thanks Jav.........and all who are following along.   I'm gonna try and do something I haven't done in a long time.  I've done some painting..........kinda bland,  but the plane is totally green {going by the suggested paint scheme}.   I'm sure everyone love to put in the small windows :rolleyes:....personally,  I hate 'em.  before I started to use window maker,  they always ended up cloudy looking.......a result from using cement.  the window maker doesn't do that......but I read that it could be used to fill in the small windows as well.  since this is a menage of small windows,  I thought it would be a good practice to try.
487189524_1.jpg.cc5b57a8cfdd84c53aacd964b9bd2785.jpg  1916234436_2.jpg.b205fb317b337acc63344580c2d058fd.jpg
these weren't too bad.......I have a little touching up to do.   I did the other side and had a terrible time.....I had to remove a couple.   it could be a slow process.  I looked for a video on this,  but I wasn't satisfied with the method shown.   I should have more on this soon.  thanks for the kind comments and for looking in :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
small update coming up....... ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
as promised :)   I did some work on this .......uuhhhhh...beauty :wacko:   the wings are painted and are now in place on the fuselage.
pay little attention to the ghosting........there will be some fading done on her later.  as mentioned,  I wasn't going to,  but I kinda liked the tire fenders,  so I added them.  again,  I had to adjust the locator holes to accept the parts better.......a little tedious to begin with.
later on when dried,  they were painted.
the assembled engines were painted flat black,  then dry brushed with aluminum
other parts were painted too.
I didn't even bother to look for a masking kit for this model........so I took to painting them freehand.
that's as far as I've gotten.........hope to have more soon :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thanks Ken..........I've seen a few others that look pretty interesting.  I stand corrected though........I was looking for images so I could get a good idea about the cockpit glass,  and I saw that eduards does a masking kit for them.  I got a few other cool decal ideas too.......if these decals don't look good ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
while I'm here........I may as well show a bit more progress on this corrugated beauty.   the tires and covers are added to the model........now to get the tail gear painted and in place.
the gear assembly is kinda interesting......like it's on stilts
....and with it now painted....looks much better
now that I have some pictures.........  I thought that this was an obscure aircraft,  and wouldn't have to many pictures of it.   part of it is true.......actual pictures are rather scant,  but there are many pictures of the finished model.  now that I have a better idea of how it looks........
I'm fairly satisfied with the dry fit.
now to let this dry fully........on to the engines :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Really  nice build denis  and the paint finish looks really good.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Yep the Soviets at that time were pretty good at building crates with wings and getting them to fly....
Your replication of the look Dennis is superbe..... (particularly that weathered swamp water green paint, great stuff)
Looking good!
Quote:
:D  :D  that swamp water green is Olive Drab {you'd think I cornered the market on the stuff}.   I have the feeling that by the time I get to the B 25,  I'm going to be burnt out on Olive green...........Navy comes to mind :ph34r:  come right down to it,  it's actually a French plane,  flown by the Czech Air Force.......they collaborated to build this plane,  an obscure contribution to 1930 aircraft.  I do have a few more progress pictures.    thanks for the kind word Eilman and OC.........thanks also for all the likes :)
I assembled the engines 327574141_1.jpg.2b1e1ca28a2ad1d1e26d08449fcb4c7d.jpg
and then added them to the model
the exhaust is ported out the bottom
I did a little detail work to the instrument panel....what I could see,  and added it.  the sticks {steering wheels} were added too.   the cockpit glass was added to finish it off.
the glass in this model is not very good......I should count myself lucky that the frame work detail was there for me to follow.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
here is some more progress........ :)   I add some of the decals from the ill fated sheet.   I tipped the blades for the Memphis Belle props and I continued with these.
next was the tail gear........it now has support from all three wheels.
for the underbelly,  I set up the bomb racks.  I was short one of the rack arms,  so I will be one bomb less.   I will use CA to fill in the holes.  also added are some of the antenna apparatus....a couple more parts will go topside.
I got home this evening and for fun,  fitted the props.   I still have the nose glass to do.........I abandoned the window maker.  there's a bit of a mess inside the fuselage.......glad that it won't be seen.  clearly I need to practice to get the ability back ;)
I also cemented the belly turret in place
I wish you all a super duper Father's day! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I got into a frenzy with this model........but first I had to back up a tiny bit.   I removed the turret platform from the front of the fuselage.   this way,  I was unobstructed installing all the windows.
I would have continued with the window maker.....but I was a little rusty with the process,  and I felt I was getting more inside the fuselage,  than filling in the window openings.  the first four were done........sanding the flash from around the panes and making sure they would fit OK........
2120775_2.jpg.4139397beb70c1b04c8daf381cf32bcc.jpg 292566997_3.jpg.e7c9543f8c827e012dfe4d73a11dd5d0.jpg
the six front panes were next....the bottom center window was the worst one to fit into place.  it was also good that I removed the platform too.......I was able to repair the gap along the top border.
1158251654_4.jpg.72c449801e31bca952b1c434d8ddf7d0.jpg 324355161_5.jpg.b69f83c368c66f8becb15f0e752d425f.jpg
2052087231_6.jpg.72d08fa1333320b788ae431446b8b496.jpg 651122032_7.jpg.a06adcce4e6403897da79fc8897d93c9.jpg
I do need to touch it up some....... I removed some of the window maker that had dried around the frames.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Looks fiddly all those windows   - its always a sticky area.
OC.
Current builds
Completed works.
Window maker was engineered for just such kits.....
Can you imaging trying to do all those in plastic?
Nice job my friend...
Quote:
it was time to work on the decals.....I had put them on a window sill a couple of time,  to see if the sun could bleach out the yellowing.  this was fairly successful.....good enough to use them.  the one thing I was concerned with,  was becoming brittle.  if they weren't useable,  I'm sure I have some I can scare up.  I began with the wings......
they conformed to the ribbed wings rather well.......I didn't need to use decal set {Testor's} to soften them.
after the decals were applied,  all the small loose parts could be added......the props,  the bombs,  the antenna brackets.   the antennas were strung with the thin wire I like to use.  it's pliable and could be adjusted to straighten it.  there is the one on the belly,  and there will be one on the top.
this one was a bit tedious........it just didn't want to center itself on the brackets.  two types of radar masts are also shown.......one under the 'chin',  and another near the navigator's station.
well.........looks like there are no more parts...........the model is complete! :)   all that is left is a few small touch ups.  the gallery is next :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thanks Egilman and OC..........this stuff is handy.   I've used it to fill in portholes in ships.......it does have some limits though.   if the opening is too large,  it won't work too good.  I used to be really good with it.   commercial airliner models and HO really benefits from the use of it ;)
thanks for all who hit the like button :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
here's the gallery of the model.  it's really wasn't a terrible model.......some holes needed to be drilled out,  flash wasn't too bad,  and fit was reasonably good.  the clear parts is about my only dig.......could be better quality.   I believe I mentioned it before.......I found that there is actually a masking set for this model......Eduards put it out.   oh well.......no matter.....I think I did a fair job of outlining the glass frames ;)   the antenna wires were painted flat black,  along with a few touch ups,  and it's now ready to show.   so..........look'in like an early model Volvo, is the MB 200
I hope you enjoyed the build.......thank you to all who followed along.  I appreciate the company! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Awesome work!  Looking forward to the final glamor shots :)
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   CLC Annapolis Wherry  Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Great work Denis. I suspect this will probably be the oddest aircraft in your collection for a while. They were a very strange looking design.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
I'm away for 5 minutes and you go and finish, turned out rather nice as well if a bit odd looking. Great job Denis.
Edit: reminds me slightly of the tri-engine junkers with the prominent ribbing
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Very nicely done Denis  - she came out just fine.
OC.
Current builds
Completed works.
Congrats on a great finish, Denis.
thank you to all for the kind comments :)   odd one for sure.........it's nice when you buy an older kit and it builds well.   usually they are the ones that give the most problems.
indeed Ed.........a Junker JU 52.......got my eye on a Savoia Marchetti SM 81.......an Italian tri-motor that can be built as commercial or military.   I've got my eye on a few others.
Mike.....the glamor shots are the last post I did........if you want to view her in a different setting,  let me know.  I'll post a few more  ;)
that the interesting part Lou.......they built these planes....boxy look'in things,  but you can also see when aircraft design began to get more and more complex,  yet refined.  .....the rounded fuselage,  the more streamlined leading edges of the wings,  and the changes in the materials used...
thanks again for the likes and comments...I'm glad you enjoyed following along :)   I'll get on the Belle........and Kempf's Dr 1.........I'm sure I can scare up something else  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hey Denis
Do you know how to tell an Italian plane in a snow storm?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
16 minutes ago, lmagna said:
Hey Denis
Like a how to tell what sex your snowman is  - snow balls...
OC.
Current builds
Completed works.
Nope, nothing like that OC. Very PG 13.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Can't say that I can...............{can't wait to hear this one  ;) }
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
