I think we all know that one about magnifiers.   I get dizzy and have headaches in about 5 minutes, yet they sit on the bench if I need to examine something up close.
On 12/10/2018 at 10:40 AM, Mirabell61 said:
fantastic little model Javier,
love the details and your excellent skill in this scale !!
    And to think that I have trouble with 1:96 scale!
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
Very Nice, I am looking forward to seeing how you finish the sails.
Michael
I like the general look of the sails Javier, I am curious about the way that the strengthening patches look at the clew of them though. I would have thought that the inward corner would have been clipped a little.
Michael
For this model I am following the ANCRE monography of thr Gemma tartana, from which I put a picture.
It is possible that the size of the patches is a little too big to see, but I think it is due to its dark color, which contrasts a lot with that of the sails.
Javier
www. barcosbaron.wordpress.com
Thank you Javier for your reply to my question.
Michael
The tartana is finished. I have followed closely the monograph of the tartana Gemma (ANCRE), of Franco Fissore, although I have allowed myself some licenses because of the small scale. One of the aspects in which I have been guided totally by the monograph is in which the model has been rigged, with the jibs to starboard in a boom especially armed for it.
I hope the result will be to your liking, because I have really enjoyed doing this
A beautiful working boat Javier  !
Nils
Current builds
-Lightship Elbe 1
Completed
Lovely!!!
XXXDAn
21 hours ago, amateur said:
Can you tell how you made the sails? they lookvery convincing.
Jan
Making of sail:
I cut to bias strips of fabric of the desired width to imitate the sail cloths that make up the sails in reality.
I stick the strips with textile glue, with a minimum overlap between them.
I cut the sails to the size and shape needed for the model, I make the reef bands with a thin strip of fabric that I stick in its position.
If the sail has patches in the corners, I hit them before the tablings.
With strips of fabric of a minimum thickness I make the tablings, which are then stuck on the edges of the trimmed sail (on both sides). I stick a thread around the sail to make the bolt rope, leaving a loop in the corners to make the clue ropes. Finally, I put the reefs in the number and position that is required in the corresponding positions of the reef bands.
Javier
Another superb model Javier seeing it in the palm of your hand makes it all the more remarkable.
Thank you for giving us the opportunity to follow how you built it.
Michael
  • 5 months later...
Javier; when you begin applying the strakes do you add a small piece of wood at the bow and stern so the strakes have a surface for which to be glued or...how do you do this?...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
I stuffed with balsa wood from the first frame to the bow and from the last to the stern, and then stem to give it shape and to serve as a support to glue the strakes. Then, when I pull out the temporary frames, I also remove the balsa wood from the bow and from the stern.
Best regards,
Javier
Thank you Javier. My first attempt wasn't too good but I'll try again. Again, thank you...Moab
Completed Builds:
Ranger...Corel
Hansa Kogge...Dusek
Spray...BlueJacket
Under Construction:
