Just got home from a New Year’s Day party that marks the end of the holiday season.  I even got a little time to spend in the shipyard these last few days. As a result, I’ve completed the planking of the Medway longboat.  I still may do some more sanding and a few more coats of oil based Wipe-on Poly, but all the planks have been installed. One thing I forgot to mention on my last post is that Chuck told me to make very sure as each plank is installed that it is glued to each frame.  So I need to try to move each frame just above a plank after it's put on the boat to insure it's properly glued..
RnBgAelDouUOijxaxhcLBnJeJ9JrJgGmJDZUdR5kMZzMgn8Q2hPqxrXLr3Xr4n7rp3j8gXllMT-wQ4lhnrrOBUN5q_5Y3_O1JlpHZPTKz9M0R23PBI4fgnObejPlu9KhMvrMNqtL
wthhEo-14iCwNBaag20vEnAvBCKx8AwYO0t1T35JO_MBkc6C53tWC326DFcvKXhkjsd9zSkLu9TlIBCZkP2vCgD_xCUb9tCQ3lrzTd0apKLsFX-9IFiQjLPLL072hBSbuOug_1PI
I'm going to spend some time on my Independence build over the next few days.
Edited by KenW
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
Very well done Ken.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thanks Rusty and Chuck.  I'll bring the model to the meeting on the 22nd.
Ken
Completed Builds:
On 12/21/2018 at 7:39 PM, KenW said:
I've always wondered about tree nails.  I'm sure they were used when most of the 18th century and earlier ships were built.  But once the planks were installed, the hull was painted.  So, the tree nails would be hidden under the paint.  Same for nails, probably.  So why go through all that trouble?
I like tree nails on the decks.  The decks were constantly scraped and I think the tree nails would be seen.  Of course, when I was in England and took a day trip down to Portsmouth, I couldn't see any on the deck of the HMS Victory.  I did see the tree nails on the USS Constitution in Boston.
What you saw were plugs, not treenails.  The deck plank is countersunk then nailed into place.  Next, a plug is inserted into the hole to protect the nail.  Looking at treenails you see end grain.  Plugs you see side grain.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Hey Chuck.  Thanks for the info.  Of course, when I saw the Constitution in Boston, I hadn't begun modeling so I had no idea what I was looking at.
I should go back.  So what is your opinion on tree nails on the hull?
Ken
Completed Builds:
I removed the frame centers and what remains actually looks like a boat.  In fact, that all went so well that I glued on the cap rail. No problems there, or so I thought.  Looking at the photos, and later at the model, I see a ‘swerve’ in the middle of the boat. I think I must have had a fairing issue that went undetected until now.  I’m hopeful that when I fail the inside of the hull and cap rail that I can ‘cover up the problem’. But fairing the inside of the hull comes later, for now it is on to the dreaded bolster.
5OvFoNNcLDsvoSXifFR8xLwomVDSTGLVSCu_jVChxyg3I9t4u1kdFSpad2jsM42TrdyVLQ9H9gGNASaQ7uyiFjVIsADkuW2a7dyir1AV1v3OP6mRsExVxO6TKbV80FfGLIYOb5xE
W89td5iUmf82Z5c3FQFEul10K2mSlBptLrpE9hDjT66RxFwpklXspXFKEfhAyCvQVk1wEz6bkaENLdDJd3E33kdBKVd8pWZ9t9VTTpxTcqQDc3-qoUhFb9LiR-XwZI5URZHafRaT
Ken
Completed Builds:
Looking nice Ken. Hopefully fairing will be able to "correct" the swerve.
Rusty
The dreaded bolsters are giving me lots of trouble.  The kit is supposed to have eight blanks, but I only find six.  I started with the starboard side and messed up 4 before I finally got a satisfactory bolster.  That leaves only one blank left. I reread the instructions and stopped using my x-acto knife. I also tried to draw a line where I think the shape should be, as per the instructions.  And I was very careful when making that curved bevel; checking the fit often. That bolster turned out surprisingly good. But now I’m really worried that I’ll mess up the last blank when making the port side bolster.
JBc6h8M2foQlDAxwCSJrhnHbigm1gr1-7qyxoCvFyLO6OaoPn_WLIYcHoKYvoNAmCfDluGDGc41zda91l9Xo7iOT2a903CHJp527f24L_2URD1VLa878P3SUVxe63dB7O8fX9e3x
Ken
Completed Builds:
Thanks Jim.
After my panic a couple of days ago, I was able to carve/sand an acceptable bolster for the port side of the model.  Again, I followed the method in Chuck’s instructions. Both bolsters are glued in place and and sanded. They look OK.  The space for the roller was no problem. The next step is to sand down the cap rail.
zEWVJ6JGzEx2OZhAS809bdprZW8xc7TRIq9Qn7DxP5kLy3DnovJcaVRyx6dXzJW7hNP6UU1yiCGzBlwer6Wh4s_EuYcbkzB8qzzzBZbWbgBz5fHvksfv-ynzzt6n3U1aLCkxS6_e     Bxx_HXg3ISkUNSg5nzUtg2TRH-4g0lbui4hSdQtZGXMD6gLzi9uMDhD3C1s_YdHT-hRrJgSf8kB9ojgjhK6qim6wM6y6Zi0K--M0VvUZgH2nSsvileGZxq6zwi0WCYaOcFeKyBA1
Edited by KenW
Ken
Completed Builds:
Thanks Jim for your comments.
Ken
Completed Builds:
Ken, panic is acceptable. It turned out very nice.
Rusty
I sanded down the cap rail to Chuck’s specifications.  No problems; just a lot of elbow grease and time. I used 220 and 320 grit sandpaper.  I added the inboard sheer strake and sanded it down so the sheer top meets the cap rail.  I also added the knee and sanded to insure that the seam is perfectly smooth. I finished it all off with 400 grit to get it even more smooth.  And then I painted the rail red. A little sand paper removed any red paint that ended up where it wasn’t supposed to be. Overall, it looks pretty good.
Ikaeu1boreDmTn07Fi0Y8iXFwzRoxcH78PZrPfOZoNbh8sNjgeAmopi9fnYX7Pz_7Y_vEczbPpFtz4IZfs4euArLYiPN5qDgEWB2PMzr_D7Jh6YzTmLcsFFs2smGAP707sR--tfh
Ken
Completed Builds:
I’ve finished the third chapter of the Medway Longboat instructions.  I drilled all the holes for the ‘nails’ and stuffed the holes with the monofilament.  I must say that I should have simulated the nails in each plank as they were installed.  It’s much easier to drill the holes INTO the frames. I can see several pieces of filament sticking through the inside of the boat.  But after I cut them off and put in the floorboards, I’m sure they won’t be seen. I glued the freezes and the molding that I scraped into shape.  I used a scraper that I got from Artesania Latina. The web site I used is:
    https://www.artesanialatina.net/en/162-micro-tools-for-modeling
The model number of the scraper is 27300.
DiHEr06_JE1iJfD-wX4krWO2DIT-tLktvk9-9VU9dPEjvefXjZoos8V5NPMRKPjrbjp8-70M9h6Iqy5JeOa-6SPXbClYlnWYT9kZO9aGbtLRJu8I5GFSIbuSqHq_Xa3TQ4LlLuDU
2gYlHx0qQ8Dvq_EZabv9OdTuYeg4tpt-qGjnMV2kxhf1tcrGyKbbo2TezheSB75S15G-cL_Qe2eUQ_KNieVFWptvJitCuOb_cx6Ko5yfW-OpO9mHDqVOiIzmpuzU6e7Ob8MMhGVI
Ken
Completed Builds:
Great workmanship Ken. If any of the monofilament should show a very tiny drop of yellow ochre paint hides them well.
Rusty
Your Longboat is looking very nice.  Thanks for the tip on installing the simulated nails as each plank is installed.  I hope to see your model at a future SMSNJ meeting.
Ryland
               - Nautical Research Guild
I began to work on the inside of the boat.  The first thing was to apply Wipe-On Poly. Then the floor boards and platforms.  No real problems. Just to boring task of doing simulated nails. And after all that you can hardly see them in the photos.
41A94Bf_UkCafTY0gUsQhPlZgsOZ5bMiWP8uCPAJL0-B927WpxE1yiEpRR_F9FlJWYS8Y8MYkYNSYzkYNNazTWAb4zL9xcSSHvkVefKzqKXs1GYdmc7-g2kMSCXSRvBezDX08lXc   GarPLYmpuRz_sG8bUgUounIuUWUIabP15Bcxvh1z-W-INL1pEXJiksduhwO6mIM09dB9hm8j0f0Ix-0Qu__rrJyzxzMkFlOrVCHHjTaVOT7u3IoeFSBDrmOr8O8qGBwUlMX34yXS
Ken
Completed Builds:
Looking really good Ken.I'll have to stop down and see it in person again!
Rusty
Thanks Rusty and come on down.
And I always listen to Chuck.2019_04_19_01.jpg.60ca73c11b2a797ec5ba33ec31172f77.jpg
Ken
Completed Builds:
  • 1 year later...
