Back on February 1st of this year, I purchased the Model Shipways New Bedford Whaleboat kit from Model Expo.
I have been a modeler on and off through out my life in plastic and card stock models, and now that I am retired I wanted to give
a wooden model a try.  I have been working a little each day on the whaleboat and I believe I have made good progress.
I am at the stage now where the basic whaleboat is together and do have a few question, so I will start posting some of my
build photos and hope you all enjoy my beginners efforts!
CURRENT BUILD:
HMS Winchelsea, 1764 ~ 1:48 scale
COMPLETED BUILDS:
New Bedford Whaleboat ~ 1:16 scale
Ships in Bottles Models
Card Stock Nautical Models
~Donor & Member of Nautical Research Guild~
Current build photo
Questions:  I have the rudder triced up on the port side aft but the line I used looks a little small to my eye?  Thoughts Please!
I have been working on the stand for the Whaleboat but not sure it is what I what?  Thoughts Please!
Thanks all and God Bless!
Edited by RBohlman
Add better photos
CURRENT BUILD:
COMPLETED BUILDS:
I always keep my stands simple in design so as not to take away from the ship itself. A lot of other artist prefer to put more into them since they are part of the art work. Including a diorama or having the whaleboat on davits attached to a bulwark similar to the plans.
The size of the base looks ok. You don't want a stand that is smaller then the hull since it looks like it is sailing off the stand. The pedestals are to large in my view. In the first photo you attached, Model Shipways is using heavy wire about the thickness of a hanger which I have seen quite often for boat models. You may want to down load other whale boats on-line and see what other artist are using. Model galleries would also be a good source.
From the photos it does look like you are doing a nice job on the whaleboat.
Scott
Concerning your other question about the line you used on the rudder, I doubt that there was a standard dimension. More than likely whatever was available. On Sheet 3 of the plans Erik  Ronnberg did include a tricing line that should give you a good idea of the scale.
Scott
Lookin really nice! This particular model is on my list to do, I like the size, it's easier to get nice details in...Will be watching this.
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Scott
Thanks, I did try to match the line size to the Sheet 3 drawing so I guess that it is the appx correct size.
Thanks everyone for the comments and help!
CURRENT BUILD:
COMPLETED BUILDS:
I have been working on a different stand for my Whaleboat model.
The cradle stands holds the boat a lot better then my 1st round wooden stands.  I stained the
cradle stands the same as on the base and also gave them a light coat of poly to match
better with the base.
Edited by RBohlman
change typo
CURRENT BUILD:
COMPLETED BUILDS:
Nice RB...you are helping me make up my mind about my next project! I am about 20 miles from the N.B. Whaling Museum and 25 miles from The Mayflower II in Plymouth Ma. Already have completed that model.
Working on hull painting and will do some weathering later after paint is nice and dry.
After the painting is completed I will be building the oars and line tubs.
I can see the light at the end of the tunnel to having this build completed!  🙂
Edited by RBohlman
Typo
CURRENT BUILD:
COMPLETED BUILDS:
Great work! Makes me think of the seamen who manned these boats...having a whale on the line and going on the "Nantucket sleigh ride".
Finished painting dark green on Whaleboat hull this morning.
I plan to let her dry overnight and then do a little touch up tomorrow
after which it is on to the building of the oars.
CURRENT BUILD:
COMPLETED BUILDS:
You are doing a beautiful job on your whaleboat.
As a kid and even now, the thoughts of hunting huge whales out on a vast ocean in a little boat using a harpoon, these so much stoked the fires of imagination. What a fearless (it seems) life those sailors led. My imagination tells me a sailor's chances of survival back then were not very high. Either a whale, the ocean, cold, or disease were all likely to take his life.
Rowlocks completed and attached.  Next step is to serve them over.
Started work on the Stern Line Tub.
Edited by RBohlman
Typo
CURRENT BUILD:
COMPLETED BUILDS:
Started work yesterday on the rowlocks.  Serving them over to muffle their sound when hunting the whale.
Stern line tub built and making a trip to Walmart today for some wood filler and other things.
Here is a photo of a rope tub that I am using as a model for mine.
Edited by RBohlman
typo
CURRENT BUILD:
COMPLETED BUILDS:
Stern and Waist tubs completed, grommet & thimble attached to the port gunwale at the mast thwart for the shroud lanyard.
Next need to work on the drogue, water keg, & piggin.
CURRENT BUILD:
COMPLETED BUILDS:
Drogue, Water Keg, Bucket and Lantern Keg completed. Working on Piggin this afternoon.
Will be starting the Spirit Pole and Sail work tomorrow. :)
CURRENT BUILD:
COMPLETED BUILDS:
Stays completed for main mast.  Time to start working on the sail.
Not a lot left to make, some irons, two knives, an axe, and the steering oar block.
I can see the light at the end of the tunnel!  :)
CURRENT BUILD:
COMPLETED BUILDS:
Ironed sail cloth and make a card stock template of full size whaleboat sail.
Ordered fabric glue and researching drawing on sail to show sail sections without sewing on sail.
Making up four (4) rope grommets for sail corners.
Edited by RBohlman
typo
CURRENT BUILD:
COMPLETED BUILDS:
Purchased a $29.99 Varmax mini sewing machine from Amazon to sew my whaleboat sail.
It worked very well and I finished a lot of the lines on the sail this morning.
I will be gluing & sewing the sails edges later today, then adding the grommets and boltrope.
CURRENT BUILD:
COMPLETED BUILDS:
I see a ham radio station in the background in one of your pictures. Are you also a licensed ham?
Ron Gove
W1GOV
Leesburg, VA
Ron Gove
W1GOV
Leesburg, VA
KG5QLS Extra on QRZ
CURRENT BUILD:
COMPLETED BUILDS:
