It is certainly coming along Patrick, no easy task capturing the very many curves and recesses!
You are gluing plastic, paper, styrene and wood together and some times the contact area is tiny, is it CA glue you are using?
Vaddoc
Vaddoc
Hi Vaddoc
Yes. CA glue is what I use almost exclusively, because it’s quick drying and non-messy.
Do you you have an alternative idea?
 Thanks
Patrick
Not really Patrick. For some reason CA never worked for me so bonding dissimilar material is a headache. I sometimes use epoxy as good surface mating is not essential but it is messy and does not work very well. I have a feeling I ve been using the wrong CA glue, too fluid and too cheap!
I think next I ll try a combination of gell CA with an activator to set it in seconds. I need to remember not to scratch my eyelids when gluing...😀
Vaddoc,
There are quite a few brands on the market, I like BSI insta-cure (fast) and insta-cure+, which is slightly thicker, they also have a gell. Most use Zap or Zap A Gap. Both brands can be get in the UK (I order mine in the UK as well) You'd probably are best off with either Zap-A-Gap or BSI insta-cure+ for what you need it for, though they dry somewhat slower than the other two, they fill in the irregularities.
HTH
Cheers
Edited by cog
Carl
2 hours ago, cog said:
Vaddoc,
There are quite a few brands on the market, I like BSI insta-cure (fast) and insta-cure+, which isslightly thicker, they also have a gell. Most use Zap or Zap A Gap. Both brands can be get in the UK (I order mine in the UK as well) You'd probably are best off with either Zap-A-Gap or BSI insta-cure+ for what you need it for, though they dry somewhat slower than the other two, the fill in the irregularities.
HTH
Cheers
Hi Vaddock and Carl
Thanks for the advice and comments.
I tend to use two types for my boats. The first is the Gel type, which is perfect for quick jobs as it’s thick, has a longer drying time and allows for final adjustments to be made.
The second type is the runny Zap A, which I use exclusively for flooding and saturating the wood, or cardboard; thereby making the surface super strong. Perfect for my teeny tiny work.
Cheers
Patrick
you've made some really nice progress since I last checked in Patrick.  the comparison shots with the pictures are especially nice........the resemblance to the actual vessel is uncanny!  looking really super!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Many thanks, Denis.
I gotta admit, building this hull and superstructure has been one heck of a challenge...but, what’s life without a few challenges here and there?
Have a great weekend.
Cheers.
Patrick
Hi folks!
Thanks for all the positive reactions and comments to Genesis’ construction journey so far.  Much appreciated as always!
This latest update shows that I’ve been adding more detail to the large settees on the aft main deck, as well as bit more furniture on the aft of the Sun Deck.
Also, as a homage to the real ship that Genesis is based upon, Khalilah, I’ve added gold card to the main deck house and other assorted areas of the superstructure, in order to bring some contrast to the black superstructure.
I hope you enjoy these photos.
Have a great weekend!
Cheers.
Patrick
ohhhhh.....so now your throwing PE into your projects.........well played orange!  ;)   very nice progress since I last looked in...........look'in my-t-fine!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Denis
Many thanks!  Much appreciated.
Not quite PE, though...just some gold card stock which really looks the part.
All the best.
Cheers.
Patrick
Catching up a bit Patrick, my goodness you are able to pack a lot of detail into these small boats. The style of this one isn't really my cup of tea but you are doing a fantastic job of a very complicated yacht.
Michael
On 11/8/2018 at 8:30 AM, canoe21 said:
Hello Patrick
Well, I have finally crawled out of my little corner the Old Ship Yard and started to look around the MSW Form. You never fail to amaze me with your very fine detail along with all of those great ideas that you are adding to your Genesis, seeming so effortless. Great job as she sure is looking supper, ENJOY.                                                            Regards   Lawrence
Hi Lawrence!  Thanks for the mighty fine compliments.  Greatly appreciated.  I got to admit that I’ve been a bit absent lately on MSW.  Work is getting in the way and I’ve just been too tired to get on and look at everyone’s logs, yours included.  Hopefully, that change one day soon.
Michael
Hi “Michael.  Thanks for dropping by.  Great to hear from you!  I understand exactly what you mean about the design of this boat ‘not being your ‘cup of tea’.  To be honest, it wasn’t my cup of tea either until about six months ago when I started this boat.  Having said that, this is a design that challenges one’s perception of beauty and is about as challenging to build as one can imagine.  Needless to say, once I got started, it has really captured my imagination.
On 11/9/2018 at 7:16 AM, flying_dutchman2 said:
To the King of Itty bitty scale:
Impressive, a fine job of putting it all together and the curves on that ship are cool.
Marcus
Thanks Marcus!!!  I gotta admit that I kinda like that title...”King of Itty Bitty Scale’...hehehe.  Not quite sure that I deserve it though.  Thanks also about your comment about the ‘curves on the ship’.  I definitely agree, as well.  This is a design which is both challenging and thought provoking at the same time.  It certainly is a captivating design.
Have a great weekend, everyone!
Cheers.
Patrick
Hi Patrick,
with all those cool curves she`s  coming along very nicely, hope you never loose the orientation with all those lines.....😉
Nils
Current builds
-Lightship Elbe 1
Completed
12 minutes ago, Mirabell61 said:
Hi Patrick,
Nils
Hi Nils
Thanks!  ...with all those cool curves....Nils, I can’t tell you how many times I’ve lost track of them so far.  Sometimes this design really ‘does my head in!’  It’s certainly challenging, that’s for sure.
Cheers
Patrick
Hi everyone!
Genesis is looking a bit more grown-up, especially now that I’ve managed to temporarily fit her radar domes and main antenna. I reckon they don’t look too bad.
I’ve also been playing a lot with Genesis’ interior accommodations, particularly her lower deck.
While overall, progress has been slow, at least she’s getting there.
Cheers.
Patrick
Edited by Omega1234
That does resemble something like a Star Destroyer from Star Wars.  I wonder if that was the intention or influence?  Nice work all around her, Patrick.
Hi Mark - you know...I wondered that very question, as well.  Very futuristic and very ‘Star Wars’ inspired, indeed.  Thanks for looking in!
40 minutes ago, cog said:
As Mark wrote, it is becoming quite futuristic ... very nice lines that way ... good to see you back at her
Hi Carl.  Thanks!  It’s certainly great to be back working on Genesis, as well.  I agree that her lines are, indeed, futuristic.  I mean, just think how talented the guys at Palmer and Johnson must be to have designed her in the first place.  Quite the imaginative talent, that’s for sure!
Thanks guys!
Cheers.
Patrick
she's look'in really sweet Patrick.........quite a maze you'v got going on.    you've probably heard this question before.......have you though about adding figures to your projects?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Denis
Many thanks.  I’ve been tempted to add figures, but I’ve always been scared that they’d turn out to be ridiculous looking blobs of nothing...such is my ability to do such things!
Oh well...
Cheers.
Patrick
Hi folks
Thanks for all of your Likes and Comments.  Much appreciated!
A quick update and close-up photos of Genesis’ main saloon.  Principally, she now sports a cocktail bar (port side) and writing desk (starboard side).  Furthermore, a large white sofa has been added to her eclectic selection of furnishings.
I’ve also included a few photos of the Owner’s suite, which has a large king sized bed as well as other assorted furnishings.
Have a great week!
Cheers
Patrick
That's actually a giant hand, right?   So much detail in such a tiny space.. unbelievable.
Nice work Patrick, she looks fabulous!  Even though we know it is a 'micro' build, it is not until you show her in your 'giant' hand :) that we can visualize just how small these furnishings (and the model) are.
cheers
Pat
cheers
Pat
Thanks Mark and Pat
I’m not admitting to having a giant hand at all....even though they come in very handy sometimes 😂😂😂
Thanks!
Cheers
Patrick
