Here goes, first I'll walk you through the building of a single Fokker Dr I - Eduard Profipack. In the mean time I have already built 9, so I'm on my way to a reasonable JASTA (Jagdstaffel) as the Germans would say. I have used multiple brands - Revell, Eduard, Roden - and from some different kits. Considering the number of airplanes I'll be building, it is worth to find the cheapest kits and bash if necessary.
Overall dimensions:
Width wing tip to tip                           10 cm    - 4"
Length nose of the prop to the tail    7.5 cm - 3"
Height wheels to upper wing             4 cm     - 1 5/8"
 Basic kit parts for the Eduard ProfiPack - as OC has written, the manufacturer delivers very nice kits to work with
1628066451_IMG_2798copy.thumb.jpg.6128ace4becff00d76825159f9843bfa.jpg924662162_IMG_2749copy.thumb.jpg.35bc12ffacee1511ea08e329b9a98481.jpg
I start to cut off all excess parts, and split the main sprue in two pieces, which facilitates handling when airbrushing. After that, I remove as much attachment points as  possible and sand any irregularities down. Some parts can be painted off the sprue and are taken off
Prepare for some preliminairy work
745007580_IMG_2799copy.thumb.jpg.3eb0070f011491f889022a3fdda12d2d.jpg12270543_IMG_2800copy.thumb.jpg.f6052391a38c366da59ddbc2d964efee.jpg
The "cockpit" must be prepared before priming the fuselage, since the example is a Profipack, I got some PE thrown in, which, at this scale, hardly shows, some close ups  ...
836778960_IMG_2801copy.thumb.jpg.b773cd1ba36f759559ea1be23a16b81d.jpg1326973768_IMG_2806copy.thumb.jpg.51802bb955bdd2f3c0ec70c2e98fa203.jpg622653997_IMG_2807copy.thumb.jpg.d989f35196d853d7597b05fcec913092.jpg910159687_IMG_2808copy.thumb.jpg.c5ba3c9b4bbbaa52c1eadbb6be057a37.jpg1189742494_IMG_2809copy.thumb.jpg.f8097d058b77953686b36c73df06a98c.jpg92049364_IMG_2813copy.thumb.jpg.10dd017e78b864f92dff8ab8cf133a30.jpg1363721798_IMG_2814copy.thumb.jpg.19fbbc9a5e6a6f0e1755cd87be8c828f.jpg
Prep for priming
Priming in white and grey, as the airplane will be camouflage green and white, from above, and baby blue and white viewed from below
Painting the wings. Someone asked me if I could show it, well I tried, it ain't easy to make a video whilst painting
Paint and brushes used
https://youtu.be/kKYMGta6-CE
Next ... tomorrow. Some shooting to be done
Edited by cog
Carl
Count me in mate  love these eduard kits  - is it my imagination or do they feel a bit more solid than other makes  (my spit feels more solid than the ICM version).
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
I'm in....  at 1/72 those must be tiny.
I"m here, still hunting around for my pocket microscope though....... ;-0
Quote:
love the Fokkers........I have two that both fit in the palm of my hand :)   watching and waiting  👀
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I know someone will ask... so I'll do it first with apologies to Charles Shultz.  At some point will there be a little flying dog house with a beagle sitting on top yelling "Curse you Red Baron"?
that would be great if Carl was building Sopwith Camels ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
At 1/72 the wingspan must be only about 10cm / 4‘‘ ! I could only do that with a magnifying glass attached to my head. Nice work.
HM Brig Badger 1/48 from Caldercraft plans
Le Coureur 1/48 by CAF
Completed Build:
Armed Virginia Sloop 1/48 by Model Shipways / Gallery
HM Cutter Sherbourne 1/64 by Caldercraft / Gallery
OC, I added the measurements to the first post, and you are right: Wingspan 10cm 4"
Thank you gents, that is most kind of you.
It seems I'll be taking photographs for some time. I cannot seem to get a series of eight where all photographs are acceptable. Lets start with the last Fokker I built ..
892049993_IMG_2916copy.thumb.jpg.1cdd3197205c96627724d5b93cc0b3d6.jpg1859086742_IMG_2914copy.thumb.jpg.6331442723c13a9b8981c72dab40bdc8.jpg664646257_IMG_2913copy.thumb.jpg.ff132496dc6fd3f753dfe4c3d8bca8cb.jpg720562968_IMG_2922copy.thumb.jpg.8a610989cfa2af0d0f9163e79e94fe92.jpg873993762_IMG_2920copy.thumb.jpg.63c0cc08dede439a1bb974952f27e171.jpg1355808535_IMG_2918copy.thumb.jpg.560a021f9820c91765e5da5e3b78df22.jpgIMG_2915 copy.jpg512866752_IMG_2917copy.thumb.jpg.785effec91b9b220c8a670769bca122c.jpg
Edited by cog
Carl
Not much room left but I will certainly be looking from somewhere. I'll try not to step on any toes.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Oh gents, I do have a Sopwith Camel ... slightly out of scale (1/32) but never the less a Sopwith from Wingnut Wings, "hidden" in my stack of kits. Unfortunately discontinued at Eduard in 1/72, but then again, who did see Fly boys? There is a Nieuport in the proper scale
Carl
Well, this one was worse. The missing photographs ... I just couldn't get them right. Changed lighting, changed ISO, changed image format, changed about all the logical things I could think of (naturally that is very limited, considering my brain's capacity ;) )
No exisiting camouflage. Used the pattern from the Fokker VII from Ltn. Hans Kirschstein, Jasta 6
811046267_IMG_3006copy.thumb.jpg.26075fb4084fe8c026c2e195c3e044e1.jpg423753113_IMG_3005copy.thumb.jpg.f3e7da2aba440032a885ffe7ea3a2eab.jpg1425956127_IMG_3001copy.thumb.jpg.50ca79a1a5726c48c52ff9de50bec67a.jpg1709497222_IMG_3003copy.thumb.jpg.8b5d20b4375baad847594ce32468b1ce.jpg1681910142_IMG_3002copy.thumb.jpg.e9969e0e75b1533cc4b3980e0f7912a2.jpg957015111_IMG_2991copy.thumb.jpg.7ef7d79b30de9344e635541753d828f7.jpg
Edited by cog
Carl
Possibly it was the camo doing it's job and fooling the camera.:D Still some striking models by any measure, the camera doesn't know what it is missing.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
They look perfectly fine to me Carl..... to both my Mk1 eyeball and through my pocket microscope....
Nice work on a difficult color combination....
Edited by Egilman
Quote:
17 hours ago, mtaylor said:
at some point will there be a little flying dog house with a beagle sitting on top yelling "Curse you Red Baron"?
But the Baron shot him down--'CURSES, foiled again!'......
Quote:
Wonderful work, Carl.
Yea, I get to see the real deal every Sunday afternoon during summer months :D  Black Baron in his DR I vs  Sir Percival Goodguy in his Sopwith Camel.  Kids love it.
I agree  completely  - this is superb work  of small subjects at a small scale  - not much room for error, they look loverly mate.
OC.
Current builds
Completed works.
2 hours ago, Jack12477 said:
Is that a flying zebra ?;):D
Nice painting, Carl.
No ity's the flying French cruiser Gloire
2 hours ago, Canute said:
Carl, they are little gems. Well done.
Thanks Ken. Never knew gems could fly, you learn something new every day at MSW ;)
Must have been, on of those photographs even fool my eyes (3rd one)
Thanks, explain the pocket microscope action to me. Tried it with mine, but it doesn't work on the screen I've got
Much apreciated Mark
OC
Enough margin for error, you just do not see it as readily as at a larger scal
Edited by cog
Carl
You had to get the one that came in the wheaties box, the one that came in the crackerjack boxes was a cheap knock off....
Quote:
Looking good Carl. That striped pattern on the top surface of the 2 bottom wings is impressive. Watched your video, impressive !
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
