HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Thanks Jeff, Steve, Ben, Joe and all the likes. Really having a lot of fun with this one!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
I've started marking off the hull for the nails. With the planks being only 1/32" thick I could put a light on the inboard side and see where the frames are.
Here is the start of the monofilament being placed in the holes after dipped in glue. A single edged razor is used to cut them off after the glue has dried.
I then sanded the nubs with 320 grit sandpaper and applied a coat of wipe on poly.
Here the starboard side has been completed.
Rusty
In your glory I would imagine Rusty! Outstanding work. How did you maintain any semblance of placement of the holes even with the ribs back illuminated?
Joe
That looks like some awesome work Rusty.  I hope mine turns out something close to that.....   😄
How many times did you go thru that 1/32 planking?  That's one of the things I'm worried about when I get to that point.
Keep up the good work..
Till next time.....     😎
Steve
Finished:              Artesania Latina Constellation;   Model Shipways USF Confederacy:  Medway Longboat 1742 - Syren Ship Model Company
Current Build:     Syren's Winchelsea
Awesome. Great work. A bright light shining through the hull and not a hint of any light shining through a seam in any plank. Ive got a long way to go to reach  such a level of craftsmanship.
Rich
Member - Ship Model Society of New Jersey
Current Build:  Pride of Baltimore 2
Finished: Kate Cory
Finished for now (Not rigged):  Medway Longboat
Thanks Joe,
With the light shining I would mark each frame. Once they were all marked I would go back and adjust any mark that was out of line.
Thanks for the kind words Steve. The area that was the most problematic was where the butt joints meet on a single frame. Fortunately if I did drill through the plank and miss a frame most were under the floorboards or seats. If I did go through and I thought it might be seen I pulled the monofilament back flush, sanded off any chips and put a tiny spot of paint on the monofilament making is very hard to see.
Hi Rich. I wish I could say that the entire hull was free of any light shining through. I still need to get better.
I got distracted from doing the hull and switched to the floorboards and platforms for a minor diversion.
Well that's all the fun for today. It's off to the family gathering now.
Rusty
The diversion to the floorboards continues.
The large boards seen in the last post were one piece each. The center board and two outside boards have a rabbet along their edges.
They were glued together with a rabbet on both sides. The outside planks of the floorboards only have a rabbet on one side so the
inboard side needed to be sanded down to fit.
I'm back at the rest of the nailing and should be done soon.
Rusty
Awesome stuff Rusty.   Keep it up.  I can't get back at the build till February.  At the rate you are going you will be almost done by then.
You set some nice lofty goals for us to keep with...
Keep up the great work!!!
Steve
Rusty awesome work. What part of the instructions has the floor board installation?
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Thanks Steve. I'm lucky to have Christmas to New Years off so I'm taking advantage of it.
Thanks Jim. I'm ahead of the instructions and I'm using the plans and Chucks build log for guidance.
Edited by Rustyj
Rusty
The hull has now been completed, sanded with 320 grit sandpaper and a light coat of wipe on poly applied.
I have also added the outermost floorboards.
Rusty
Thanks Jeff and for all the likes!
Rusty
Thanks Chuck, Just heat, bend, check and repeat as necessary. Works like a charm.
The platforms were sanded and notches for the frames cut. This required many test fits until I got a fit I was happy with.
The risers have been sanded, nails applied and a light coat of poly added.
To place these I used the same method from the barge model.
A T square was made from scrap and the height was taken from the plans and transferred to each frame.
Rusty
This was a test fit of the risers prior to marking off the bolt locations.
The starboard side installed.
You can also see the completed thwarts above. They were assembled from two pieces to again give a nice uniformed rabbett.
Here they are before being removed from the sheets.
And the thwarts sanded to fit but not yet glued in place.
Rusty
Thanks Joe also thanks for all the likes!
Rusty
The mast thwart iron work has been completed. Supplied 1/16" x .025 brass strip was used to make the
three straps needed to hold the mast. I bent the two straps around scrape wood the same thickness as
the thwart. Holes were drilled with a #74 drill bit. The last iron strap was bent around a 3/8" dia. drill bit.
All the thwarts have now been glued in place. Next I did the seats in the cockpit.  The seats are laser cut in two layers just like the thwarts.
The sides needed to have notches sanded in them for the frames just like the floor platforms. I got carried away and forgot to take pictures
of that. Here is the finished result with many, many, did I say many coats of paint.
Rusty
The windlass, supports and bars have been completed and are now in place. I used a x-acto blade and files to complete the bevels.
The ends were trimmed and then sanded to shape. A little at a time to keep them equal and a good snug fit.
Rusty
Thanks Jim, Also thanks for all the likes!
Rusty
The six knees have been sanded, painted and placed. The two fore knees have
some sharp angles and thankfully Chuck supplies extras! Also the belaying pins
where shaped and placed in the thwart.
I'm on to the rudder, grappling hooks and thole pins!
Rusty
Rusty be VERY careful working around the rudder after it is installed. I broke mine off twice. Finally I just removed it and set it aside. I will reinstall AFTER it is on it’s stand. Your build looks outstanding. You might want to install your horse back aft at the same time as your rudder, don’t forget the block.....experience talking.😭
Regards,
Jim Rogers
That's great advise Jim, thanks. I've been the "victim" of a broken rudder or two on previous builds and still haven't learned from it!
Rusty
On 11/16/2018 at 5:53 PM, Rustyj said:
Hi All,
Here is my first update on the Medway Longboat.
I didn't have a huzzywutchet but I did use my Byrnes table saw. I set the blade height and did a test cut with scrap wood from the keel billet.
This is looking great, very clean and tidy looking.
Can i ask though, what is a huzzywutchet ? Ive googled it at and theres only 1 result on google, which is this thread.
Edited by Trig
Current-
HMS Bounty 1:48 by Artesania Latina
Finished-
Gjoa by Constructo
Thanks Trig!
It is a combination height, depth & thickness gauge from a company called iGaging (igaging.com).
IMG_4295.thumb.JPG.1338a8157112134418b432276a29e4eb.JPG.b6f81dd7bf72e9f039d5034872859f62.JPG
Rusty
Making progress with some of the small things to finish the hull.
The roller and fixed block have been added to bow.
The traveler was made from 1/16' brass rod blackened.
The traveler and block have been added at the stern.
Next I will make the rudder and set it aside as Jim suggested.
Rusty
