etsinko
Schooner Polotsk by etsinko - Master Korabel - 1:72
Hello everybody,
Some time ago I started building Master Korabel Schooner Polotsk kit but I was too lazy/busy to start a build log here. Finally I decided to go ahead and do it. I'll be posting more often until this build log catches up with the build's current state. I have been precisely following the instructions during the process so far and it has been a smooth ride.
1. I started with assembly of the ship's frame. The desing of this kit's frame is very interesting, it has a HDF plate that splits the frame horizontally. This ensures that all bulkheads and the center keel are perfectly straight and perpendicular to each other:
2. All parts have laser cut notches so it was really easy to bevel them:
3. This is how the frame looks like with all lower bulkheads installed:
4. Finally upper bulkheads and the false deck are installed. Note how the deck overhangs in the stern and how thick the timbers are (these will be cut off later):
Share this post
Link to post
Share on other sites
5. Next come the bulwark and the taffrail. In order to simplify this step the kit supplies two jigs. One for the bow and another one for the taffrail in the stern. These jigs are inserted into the holes in the deck and support both the bulwark and the taffrail (I wrapped one of them in scotch tape to prevent the taffrail accidentaly gluing to it):
6. After that I soaked the bulwark and the taffrail in water, carefully bent them and put them on the model without gluing anything. Then I let them dry completely:
7. Once dry they maintained their shape and could be easily adjusted on the model without too much stress. Finally I glued them to the hull (it was really important to make sure that the bulwark is not glued to the timbers!):
8. After glue was dry the jigs could be removed:
Share this post
Link to post
9. Next, the stern needed to be shaped using a bunch of filler blocks. I glued them in and carefully shaped them using a sanding block:
10. First layer of planking was a breeze thanks to all planks being pre-cut with laser. All of them fit each other perfectly and it was such an smooth sailing that I forgot to take any pictures of the process. Here is the end result:
I also painted all openings and hatches in the deck black:
11.  The final layer of planking started with the taffrail. Everything was straightforward and all parts fit each other perfectly:
Share this post
Link to post
This is amazing kit! All just fits together out of the box.  I had never seen such quality from any other kit manufacturers. I would love they designed some larger ship kits with  same quality.
Share this post
Link to post
I totally agree. This is my second kit by Master Korabel and I'm loving it! As far as I know they are planning to release some 1:48 scale bigger boats some time this year. I assume the quality is going to be at the same level.
Share this post
Link to post
6 hours ago, DocBlake said:
Very interesting!  I'll be watching this one.  I'm also awaiting Master Korabel's tender "Avos".
I'm waiting for tender "Avos" as well. It is my next build after this one.
Share this post
Link to post
12. Next I cut off all timbers (except cathead's timber) supporting the bulwark. I was lucky the bulwark hadn't glued to them:
The inner bulwark consisted of two layers on this model. First layer has only opening for gun ports, while the second layer had additional openings for oar ports. This created an illusion of real oarports. Gluing first layer wasn't too hard. All I had to do was to make sure that all gunport openings align correctly:
I was worried about gluing the second layer. Not only everything had to be aligned, but I also had to work very fast so that PVA glue didn't dry before everything was aligned and clamped together:
13. Next were the deck and the waterways. In this kit the deck came as one piece with all plank lines cut with laser. I spent a lot of time sanding and adjusting the deck and the waterways so they fit nicely. After I was confident that everything fitted nicely I glued waterways first and then the deck. For gluing the deck I used thick CA glue. The deck had a saddle shape and I was afraid I wouldn't be able to clamp it well enough if I used PVA glue. I used pins to align the deck with the openings (you can also see oar ports in this picture) :
The kit supplied final waterways piece in the stern was a little bit short for my taste:
So I spent a few more minutes and made a new one from scratch:
26.thumb.jpg.a0728ba1212fc88bcbc5723c1bafca09.jpgIn the end, this is how the hull looked like:
Share this post
Link to post
It's available at the moment. On eBay, search for Master Korabel Avos
Share this post
Link to post
Yes, but those are models for Russian market sold by individuals, they don't have a manual in English. Master Korabel is still in process of translating it.
Share this post
Link to post
A week ago I asked Greenstone, who promoted the kit in this forum, and he told me :
  On 12/30/2018 at 9:41 AM, Dutchman said:
Great! Will there also be an english instruction/manual included (or available)?
Yes, it will be with english text instruction, photo instruction and drawing
Share this post
Link to post
Yes, the instructions will be available, but not just yet. End of January, that is when it is going to be available.
Share this post
Link to post
Ohwell....fine, either way. I won't be ordering it soon anyway (I think). I still have a lot of building hours to go on my current kit ;)
Share this post
Link to post
14. Once glue was dry I proceeded to glue the final layer of planks. All planks came precut in this kit and the first strake needed to be installed was the bulwark. It had to be carefully aligned with the port openings because all other strakes depended on this one. I used my favourite way of gluing veneer - PVA + hot iron:
Then I continued gluing the strakes alternating port and starboard sides:
Eventually the whole hull was planked and the central keel and the sternpost were installed:
14. The design of the stem piece was very interesting. It was made from one solid piece of plywood and a few veneer pieces were needed to be glued on to it to simulate a composite stem:
15. Finally I installed gun port covers in the stern:
And this is how she looked after planking stage:
Edited by etsinko
Share this post
Link to post
15. Next I assembled the rudder and the pintles:
8.thumb.jpg.b8c740a372b3a762eb2f06573bf74fa3.jpgGlued the horseshoe to the keel:
16. After applying a layer of wipe-on-poly to the hull I glued brass decorative details to the taffrail and installed the rudder:
17. Next I decided to spend some time assembling all the deck details. They are done as a small kits included with the ship and were easy to assemble. The capstan:
11.thumb.jpg.d9e6e70031a45e9c94b060d871172afc.jpgThe pumps. The manual suggests gluing the metal handles with some BF-2 glue. I couldn't finds this glue in Canada. I think this is some special glue that can only be bought in Russia. I tried gluing them with CA glue but it doesn't hold brass. In the end I decided to solder them and the result was phenomenal. I highly recommend soldering brass parts instead of gluing them!
The binnacle:
13.thumb.jpg.913f6c73fdc7c7286a7aa224159a22f1.jpgFinally I assembled the hatches and the grates. I used aftermarket lasercut grates which have 0.6mm square openings. I think these are much better for this scale:
18. Then I installed catheads and some decorative elements in the ship's head:
Share this post
Link to post
Really impressed with this build - that is a lovely fit of planks to stem and stern.
Just a query - could you expand upon your favorite method of gluing  - PVA and hot iron - i fancy trying it on my Pickle build and I am just at that stage
Share this post
Link to post
SpyGlass,
The idea behind gluing with hot iron is that when you heat up PVA glue it melts and as soon as you stop applying heat it solidifies very quickly (~ 5 - 10 seconds). The benefit of this is that this can be repeated multiple times.
1. I dryfit the plank, make sure that it fits nicely where it supposed to go
2. I apply PVA glue (I'm using Weldbond white PVA glue) on the back side of plank and make sure to spread it with a toothpick so it covers the whole plank consistently
Really, the beauty of this method is that there is no rush, glue can dry but it won't stop it from melting and gluing. So you can take your time here and make sure that everything is covered.
This is how it looks like when covered whith glue (actually this is a bit too much):
3. I usually wait until the glue is tacky and then begin to put the plank on the hull. I start from the bow and put the plank as close as possible to the stem and to the previous strake. Just lay it out along the hull trying fit it properly (its ok if it is not a perfect fit)
4. Then I apply the tip of the hot iron to the plank where it touches the bow. I move it back and forth a little and press it slightly. Really like ironing linens. The goal here is to get the plank glued to the bow section so you have starting point.
5. After a few seconds (depends on how hot your iron is) the glue will melt and you can start pushing the plank with your fingers. I try to get it as close as possible to the stem and to the previous strake. You'll have about 5 seconds to do that. If glue dries before you finished you can apply heat again
6. Once I'm happy with how fore section turned out, I continue to work in ~ 2" sections: heat up, push the plank towards the previous strake and wait till it's dry
7. After the plank has been glued, I check the whole strake for gaps. If I see them, I apply the tip of hot iron and push the plank again
8. Finally, I look at the open end of the plank (the side that is opposite from the previous strake) and if I see any gaps,  I just heat them up and push down with fingers
And that's it!
Another good thing about this method is that you can use an iron to remove a plank as well! Just start from the stern and move in short sections heating the plank up and lifting it with a tip of a knife.
As for the temperature. I crank my iron to the max, but it is probably an overkill. You can practice on scrap veneer and see what works for you
Hope this helps!
Share this post
Link to post
Thanks I have heard of this before and I presumed that it was done as you describe so well but didnt have the courage  ( or the iron) to try before getting details.
Your build of course has the advantage of working with preshaped planks - are they ply or solid and how thick ?
I shall  give it a whirl on scrap - when i can get an iron  past the Admiral. Somewhere I have a little travel iron which is more handy i shall try that too.
I hate CA but PVA just requires so many clamps  and doesnt do that first "grab" which your method overcomes and on Pickle its a real problem because the first planking is so thin that i have actually damaged it with my normal clamps I have always used.
Edited by SpyGlass
Share this post
Link to post
SpyGlass,
this technique works for veneer (less than 1mm thick). With thicker planks there is not enough time for heat to get glue boiling before the other side of the plank begins to smoke.
Yes, try with scrap first. That is how I learned it. It is a great technique and you'll find it handy!
Share this post
Link to post
18. I patiently continued chugging along and adding more and more details... The mast bitts, the windass, the smokestack, the channels, the belaying pin racks. I also carved and installed 16 knight heads. Thankfully those came laser cut and minimal carving required to finish them:
19. I really liked working on the head decorations. The kit included a lot of details including two "sailors' thrones"! All parts were laser cut and were pretty easy to install and minimal sanding was required. All decorations were made of photoetched brass:
21.thumb.jpg.8815a97bb416798201ddfaf69eb735f4.jpg22.thumb.jpg.81e80acf31e967758f928df6f25ac8d1.jpg23.thumb.jpg.088a4e6a3984a440d54981d8d990c883.jpg
20. Finally all hull details were complete and I switched to spars. Altogether there were 15 spars including a couple of flagpoles - reasonable amount. Most of the spars came as laser cut parts and required rounding. I used a mini plane to make them octogonal and then sanded them further down. Some spars had pretty complex shapes:
Yards were pretty detailed for such scale:
Each crosstree consisted of 6 lasercut parts:
And this is where I stand right now. All that is left is to assemble 12 cannons, rig and install them and then rig the ship.  I will continue posting my progress here as it comes along.
Share this post
Link to post
8 hours ago, etsinko said:
SpyGlass,
I guess you could also use an electrical plankbender (which I happen to use sometimes to pre-bend the planks ;) ). Maybe handier than an iron, which is quite bulky?
Share this post
Link to post
Humm yes I seem now to remember that I did try this some years ago and I was using 1.5 mm strip and indeed one sided smoked before the other side steamed.
But I am using 1mm now so I will give it another try on scrap.
Share this post
Link to post
I'm finally back from my long break and begin to continue working on my model of Polotsk. I'm getting back into it slowly hence there is not too much progress so far. All that is left before rigging and masting can begin is to assemble and install the cannons, install and rig the tiller, the binnacle, the anchors, the boat, the chainplates and some other little things on the deck.
21. Getting cannons assembled was very easy but super boring. There are 12 of them altogether and it was very repetitive. I needed to make and install 48 jump rings into 48 eyebolts. First I built carriages and tied breeching ropes to cascables:
Then I seized two eyebolts into the breeching ropes:
And using a simple jig tightened and adjusted seizings so they are all of the same length:
No other cannon tackles were used on this model, so the cannons finally could be installed on the model. Here, I only glued the eyebolts into the bulwark without attaching the cannons to the deck, I will glue them to the deck once the chainplates are installed. Also, in this picture you can see anchor cable being laid down:
22. Then I rigged the tiller and installed the binnacle and the skylight:
Share this post
Link to post
23. Finally I moved to installing the chainplates. First, I installed all deadeyes into the chainplates and carefully positioned them in the channels. I used green painter's tape to mark their angles:
Then I spent quite a lot of time adjusting the chainplates on each side to make them symmetrical:
When I was finally satisfied with their positions, I drilled the holes and inserted nails:
24. Next I installed the ship's boat on the keelblocks. I used some sailcloth to simulate a furled sail:
25. Then anchors were installed (I haven't lashed them to the knightheads just yet, will do it once bowsprit is rigged). I used heatshrink to simulate bands on the anchor stock:
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
The Guild is a non-profit educational organization whose mission is to provide support to our members in their efforts to raise the quality of their model shipcraft.
The Nautical Research Guild puts on ship modeling seminars, yearly conferences, and juried competitions. We publish books on ship modeling techniques as well as our world-renowned quarterly magazine, The Nautical Research Journal, whose pages are full of articles by master ship modelers who show you how they build those exquisite details on their models, and by maritime historians who show you what details to build.
Our Emblem
