General Dynamics F-16XL-2 by CDW - FINISHED - Kinetic - 1:48 Scale - PLASTIC - experimental fighter-bomber
The F-16XL-2 is a derivative of the F-16, with a "cranked arrow" delta wing. This delta wing configuration allowed the F-16XL-2 to carry twice the ordnance load of the F-16 with a 40% greater range. The wing configuration provided 27 hard points for ordnance. The aircraft was entered into the United States Air Force Enhanced Technical Fighter (ETF) competition, but lost to the F-15E Strike Eagle. Subsequently, the two prototype models were turned over to NASA for research. Both aircraft were retired in 2009 and are stored at Edwards AFB.
I plan to build this model pretty much box-stock. The only aftermarket items I have purchased for it are a pair of Aires Aces2 resin ejection seats. I may add some home made plumbing/wiring here and there to give the model an enhanced appearance but I don't want to go crazy with extra details that bog down the progress of the build. This is a project I would like to finish within 2 weeks, maybe 3.
Provided here are photos of the kit box and the instruction pages. As I'm building the kit, I will refer to the step #'s I'm working on so you will have some point of reference.
DSCN3115.thumb.JPG.7f4970b593f36a0fd8026a5a1e3dd518.JPGDSCN3116.thumb.JPG.25617a9a55df8b984ffeb86460d0994c.JPGDSCN3117.thumb.JPG.d9314f652b6b3ba5b524960877dec436.JPGDSCN3118.thumb.JPG.29f35cf1df9ff08ecd1f9b6f5085c7d0.JPGDSCN3119.thumb.JPG.c4ce8dc3cba73e53b5685a6f981ff488.JPGDSCN3120.thumb.JPG.f6600638879488b35616965c4cc158c8.JPGDSCN3121.thumb.JPG.de1492fa2fb17ee30896b396d2e232f2.JPGDSCN3122.thumb.JPG.3303a168ab2393ef2325143c83094384.JPGDSCN3123.thumb.JPG.bceaa6cca487ee1fabb9c9647288f972.JPGDSCN3124.thumb.JPG.30cc6f5abd5d661151e050f2a7083ddf.JPG
This will be Brill  - Very very good kit.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
I'm in :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Heretofore, models of the F-16XL have been few and far between. Monogram did one in 1:72 scale a long time ago, then a company in Korea, Kangnam, did one in 1:32 scale in the 90's.
According to experts (not I), neither kit was accurate and there was a massive resin correction set available for the 1:32 model that seemed cost prohibitive. Seems like Kinetic did a good job on their molds for the plane, again, that's according to experts and not me. I just think the molds look really nice. Engraving and detail looks super.
I've read the four-color camouflage is hypothetical. That being the case, I may decide to fly by the seat of my pants and create my own hypothetical paint scheme. I've got some nice decal graphics that are begging to be used.
Looking forward to this one mate,   the closest I came to seeing a  future concept plane was at Farnborough Airshow  in the early 80s when they had the Mirage 4000  proto type, like the F16XL it has some amazing tech to it.
OC.
Current builds
Completed works.
Saw it out at Edwards AFB in the prototype scheme, back the 90s. Liked it a lot, since it was a two seater. Saw lots of other cool stuff out there, too. Lifting bodies, an SR-71.
I'm in.
Ken
Started: MS Bounty Longboat,
This is steps 1 through 8, and most of step 9. I prefer to leave the landing gear assemblies until later in the build as there is more construction, filling, priming, and painting to do first.
DSCN3130.thumb.JPG.1d483fbe68ca5c57fb9f2c4a11e8a20b.JPGDSCN3131.thumb.JPG.69c7b4e3ad07909622b4e26c39973cc0.JPGDSCN3132.thumb.JPG.0193177760d57e955ba42c6a6ebd31e4.JPGDSCN3133.thumb.JPG.083de75fcc545910a418a675ed2b013f.JPGDSCN3136.thumb.JPG.7143e1c1f5218df9a377c57e5e4f60b8.JPG
On both left and right wings, there is an annoying gap at the leading edge. Other than that, the model parts have been a pretty good fit to this point.
I'm using the "stretched sprue" technique to fill the gaps, as there is a row of fine rivet detail immediately adjacent to the gap that would be destroyed by filling with putty and sanding. After the stretched sprue, will carefully lay down some #500 Mr Surfacer with a small detail brush to finish off the seam. It should be almost invisible when finished and leave the rivet detail intact (as long as I don't fill them with Mr Surfacer).
1852315860_stretchedsprue.thumb.jpg.94bccd9b8b908f9824369fe6af573fa2.jpg403271150_stretchedsprue2.jpg.b9aef7c29e07e07440e5ac901b4997fc.jpg
Just now, GrandpaPhil said:
I’ll have to remember the stretched sprue method of filling seams in plastic models.
If you try it, use Tamiya liquid cement to fuse the streched sprue into the seam. It softens the plastic sprue material and you can push it down into the seamusing a tooth pick or similar tool of your choice. Much less hassle than putty and easy to clean up afterward without sanding away surrounding detail.
PS: I should have added, back in the day, this was also a popular method of adding or re-establishing a raised panel line.
Edited by CDW
look'in good :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
CDW,
I read somewhere that those two birds were taken out of storage for "further testing".   I don't remember why though....
Cool! My Son is crewchief to an F-16 mainly 803 at Misawa does others also but have one about 1/2 built meaning to do it in 803 maybe this will be the spark? ;) Kevin
The video is pretty old like 2016 he made E-5 about 2/3 months ago he joined in summer of 2015 needless to say I am proud of him he's done well.I sent the link via skype about F-16 Delta.
Edited by Javlin
video
5 hours ago, mtaylor said:
CDW,
I'm guessing you watched the video I posted? It talks about the testing NASA did on the planes using laminar airflow technology, and the fact it gave the F-16XL airframes the ability to fly supersonic without afterburner. Other than that, I haven't heard about further testing, but would be interested in more information. Will be on the lookout for more.
 I'll have to check a site I visit regularly that deals with various military items.
Life has really gotten in the way of modeling the past few days (more than a few actually), but it is what it is. Between other household projects, I've squeezed in some modeling time here and there, but not a steady pace the way I like to do it. Never the less, I finally arrived at the time for exterior paint. First step was giving everything a coat of Tamiya white primer using their bottled primer shot through my airbrush. If you try this cost-effective means of using Tamiya primer, be sure to use an adequate percentage of Tamiya lacquer thinner to primer, about a 60:40 ratio of reducer to primer. Any less reducer and you will likely have clogging issues through your airbrush. Anyway, the primer went on nice and smooth with no issues.
Next, I decided to use AK paints for the color coats as a while back, I bought a set of US Modern Aircraft paints that include a large selection of various shades of gray, perfect for my F-16XL. I got careless and forgot that Mr Color leveling thinner does not work with AK paints. I mixed the AK paint with the Mr Color thinner directly in the color cup of my airbrush and that made a huge mess inside my airbrush. Next I had to do a thorough tear down and cleaning of the airbrush before I could move forward. After doing all that, I then added the color to the cup of my airbrush again and then mixed in about 40% AK reducer as is my usual mix ratio for similar color coats of other brands such as Tamiya or Mr Color...wrong again. 40% reducer made the AK paint FAR too thin and I made a big mess with it. I took the model directly to the sink where I washed away the color I had just applied and brushed it all off with a wide soft brush. After drying off the model, I tried again, this time using the AK paint directly from the bottle, no reducer at all. This time it was perfect. The AK paint dries to a nice satin finish, but it DOES NOT LIKE THINNER at all! Even it's own brand of thinner was not needed, the paint is ready to spray straight from the bottle. I should have known better and practiced with it a bit first, as should be done with any paint we are not familiar with.
Really and truly, I should not be making mistakes like this. I've been at this hobby long enough to know better, but sometimes I get in a rush and end up paying the price for it. Luckily, using acrylic paints makes it easy to correct a bad situation just by rinsing away the paint with water before it dries.
Soon, I'll post some photos of the finished paint scheme, but it's going to take a few days as there is lots of masking to do for this one and each coat needs to dry overnight before masking.
Until next time, Cheers!
I get the same way sometimes like you been doing this for off and on for 50yrs now?What is the the thinner for AK? I have just a few of there bottles and sprayed straight like it's between a acrylic and almost enamel but that's not possible I think I used alcohol and Tamy thinner to clean the airbrush. ;) Kevin
Yeah, I'm almost 60 years into this hobby now but still learning.
For AK, they have their own proprietary thinner, but I think Vallejo thinner would work just as well. Having said that, try mixing a small amount in a disposable paint cup first to make sure there is no bad reaction if you are using something other than their own thinner. Mr Color thinner or alcohol will turn the AK paint into a big gum ball. Straight from the bottle, the AK paint settles down into a finish that's just as you described, a cross between an acrylic and enamel. Takes this stuff at least 24 hours to dry and still feels somewhat tacky even then. But I like the finished look of it, a satin finish. I think once it thoroughly dries, it will take a wash very well, with no need for a clear coat prior to the wash.
This model will have five different shades of gray in the Heather-Ferris camouflage scheme. Here, I have placed the first two shades of gray, both AK paints. The finished camo scheme can be seen on the instruction page in my first post.
DSCN3150.thumb.JPG.bf62f2e2e6969237bb6fe6381d3fbdc4.JPGDSCN3151.thumb.JPG.54474e68890a41892c303a5739953add.JPGDSCN3152.thumb.JPG.8f2d592f875e4ddb19abd3e642ecde3b.JPG
The Heather-Ferris camouflage paint scheme is just about finished. While the finish looks okay, I'm just not a fan of these AK Air acrylic paints. Maybe I received a bad batch, I don't know. I have read where some bad batches got out there but don't know if that's the case here. The problem is, the paint has stayed tacky for days. Never had an acrylic paint act like that. It's common to enamels, but odd for acrylics in my own personal experience.
When you first spray this paint down, it looks like crap. Then you take your hair dryer, give it a drying treatment and it looks great. If the paint didn't stay tacky, it would be good.
DSCN3153.thumb.JPG.135cdee93835e436914a74d885b62684.JPGDSCN3154.thumb.JPG.b6c76fe03be1c903a6314b2797f674d5.JPGDSCN3155.thumb.JPG.58323e6375ac3ec18f1b997e4407a88d.JPGDSCN3157.thumb.JPG.7e3201c310ac34c98eb8966fbc51495d.JPGDSCN3158.thumb.JPG.28b02437367ded6d689eea2d692625e1.JPG
superb paint so far  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Here's a few photos of where she sits right now.
The camouflage is done, still need to add some panel line work. The canopy and seats are sitting in place for photos, but not cemented. Still must add photo etch details and detail painting to the ejection seats. My aftermarket resin ejection seats were too wide to fit inside the cockpit tub. While I could sand away enough to force a fit, it would erase much of the detail the resin seats provided in the first place.I just opted to use the kit-supplied seats and will add the aftermarket photo etch bits to enhance them.
It's unfortunate but this kit does not supply any decal markings for the vast array of ordnance provided in the kit. It just won't look complete without the decals, so I had to order a set from a vendor in Australia. That order won't arrive until mid-January so it's going to be a while before I can finish this model.
In the meantime, I'll be finishing the cockpit, adding and painting the afterburner, preparing and adding the ordnance pylons, adding panel line details, then applying the main decals supplied in the kit.
DSCN3159.thumb.JPG.279d2956f520596f4f5388b5409ecdd1.JPGDSCN3160.thumb.JPG.021ea8843455abd213ca9f1da7848678.JPGDSCN3161.thumb.JPG.bcce41275691297f0bc9a55b50c8a6e1.JPGDSCN3162.thumb.JPG.31d5aee903b7cc6ba6632cf2dd70c6e5.JPGDSCN3163.thumb.JPG.26a434967f4525e91e0a0b4618a35dee.JPGDSCN3164.thumb.JPG.10adc89a25043e271f7dbbdbaaa63635.JPGDSCN3165.thumb.JPG.978a088d916c5141247cebd5a57a2938.JPG
Craig, most iron bombs, whether live or inert shapes were a khaki green. Live ordnance would have a yellow band next to the front fuse, inert ordnance would have a blue band. Laser kits were khaki, too. Cluster bombs were similarly painted.
AIM-9 Sidewinders have a metallic green forward section. White behind. And yellow or blue stripes near the fuse section. Sparrows and AMRAAMs were white, except the radome/front section was a white ceramic.
12 years as a Weapons Officer did leave some imprint. ;)
Ken
very nice!  hope your having a great Christmas day right now :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks so much Denis. We are having a grand time here. Hope you are doing the same. Two of my daughters and a grand daughter are flying up to Manchester tomorrow morning to spend a week with their big sister.
They are really looking forward to seeing snow. 😃
