Screw
Edited by Ilhan Gokcay
What I most appreciate in your modeling technique is that everything is shaping up with a saw, a drill bit, some sandpapers, needles and a few glue drops... No advanced machinery... And impeccable result...
Best Regards…
Ferit KUTLU
Under construction: Frigate Berlin (Brandenburg Navy)
Hope: Frigate Wappen Von Hamburg (Brandenburg Navy)
Hi Ferit Kutlu, thanks.
That's because I'm building in a room/lounge at home.
Actually I would like to have a small milling machine and a lathe but they are not an absolute must.
Lovely work Ilhan.
Michael
Agree with Michael, a beautiful slim model,
very nice work Ilhan, The built 4-blade prop also looks great....
Nils
Current builds
-Lightship Elbe 1
Completed
Wonderful work......
Rob
Current build:
Finished build:
Current build(On hold):
  • 1 year later...
Housings for the ventilators (brass tube) and channels (0.5 mm brass).
I glued the keel, 1 mm acrylic sheet.
Beautiful work, Ilhan. The model is looking great. As you are so good working in brass, I wonder why you used acrylic for the stern post. Will it be strong enough?
Thanks Druxey.  No its not, it breaks easily at a strong hit. But I found it easy to let it cut by laser rather than cutting myself a 1 mm thick brass. I can cut brass but I overestimated cutting a big part of 1 mm brass. It's okey when I take care.  Even after a few breaks. 😉
Bulwark is two layers of 0,5 mm ply glued at site on a mould.
Second layer of 0.5 plywood bulwark.
