down -- 9 more to go.
Regards,
David
David Robinson
Boston, MA area
I guess maybe 2-3 hours per day when I don't have a lot of my professional work to get to.  I spent more time yesterday on the main yard -- maybe 4 hours in all.
Each part is an engineering challenge for me.  I look at the drawings and think about how I'll build it, and part of that is the "what is the most efficient way?"
Here's the catch:  if you zoom way in on my woodworking, you'll see that it doesn't stand up to some of the really outstanding detail work I've seen here -- such as by Zappto, Vossy and AntonyUK.  I think it's fine, and looks good on the model for normal viewing -- but I just don't have the patience that I've seen some others apply -- and their results show it.
Regards,
David
David Robinson
Boston, MA area
you have a far more elaborate and technical build than I have david
its more than fine my friend
its stunning!
cheers
chris
I have finished the 3 main mast yards and mounted them on the main mast, then stepped the mast to the boat.  Picture below.
When I started this kit, I wondered if the upgrade kit would prove worth it (other than the lifeboat kit it contains).  But there are three brass fittings in it that have proven to be really valuable:
  • The deadeye fittings are upgraded and are more secure.
  • The footrope stanchions replace having to fabricate them out of thin wire, and are better looking than anything I could have created myself in the non-upgraded kit
  • The fittings for the stunsail booms again avoid having to fabricate two fittings per yard end (4 per yard) out of separate parts.
Regards,
David
David Robinson
Boston, MA area
All the yards are now up.  I also mounted the driver boom and driver gaff, even though they don't have rigging support, because I think it would be much more difficult with the shrouds up.
A kit note:  not enough parrell beads supplied.  Fortunately, I had some left over from the Revenge.
Now on to shrouds -- which I'll be at for a while.
Regards,
David
David Robinson
Boston, MA area
The shrouds will be the traditional black.
Regards,
David
David Robinson
Boston, MA area
It's been a bit since my last post, partly because I was away last week, but also because I have hit the shrouds and ratlines -- and you all know what that's like.  Never ends.
Here's my first stage of those -- the lower foremast shrouds and futtock shrouds.
Regards,
David
David Robinson
Boston, MA area
Looking good, David.
Doug
Completed:
HM Brig Supply - JoKita / Caldercraft 1:64
HMS Fly - Caldercraft 1:64
HMS Sherborne - Caldercraft 1:64
HM Brig Flirt - Vanguard 1:64
Saucy Jack - Vanguard 1:64
Continuing to work on shrouds.  When I did the foremast shrouds, I followed the approach noted in the drawings (see below), which is certainly structurally sound and is probably how shrouds were "hung" off the mast on the real ship.
The issue I had was twofold:  alignment of the deadeyes when fixing the second deadeye in the loop, and more important, creating the proper alignment and spacing at the top.  I really had to struggle to get separation and not have the shrouds cross approaching the top of the lower foremast, and the alignment I had on the foremast was marginally OK, but not what I really wanted.
So for the main mast I went back to the approach I used on the Revenge, which is to rig the shrouds one at a time, fixing the alignment and tensioning at the top with CA gel.  I'm much happier with the results.  See below, including two pics with white paper behind the shrouds so the alignment up to the mast is easier to see.
Regards,
David
David Robinson
Boston, MA area
Lower main mast shrouds and ratlines now done.
Regards,
David
David Robinson
Boston, MA area
I haven't posted in a while, because I have been traveling and also busy with some business.  But this week I was able to do the mizzen lower shrouds and finish off the lower shrouds, futtock shrouds and ratlines, so here's a picture of that.
Regards,
David
David Robinson
Boston, MA area
All shrouds are now up.   😂  I think I've been seeing ratlines in my sleep.
Now on to other rigging, in between some business trips coming up this week and next.
Regards,
David
David Robinson
Boston, MA area
Foremast crow's foot rigging is up.  As I was snipping the last loose piece of crow's foot, I managed to commit the ultimate rigging sin and snip the crow's foot too.    😫  All of the "feet" are one long continuous line.
So I spliced the last lead and saved it.  You can see the splice if you zoom in on the second picture and look at the leftmost "foot".  But it's hard to see with the naked eye, so all's well that ends well.
Regards,
David
David Robinson
Boston, MA area
Now all 3 crows feet are up -- hard to see in this pic.
Regards,
David
David Robinson
Boston, MA area
All the stays are now up.  Some run close to the mast and shrouds so you have to look for them.
Regards,
David
David Robinson
Boston, MA area
Chris:
Thanks very much.  Yes, I do have the next build planned.  I'm going to do the Amati Titanic, which I have on the shelf waiting.
Regards,
David
David Robinson
Boston, MA area
David thats a fine build! Great work there. And she is a beauty... oh yes!
Christos
ps. very impressive indeed  the diferent  wood colour grades of the hull (among all the others)
Edited by MESSIS
The yard lifts are now up, so from here on to the final stage of rigging, then mounting & done.
Regards,
David
David Robinson
Boston, MA area
FLY IS COMPLETED.
I finished the H.M.S. Fly today -- competed pics are in the Completed Kits Gallery.  Just a couple of samples here.
I wanted to see what the lifeboat from the upgrade would look like, so I built it and liked it, so installed it on the ship.  I made some mods to it, including using real wood planks down the side at the gunwales, vs. paint.
A couple of kit build notes from my most recent work:
  1. I added some fine thread braces to the stays the crow's feet are attached to, to keep the crow's feet tight.  Important as the stays are pulled up by the rigging and need some counter-balance.
  2. I ran out of 3mm and 5mm blocks, and 3mm deadeyes.  Fortunately, I had leftovers (plenty) from the Amati Revenge kit, so I was OK, but a caution to other builders.  I didn't lose more than 2-3 of each on the floor.
Now a break from kit building while my wife and I go on a Greek Islands cruise.  When I return in late September, I'm going to tackle the Amati Titanic, and I'll create a detailed build log for that as I don't see much on this site.
Regards, and Happy Labor Day to the Americans,
David
David Robinson
Boston, MA area
Very nicely done, David! It's an inspiration to those of us whose own partially-completed HMS Fly builds are gathering dust in a display cabinet. I'm not admitting that this something that I have actually done. Okay, yes -- yes I am. 🙄
Cheers!
