Well this is the one that started the bug.... I was gonna wait to start this but I’m waiting for stuff on all my other builds... I am going to build this with the aid of the Airfix magazine builds by James Hatch and Brett Green, leaning more to the Hatch version specifically.....  so here is the start of the cockpit- it looks more weathered in person, I’m finding that weathering silver/aluminum is more difficult than greens and black.....looks like I need to sand and fill some pin marks on the seat, I thought they would be covered by a seat cushion but not on this version? There is definitely a lot more flash/cleanup to do on this kit vs the 1/48 Airfix kits I’m doing. Any input or suggestions are definitely welcome!
Edited by ASAT
Compliance
Work carefully cleaning up the flash, some of it may be attachment points for other parts. I use an #11 blade and a number of various grades of sanding sticks for cleanup. I use Vallejo putty to fill gaps, as do a number of the other modelers on this site.
Ken
Started: MS Bounty Longboat,
I found that out the hard way, lucky it still fit ok... that is one area where the airfix instructions are lacking, it doesn’t always show clearly where everything attaches. I thought I cleaned up the parts on the areas that will show, but the camera is pretty brutal at showing flaws.... need a bit of work in a few areas
perhaps a a trimmed piece of thin leather would cover them over.  nice start on the air frame :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Well, I worked over some area’s and have all the cockpit stuff done except for the instrument panel.... waiting for the airscale decals for it.... started work on the Napier engine, filling in a couple huge pin marks that will be right on top of the Sabre motor....
That looks really nice  - so much detail.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Looking fantastic Lou. You certainly know how to get up and move along in a build!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
That's coming along nicely.
Remember that this kit has very tight tolerances when it comes to closing up those frames in the wing and also the fuselage shell sections. Triple check that underside of the fuselage so that it cleanly closes up along the panel line. I checked the various subassemblies inside the fuse/wing, as often as I could.
Ongoing:
Thanks James, whew! Had me nervous for a bit there, I pulled out hose pieces, cleaned them up and the fit is great so far... still not sure how I’m going to tackle the canopy turtle deck area, I want to clean it up and re scribe and rivet but I’ve never done either of those things before.... gotta be easier than grafting in a whole new panel though....
Here’s the main block and supercharger of the Napier motor - just dry fitted and some initial dry brushing to accent the detail - there are little bolts there that I didn’t even see till I started brushing! I’m having a blast on this motor! I hope I still do when I start doing all the pipes and wiring - looks pretty hairy!
Edited by ASAT
That looks  really nice   so much detail at this scale.
OC.
Current builds
Completed works.
24 cylinders with two spark plugs per cylinder... I'd sure hate to be one changing spark plugs.
Glued on the supercharger and got the motor installed, quite a bit of plumbing to do and some of them are like those old ring puzzles.... got to twist and finesse them into place - a bright spot light would help to see some of the termination points hidden in the interior of the maze.... 😅
Edited by ASAT
That is really quite an engine Lou
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
I agree Lou, it’s one of the things that attracted me to the model, that and the air intake, reminds me of the A7-E’s that I worked on in the Navy....
I have always thought that the Tiffy's big radiator intake gave it a particularly hulking and menacing look. My card modeling interests lean toward the interwar years, but I think that I might one day have a slot in my queue for a Typhoon.
Yep, it would be a perfect platform for a shark’s mouth graphic....
very nice progress Lou........engine is really neat!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Did some more engine work, the ignition harness to be exact, there was a plethora of flash/mold lines - itty bitty little tiny lines that stuck out like a sore thumbnail? 😁Took quite a few hours to get them ready for paint, lots of fine work mostly with a #11 blade. Tried to emulate some of the Napier Sabre engine harness on google, seems like the main tubes are aluminum but have been heat soaked and discolored yellowish, the leads are kinda magnesium looking and the spark plug boots are brass. Washed it down with some engine weathering paints from AK interactive.... came out pretty good!
On 4/13/2020 at 6:47 AM, Beef Wellington said:
Looks great Lou, how much of this detail will be visible - I hope lots!
Hi Jason, just saw this post again.... they give you several options to show detail - the one that shows the most has the whole nose de- paneled but I plan on depicting it like JamesH (James Hatch) did for his magazine builds with the port side engine exposed and a couple on the port side off around the intake/radiator.... I know it won’t look as good as his but at least I can impose on him as a resource!😀
EDITIO
EDITIO
Looks nice Lou... That's one big baby....
Figured out where your going to build the hangar yet?
Quote:
