Thanks Bob, The speed is a bit deceptive as I don't keep the log up to date as I should.
Also I'm on vacation since before Christmas until the 4th so I've had a lot of time in the shop.
7 hours ago, Blue Ensign said:
it would make a wonderful hull only Admiralty style model
Thanks B.E. You are absolutely correct about it making an excellent Admiralty style model.
If you do succumb I don't think you'll be disappointed.
Also thanks everyone for the continued likes.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
19 hours ago, Blue Ensign said:
I must admit that I was sorely tempted by this kit, it struck me that it would make a wonderful hull only Admiralty style model, I still may yet succumb
Go for it, BE. I would love to follow along as you research and add details to this lovely model.
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Thanks Bob!
The hull was taped off at the water line and painted with a satin white spray paint.
I also added the stern fascia and the PE stern window frames. Everything was a nice fit.
I'm painting the stern decoration and panels and once dry I'll add them too.
Rusty
I'm having Déjà vu !!!
Looking real good and that white area looks flawless.
Ongoing:
😂. Thanks Jim. One question. When you attached the PE details to the out side of the hull what did you use? It's so clean and no glue marks.
Thanks Glenn, Yes I used Tamiya tape and then regular painters tape over that.
Thanks for all the likes too!
Rusty
I used Johnsons Klear (Future) floor polish.
Just brush some in there and plop the PE into position. Wick away any excess and leave to dry for 30 mins. I then brushed some extra over the top. No glue and it's settled solidly into place with no glue marks.
As for using Tamiya tape....don't waste your money. Buy Tesa Tape. Same stuff and a fraction of the price for the quantity.
https://uk.rs-online.com/web/p/masking-tapes/9139532/
Same grade. Same tack. Exactly the same, I promise.
Ongoing:
Is there any long term issues with this method? The results are awesome - is there a link to how/why this works?
Thanks Jim.
I did a google search and it's now called Pledge Revive It Gloss Finish and you can get it at places like Walmart, Kmart etc.
There are a couple of modeler related topics on how modelers use it.
https://ilovewood001.tripod.com/modeling/future.html
http://www.swannysmodels.com/TheCompleteFuture.html
Also thanks for the tip on the Tesa Tape. When I use up the Tamiya.
Looks like a visit to Walmart is in my future!
Rusty
Floor polish...amazing...how do modelers ever figure out all of these unique techniques in the first place?
Bob Garcia
Current Builds:
Nope, none whatsoever!
Just add some to a small brush and brush the area you want to add PE to. Properly wet the area, then add the PE. Use a dry brush to wick away any excess and leave to dry. Seal with another brushing of Klear/future.
Ongoing:
18 hours ago, Matt D said:
How did you plot the waterline for your masking tape?
Thanks Matt,
I used a marker similar to the one Jim used in the picture below. I took waterline height at mid ship from the plans, set the water line marker at that correct height and marked the hull. I then ran my tape to match the marked line. Checked the run from multiple angles and tweaked it as necessary to get a good looking flow.
107.jpeg.7802abd2a71d891ac9808a12e53df37c.thumb.jpeg.b61d1d2bafe432d19a0054fc987f717a.jpeg
Rusty
I've completed working on the stern. The stern decoration has been painted as per the
instructions as well as the PE stern paneling decoration and the upper and lower counter rail parts.
Everything fit really well!
DSC00199.thumb.JPG.e3e75ce8ef39066db2c64a77f4dc5282.JPGDSC00230.thumb.JPG.478483af4facb50b375497e75d2e35d3.JPG
Rusty
2 hours ago, glbarlow said:
that takes a really steady hand
Yes it does Glenn so there was a lot of touching up.I
Hi Bob. Yes I painted the blue first then the gold, touched up the blue, touched up the gold, repeat! :)
Rusty
Wow...what a beautiful paint job! I can't imagine I can't even imagine being able to paint that kind of fine detail without making a big mess of it...
Bob Garcia
Current Builds:
Just catching up with your log Rusty, and like everyone else that's commented I'm very impressed with your work so far, especially your planking and paintwork.
Like you, I enjoy planking decks and when I eventually get round to starting my Duchess I'll follow your lead and raid my stock of boxwood as I did with Speedy. I'm not so hot on hull planking though, and I wonder if that's because I try and complete each strake with a single planking strip? I've noticed that you and many other builders follow full size practice and use several planks in each strake. I'd always thought I'd  have problems with the joints, but do you find that the convenience of dealing with shorter lengths outweighs any disadvantages?
Now that I've found your log I'll follow on with interest.
Derek
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
7 hours ago, glennard2523 said:
Did you soak and bend the stern decoration before painting blue and gold?
Thanks Glenn. I did not soak it as I thought the resin wouldn't get warm enough. I instead clamped it to
the stern and then warmed it with a hair dryer. There was a little spring back but not enough to effect the gluing.
Thanks Bob. I purchased a very fine tipped paint brush just for the stern painting.
Thank you Derek, I find the shorter pieces works better for me. The ends are flushed with a sanding stick and
checked and adjusted as needed. For me the longer strips are the disadvantage.
Thanks everyone for stopping by and all the likes.
Rusty
The horse shoe and fish plates are in place.
I took the laser etched deck and placed it over my deck and marked off and drilled the holes where indicated.
DSC00233.thumb.JPG.4adce8b63753813d2e68bfa47aa1936a.JPGDSC00237.thumb.JPG.866cdb3f17019124c67699ff0627d7d1.JPGDSC00238.thumb.JPG.0c3c3e0a47a5f38b37f1e53e2c38acba.JPGDSC00239.thumb.JPG.428c0deab17ed1d33fdb2da9077d1934.JPG
At the stem the three pieces laminated together left minor seams. I sanded these areas and applied a thinned down coat of wood filler. I sanded that down and painted it and affixed the bow "V" frames.
DSC00241.thumb.JPG.3a60d0307a1ef9b16c7d26c7f1dda5ce.JPGDSC00242.thumb.JPG.5077bc187fe1c716e3a4dfa0bbf858d5.JPGDSC00244.thumb.JPG.5733f4b8c4bf19cc07e25429c695ccc4.JPG
I then started gluing on the upper and lower Cheek Rail, bow brackets and hawse bolsters. After installing the rails I noticed that the tip of the upper rail ends up above the part of the stem where the figurehead sits. I tested attempting to place the figurehead with the cheek rail in place and I could not do it. At least for me I'll remove the upper cheek to place the figurehead once it's painted and ready to be installed.
Rusty
Thank you Glenn and Matt. Much appreciated. Also all the likes too.
Speaking of painting, PE is being painted. I used rattle can primer then gold and black matt
spray paint.
Rusty
