Amazing job Danny ! And you actually make it sound easy... oh dear!  :pirate41:
Padeen (Adeline)
"When there is a will, there is a way"
Completed build: Le Camaret - Constructo - static wood 1:35  (build log, gallery)
Current build (very limited modelling time at the moment...): HMS Fly - Amati/Victory Models - static wood 1:64 (build log)
Projected build: HMS Victory - Chris Watton's design - static wood 1:64 (when available..., no rush!)
Thank you Mark, Brian, Janos, Druxey and Adeline.
Brian, I'll write a tutorial when I learn how to silver solder properly :D .
Janos - Birchwood Casey Brass Black.
Druxey, thanks for the new info about Yellow Ochre". Must try that soon.
One problem I had was transferring the heat in the right direction due to the round surface, another was the thickness of the pipe compared to the smaller pieces. My Micro Torch was inadequate for the job of soldering the two pieces of pipe together, and I had to resort to my "big" torch (see below) :
I kinda figured the big fella would have made a brass puddle out of the slides and handles rather rapidly :huh:  .
:cheers:  Danny
Cheers, Danny
Dan,
very nice progress. It's allways a pleasure to read in your log.
Regards Christian
Danny,
    I also will be waiting for the tutorial. Keep the pictures coming. Love the work that you have done on such a beautiful ship.
Wacko
Joe :D
Go MSW :) :)
Incredible work, Danny! very fine gratings, and the Galley Cowl looks terrific! WOW!
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Just dropped by to see the development. And then my jaw dropped to the floor. Darn!
What a fountain of knowledge and craftsmanship you are.
Rafael.
Built:
-bragozzo http://modelshipworld.com/index.php?/gallery/member/867-artitec3/
-leut by MiniMamoli
-passenger boat by Artitec (resin kit)
Current build: paranza fishing boat (of the Adriatic) by Corel
On the shelf: Gulnara by Krick
I am enjoiying your build.......and fine work indeed.
I use my hand held micro torch and flux core silver solder to do all my soldering......you did a good job for sure.
What agent did you use for blackening/pickling?  I use gun blue on all my copper and brass and it blackens it up nicely and in short order.
Great log.
Rob
Current build:
Finished build:
Current build(On hold):
Nice work Danny.  However if you take a look silver solder comes in different temps dependind on the job.  If you go to Sante Fe Jewelry Supply and check out there website you will find them.  A jeweler will now and then use 2 different solders on the same piece.  Both are good just a few dgrees diffrence in melting point.  I have done hard soldering as well and I have found that after you solder a joint the melting temp has risen so you can solder close or next to it with out too much trouble.
David B
Thanks again Christian, Joe, Alex, Raphael, Aldo, Brian, Dave, Rob and David for your kind comments and words of advice :) .
Rob, I use a silver solder paste - medium melting point. For the blackening I used Birchwood Casey Brass Black which I bought from a gun store - similar stuff to the one you use I guess, but it doesn't work on copper unfortunately. It blackens it, but the black rubs straight off again :( .
David, I was aware of the different melting point grades of the solder paste. I only have the one at the moment (medium), it's not cheap (about $25.00 per tube but it goes a LOOONG way :) ) and I have to import it from the US - as I don't have a lot more multiple joint soldering to do on this model I'm holding off on getting any other grades for a while.
:cheers:  Danny
Cheers, Danny
Breast Beams
The aftermost beam on the Forecastle and foremost beam on the Quarterdeck are known as Breast Beams. These are shaped differently to the other beams in that they have a rabbet to accept the ends of the deck planking and a molded spurnwater on the top edge. There is also a decorative molding beneath the outer edge:
The beam was originally made from heavier stock in one piece to add strength to the edges of the decks. I chose to make them from three pieces - a "normal" beam, the rabbeted top and the molding. When all glued together there is no difference apparent as the joints are hidden.
To cut the molding I filed a scraper from a square ended Xacto blade :
To attach the moldings I used a High Strength PVA glue named Rapi-Bond which I found recently. This stuff sets almost as fast as thick CA, and has a lot more bond strength than the Fullers Maxbond I've used to date :
Some pics of the moldings being fitted :
:cheers:  Danny
the fore
Cheers, Danny
Thanks John,
It sets enough in about a minute or so to no longer need clamping, even on these pieces which I didn't bother soaking first to follow the deck roundup - in fact for a few other flat things I did earlier I just held my fingers on the piece for a few seconds instead of using clamps at all :) .
It's just a fast-setting PVA, so I guess it's as chemically stable as the normal stuff.
:cheers:  Danny
Cheers, Danny
Gee, thanks very much everyone :) .
I'm stunned, especially by the wishes from guys and gals I haven't had much (if any) contact with on my build log. I didn't realize there were so many following it.
EDIT - Sorry to all who posted Birthday Greetings, but I've deleted them (about 3 pages worth :huh:  ) to free up a bit of room on my build log. No disrespect intended to anyone, and thanks again for the wishes.
:cheers:  Danny
Cheers, Danny
Almost all of us have been following since the very first post. I know I have, and I have learn a great deal because of this build. So don't think for one minute that we have not been watching and learning from you.
Wacko
Joe :D
Go MSW :) :)
if anyone doesn't learn something from you.......then they're missing out!   I find it very hard,  to look at a build,  and not come away some idea or another.   I watched you builds since the day I came here Dan........I am totally convinced that I will NEVER aspire to your level.
your THAT good!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
What hasn't been said about this build?...Impressive! :)
Not only envious of all your toys but mostly of your talent.  :piratetongueor4:
Thanks for your time and effort in sharing.
John
Edited by Redbeard
John   B)
Current Build: MSW 18 Century Longboat 1:48
Next Build:    MSW Bluenose 1:64
Thanks again Joe, Brian, mhegazi, Sonofagun, Steve, Guy, Popeye and John - it's nice to have this kind of support :) .
Hi all,
Not much progress to report on Vulture lately. I've been busy for the last couple of weeks - I reconstructed my Build Log of the "Norfolk Sloop" which was lost in the Great Crash (there's a link to it in my signature below for those of you who didn't see it first time around).
Only thing to report is the fitting of a half-door and light in the forecastle bulkhead. These are conjectural on my part, as there aren't any details of them on any of the NMM plans or in TFFM either.
I've made the light swing upward for ventilation alongside the galley stove. The lower part of the door swings away from the stove to allow the anchor hawse to pass through the bulkhead when being winched in or out.
:cheers:  Danny
Cheers, Danny
Nicely done, Danny.  Why did you make the light swing upwards instead of sideways?
John
Thanks John.
It wouldn't have swung toward the stove - too close for comfort. If it swung the other way it would interfere with the door alongside, so the only way I could see it swinging was upward. That way it could be left open for ventilation without getting in the way of anything else. The lower part of the door would only have needed to be open when the anchor was being raised or lowered.
:cheers:  Danny
Cheers, Danny
Hi Dan, I have just now discovered you log. Somehow I guess I never found it when scanning the site. I am totally fascinated at your skills and abilities. Quite a project and I'll be following it closely.
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Hi, Danny. I see you've been busy in my absence, building like there's no tomorrow! AND got yourself promoted to Staff, well done.
Speak soon
aitch
I am speechless. Your work is absolutely amazing!
The attention to detail is phenomenal.
I will be watching in awe as this build progresses and could only dream of learning a few basics from you.
Current Build - US Brig Syren - Model Shipways - 1:64 - 1st wood build
Armed Virginia Sloop with complimentary 8x paint MS paint set - Model Shipways - Ordered 31st October 2013
Victory Cross Section - Corel - Ordered 15th October
