2 hours ago, Vane said:
Moving on to the ships boat... this is abit tricky but I think I am through the worst part... first couple of planks. Now it is stable and just keep adding pieces to it!
I feel with you Vane, as I'm building a boat for my Duchess of Kingston at the moment. It's a tedious affair for a novice like me and the first planks were not the most difficult.
I feared the step of removing the frames, but it worked out good, without destroying the hull. I used PVA for the planks in places, where the frames will be removed and CA on the other parts of the planks.
Cheers Rob
                             Duchess of Kingston - paused
                             USS Arizona 1/350 Eduard
The first time I broke out the MDF frames, I was more than a little wary.
Actually, just go gently and it'll be fine. My suggestion is to snip away the bridge between the two halves and twist each side out separately.
Ongoing:
Thanks for the advice, I managed to do the hard part without breaking it. The worst was to get rid of all CA glue. I decided to deviate from the instructions and add the top rail before removing the frames to get a more solid structure.
Its hard work but I do think this piece will really add to the finish of the model.
Current builds: HMS Victory (Corel 1:98), HMS Snake (Caldercraft 1:64), HMBV Granado (Caldercraft 1:64), HMS Diana (Caldercraft 1:64), HMS Speedy (Vanguard Models 1:64)
That's a pretty good launch, It's smaller than your thumb 👍
Beautiful job!
Current Build - St. Roch, Billing Boats; HMS Agamemnon, Caldercraft (on hold)
Previous Builds - Armed Virginia Sloop, Model Shipways; Constitution, Model Shipways; Rattlesnake, Mamoli; Virginia Privateer, Marine Model Co, restoration; Prince de Neufchatel, Model Shipways; Charles W. Morgan, Model Shipways; Pride of Baltimore II, Model Shipways, Bluenose, Model Shipways (x2); Niagara, Model Shipways; Mayfower, Model Shipways; Shamrock V, Amati; HMS Pegasus, Victory/Amati
I realized that I have now completed the building phase of the model and reached page 48 of 54 in the manual.
No more cutting wood, sanding, painting nor gluing parts. All what is left to do has been organized into this box.
I have no clue how long time it will take to tie all the blocks and rig Speedy but it feels good to have completed this stage of the build. I will try to take some proper photos of how the ship looks like and post them in the next post. Thanks for all the nice comments and support so far.
Lovely looking model so far. Congratulations
I may be wrong but I believe the boat oars were stowed with all paddles facing the same way. No doubt the experts out there will confirm
Thanks, I have seen both ways but thought it was "cleaner" to do it zig zag.
And here she is in her full glory.
I will now take a break from the work, since I am going on a long holiday abroad for the first time in 2.5 years. So dont expect any updates until I am back at the bench.
  • 3 months later...
