Bob, this is fantastic! The rigging for the phily is very basic. As leclair stated, with your skills it will not be a problem
Current build: Model Shipways “Confederacy “
Completed builds:
Mamoli “Royal Louis“
Mantua “Royal Caroline”
Scratch 1/4 scale gondola “Philadelphia”
Scratch “Hannah” from Hahn plans.
   That is one of the reasons I selected the Philly, and also (next on the bench) the MS USN Picket Boat. Simple enough rigging that I can use to learn on, and since they're both 1:24 scale I can have some symbosis action going on between them. After these builds are completed, I'll probably try a real "big boy pants" sailing ship.
   Thanks for the (as yet unearned) votes of confidence on the rigging. As I've said before, there's so much good info and helpful people on the forum that will help me muddle through this... I'm actually looking forward to it!
Bob Cardone
On the bench:
Gunboat Philadelphia Model Shipways 1:24
CSS Palmetto State Verlinden 1:200
Next up:
USN Picket Boat #1 Model Shipways 1:24
Completed:
F-4 Phantom Hasegawa 1:48
Smilodon Fatalis Unknown manufacturer and scale
Panzer IV 1:32 Unimax/ Forces of Valor prebuilt with mods, diorama
FINALLY!
   The base is done, and ready for the resin water pours. Two more sunny Florida days and it'll be dry enough for the resin. The trees, grass and foliage will be done after the water. I've got the dams cut for the front, left side and creek areas, and will be using Tyvek tape on the inner faces of the dams (resin doesn't stick to Tyvek, and if the tape is applied without wrinkles, will leave a nice, smooth clear surface). After the dams are in place (and securely sealed from resin leakage), I'll apply a "wet coat" of resin over the whole area that will be underwater. That way I hope I can catch any errant bubbles that are guaranteed to come out of the river bed and stone work, and get a feel for how this brand of resin works (Dr. Crafty from Amazon).
   After the wet coat, I'll be pouring to a final depth of about 1.25" I'm going to do about 3 to 4 pours, with the first ones tinted with a bit of green and brown mica dyes. That will add some murkiness and depth, with the rest of the pours clear. To simulate ripples atop the final pour, I'll use ModPodge gloss medium, worked with a brush and by blowing on it through a straw. There's tons of good videos on YouTube on how to do this.
   The tricky part is when the pours reach the bottom of the hull. The plan is to have the boat removable after the pours are done, so I'll have to "resin-proof" the hull. I'm going to use Tyvek tape and maybe some Pam cooking spray or Vaseline to make sure the boat will come out cleanly. I left myself a "get out of jail free" option by drilling three 5/8" holes in the black boat support piece on the base. That way if the hull sticks, I'll at least be able to push (tap...pound...I hope not) up from under the base at the bow, amidships, and stern to free it. When I do my wet coat, I'll experiment with different ways to resin proof the hull. I've never embedded anything this big, should be a real adventure....
Here's some shots of the Philly gently run up on shore... The final waterline will be about 3/4" up from the bottom.
Here's three shots of the base with all terrain forming and paint completed (I can't wait to get the water done, I'm so over working on this base...)
Edited by BobCardone
Add pic
Bob Cardone
On the bench:
Next up:
Completed:
I hope you put a bit of tape over the holes, just in case......
Copy that! Otherwise, I'll have a nicely resined workbench...😆
Bob Cardone
On the bench:
Next up:
Completed:
4 hours ago, BobCardone said:
The plan is to have the boat removable after the pours are done, so I'll have to "resin-proof" the hull. I'm going to use Tyvek tape and maybe some Pam cooking spray or Vaseline to make sure the boat will come out cleanly. I left myself a "get out of jail free" option by drilling three 5/8" holes in the black boat support piece on the base. That way if the hull sticks, I'll at least be able to push (tap...pound...not) up from under the base at the bow, amidships, and stern to free it.
Fantastic diorama and I love the creativity of your "get out of jail" option!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Hey all,
The pours have begun!!!
   First, I put the resin in a sink full of hot water and let it sit for about an hour. I attached the dams, and Tyvek'ed the boat and dam sides. Then I put the base out in the sun to get good and warm. After everything was nice and toasty, I got all the stuff ready for the pours. I attached the boat to the base with three screws to keep it stable. Don't want it to float away!!!
IMG_20200417_104601.thumb.jpg.821bbd39ae0c70a545526c17f0b1680f.jpgIMG_20200417_104304.thumb.jpg.af707869fad5bc01af93a50d8c688cb0.jpg
   I started at 9 AM, hoping to get at least three to four 1/8" deep pours done. Most 1:1 epoxies (if it's a warm day, it's 80 deg F here, and sunny) can be re-coated in about 2 hours, so I hoped I could pour to the bottom of the rudder today.
   The rudder is a separate challenge, as I will have to cut off and embed the part of it that will be under water. I'll drill locating pins in the resin and also the upper part of the rudder so everything will align properly when the final pours are done tomorrow.
   Here's the procedure I followed (from the brand I used, but the method is similar for most 1:1 resins). First, I mixed up 4+4 oz. of resin to use as a seal coat. Measure by volume, and stir until the mixture is no longer milky. I then used a disposable brush to apply the seal coat over all the base that would be under water. I did find one small leak in the lower front corner, easily fixed by a toothpick pushed into the gap. When the seal coat was tacky but not sticky (use a cotton swab... if it tacks but doesn't pull cotton away it's OK for the next pour). For my first flood pour, I mixed 8 oz. of resin and tinted it a tiny amount with some green and brown mica powder. I poured some resin in all four corners of the river bed, and evened it all out with a craft stick and toothpick. I was lucky, the seal coat worked well and because all the materials were quite warm, I didn't have any major bubble trouble. The ones that did pop up were easily removed with a heat gun.
   Doing four more 8 oz. pours, I was able to pour up to the bottom of the rudder (total pour depth so far about 5/8", or half way there). The resin is hardening nicely, even and smooth. The base did get pretty hot as the resin set, but it's cooled off with no apparent damage to the boat. The part I'm apprehensive about is the boat sticking to the base. In a few hours, I'll attempt to remove the boat, we'll see if all my precautions worked... (fingers and all appendages crossed...).
   Here's some shots after today's pours:
Bob Cardone
On the bench:
Next up:
Completed:
Hi all,
   Final pours done. The draft ended up about 3/4", and the total depth about 1-1/4". I ended up using the whole gallon, about seven pours total. To facilitate handling the boat, I removed most of the furniture and cannons. I was lucky... the Tyvek and Vaseline trick worked, the only moderate resistance when I removed the boat was some suction (probably the Vaseline). As the final coat set, I poked and prodded it to simulate ripples and swells. After the resin finally sets (about 72 hours) I'll start with the gloss ModPodge to detail out the ripples and edges of the resin where it meets the boat. After that, I'll add the soil, foliage, trees and grass and touch up where the water meets the shore.
   Now that the hull is finally fitted to the base, I can start completing the boat. All the furniture, masts, fittings and cargo are done, and just need attaching. After that, I'll start rigging. I'm so happy to have achieved this milestone, I was so afraid the boat would be permanently stuck to the base... that would have been very bad...
Here's some pics... I like the sun reflections off the water on the hull.
Bob Cardone
On the bench:
Next up:
Completed:
Simply outstanding, Bob! If I ever do a diorama I'll know who to ask to get advice.
Did you use the green and brown mica powder in the first pour only? Does the powder dissolve and tint the resin evenly?
I like to make didgeridoos from raw logs I have collected and cured. After rough shaping the log into the shape of the didgeridoo I want, I split it down the middle and carve out the inside. Then I glue the two halves back together, sand down the outside of the didge and then coat the inside and outside with resin. It's always a crap shoot to see what musical key the didge ends up being!
I have a couple of nice logs that have a big cracks in them. I've seen didgeridoos made when the craftsman filled the crack(s) with colored epoxy resin and they looked great as a highlight to the didge. I'd like to try that so I'm curious as to what is the best method of creating a deep, clear color in the resin. Are these powders that you use the best way to go or wood something like food coloring work too?
Thanks, Bob.
Edited by BobG
Bob Garcia
Current Builds:
Thanks, Bob! Dioramas are a lot of fun and can really complement a model.
   I've found that mica powder is the best for tinting about anything. It's very concentrated and finely ground, and blends evenly. I got a set of 24 tints, I used the middle two in the picture on the first pour only. I did most of my pre-shading of the riverbed beforehand with paint, washes and dry-brushing. I wouldn't use paint or food coloring, you might get unpredictable results with the resin not hardening or fish-eyeing. Mica powder comes in some pretty crazy types: sparkle, pearl, candy, metallic and a lot of colors. It's pretty cheap, and it's so concentrated it'll last forever.
   Very cool! The mica tints would be perfect. There are tons of good YouTube videos of people making "river" coffee tables that use graduated tint techniques that would apply to your didgeridoos. You have some very interesting hobbies, Bob... If you're didgeridoos are anything like your Medway Longboat, I'll bet they're sweet!
Bob Cardone
On the bench:
Next up:
Completed:
What about the rudder?  It doesn't look like you left a space in the water for the rudder...or am I missing something?
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Rudder fail. I originally cut the rudder even with the waterline, with the intention of pinning the underwater part to the base and then attaching the top part after the last pour. I pinned it to the bottom, and of course after the first 3/4" of pours it floated loose, totally soaked in resin and unusable. Now I have to wait for the resin to harden completely and then rout a groove for the bottom of the rudder (of course I'll have to make a new piece). Oh well, this was the only real problem I had, and with some effort I think I can make it look right.
Bob Cardone
On the bench:
Next up:
Completed:
That looks great, Bob.
Here's a video of this amazing guitar...
Bob Cardone
On the bench:
Next up:
Completed:
    Chuck, it was a real bummer when my rudder "floated away" but I'm not easily deterred⚒️  I cut a groove with a rotary tool for the underwater part of the rudder, and made a piece stained and nailed like the original. Here's the original, forever attached to the lid of my Durham's can.... R.I.P.
   I plan on embedding the new piece, and I'm testing both resin and ModPodge gloss medium as the filler on a part of the resin pour under the boat (won't be seen, great place to experiment). I embedded a small piece of hull color stained wood in each test, we'll see which one comes out the clearest and blends the best. I believe with some effort I can overcome the rudder fiasco with little visible evidence.
   I hate resin fillets. You know, the part where the resin "creeps up" any vertical surface it contacts. I believe they really ruin a lot of water effects I've seen, so I take special effort to remove them. If the resin was mixed properly and is fully cured, it takes machining, sanding and polishing very well. You can tell it's OK to work with if you get white powdery dust when sanding. For the fillets around the edge and the hull, I used a hobby knife to cut off the upper part and then started wet sanding at #240. Once the fillets were leveled with the main water surface, I wet sanded in order -#400 -#800 -#1200 -#2500 grits to remove tooling and sanding marks. Once all the edges are finished, I'll use some polish to get rid of most of the remaining haze. I'm not too concerned with a "wet gloss" finish at this stage, as I plan on coating the whole water surface with gloss ModPodge so I can do the final shaping of the water surface and where it meets the boat and shore. The nice thing about gloss ModPodge is it dries "wet look" and is very forgiving to work with.
   Here's some pics of the rudder groove, the piece partially inserted and the right edge fillet sanded down to #2500. Don't mind the cloudiness, that will go away with polishing and gloss medium later on.
While I was at it, I made some elevation corrections. The path on the lower right would have been underwater, and I needed a flatter surface in the upper left corner for a big tree.
Add pics
Bob Cardone
On the bench:
Next up:
Completed:
13 hours ago, yvesvidal said:
I understand your worries and anxiety when pouring the resin. I went through the same things, when adding the fuel tanks on my submarine.
Resin is funny stuff. I've had problems I didn't expect and success where I expected problems... That's what it's about... learn as you go and be adaptable.
Bob Cardone
On the bench:
Next up:
Completed:
I decided to use resin to embed the rudder bottom. Filled the slot half way with an eye dropper, than inserted the rudder slightly below the water surface. Added resin until it totally covered the slot and rudder piece. Seems to have worked out fine, I can't see any signs of the edges where I cut the slot. Next is to finish sanding the water and hull edges.
Bob Cardone
On the bench:
Next up:
Completed:
Hi all,
   Well, had a major failure in the base water resin. Delamination all along the front edge between the first and second pour.  It's still structurally sound, but there is a very visible series of air pockets that go about 1/4" horizontally into the water, they look silvery in this pic (under the sanding marks)... I spent all week trying to fix it, but it's there for good.
That foils my plan of having the front of the base displayed with the water visible. I guess I'll just box the bottom 2" of the base with the display case I've designed. The good news is the rest of the base is done, with just one very thin coat of resin left to blend all the sanding marks.
   Here's the state of things... Poor Philly is stripped down, dusty and tired of being handled so much and so roughly. But no more! all the rough stuff is done and I can start putting things back together and moving on to new construction.
Bob Cardone
On the bench:
Next up:
Completed:
Thanks, I appreciate the support!
   In retrospect, I "went down the rabbit hole" on the base, and lost focus on the main project. I'm guilty of what the military calls "mission creep"; adding features that compromise the objective with little added overall benefit. I've decided to put the base "on ice" for now and get back to the boat. The existing base may be salvageable, or I may make a smaller and simpler version. It is frustrating, but it was fun building it and I won't let some problems take away from that fun!
   I'm rearranging my workshop, so there won't be much progress over the next week or so. Not to worry, this will NOT be a necro build log. Slim (and Snowball) just won't let that happen...
Bob Cardone
On the bench:
Next up:
Completed:
Hi all,
   It's been a while since any progress on the Philly, but the workshop is finally clean and organized... Mr. Snowball and The Nipster supervised, and then advised me to get back to work on the boat.
   I finished out the water as best I could, still have some delamination on the front but after sanding and polishing it's a lot less noticeable. Here's some pics as it stands now, and with the workshop revamp completed work on the boat will resume at a faster pace. Next will be re-attaching all the guns, deck stuff and other things removed to make the water pour easier. If I did it over again, I would have made the base much smaller and less complicated. Building it really set me back on the boat construction and made me lose my primal focus. As they say though, in for a penny, in for a pound...
Bob Cardone
On the bench:
Next up:
Completed:
It sure looks good to me, Bob. It seems to me, that for a diorama with a boat this size, you wouldn't want a much smaller diorama. Of course, the boat is so well done it would display beautifully just on it's own too.
By the way, it looks like you have enough amp power in your workshop to hear your music even with the shop vac running! How has your hearing faired over the years as a musician? Between working in the engine room of the Coast Guard Cutter Storis without ear protection for 1 1/2 followed by many years of listening to music at much too high a volume, my hearing has suffered a bit. Oh the follies of youth...!
Bob Garcia
Current Builds:
