very good looking schooner Russ
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Russ -- That wheel is interesting.  Could you give us a few details on its construction?  What materials did you use?
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Martin:
I freely admit that I could have made a better job of the wheel. Close up, the paint work should be better for sure. However, it is not too bad when you look at it from a distance. :)
The boss and the rim are of boxwood. The rim piece was cut out and the inside section removed. Files were used to clean up the inner and outer surfaces. The spokes are of bamboo. Each spoke extends through the rim and then is cut off to form the handles. The outer and inner rims are of poster board, as are the pieces set onto the rim at each spoke.
Russ
  • 2 months later...
I think everything is coming together nicely!
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
  • 6 months later...
I know it has been a long time, but I am still working on this schooner. I had to take time to do all sorts of other projects including a large scale model restoration last year. In the meantime, I have been getting a few things done on this model, here and there. Here is where I am at right now.
I am painting the bottom of the hull red. This has a several very thin coats and it will need a few more yet.
I have the sails almost ready. I still need to attach the hanks for the forestaysail and the jib. The main and foresails are both ready to go on the masts right now.
In preparation for rigging, I am making some blocks. Here is the double block for the main gaff halyard.
Russ
Thanks. I am glad to be able to get some more work done. I am hoping to get her completed some time soon. We will see.
Russ
Russ,
I was beginning to think you had fallen off the end of the earth.   :)     Your schooner just continues to look great.  Any progress is better than no progress and hope you get some more time to work on her.
Great to see an update Russ.
Michael
Tought you had someting to finish here at MSW. Good to see you back at the 'bench', Russ
Cheers
Carl
Here is the nearly completed red bottom. I see from the stern photo, I need to a little touch up around the sternpost. The camera always finds these thing. :) In any event, it does not look too bad.
Russ
Chuck:
Thanks. I am hoping that the waterline will be okay. Those pics are about as close as you can get to seeing the underside of the model when it is on its cradle. Maybe it will work.
Russ
I feel your pain Russ........I've got a few more years yet.    and when I get there,  they'll probably have raised the bar another couple of years  :(
the bottom paint look great........touch ups are part of the process.  you'll be doing it until you throw up your hands and say  'I'm finished!'  {I've done it on all my builds  ;)  }   it a good color scheme....red and white compliment each other.   good to see your working on her again  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks. I have made a few touch ups this evening and it looks much better. I think it will pass muster. :)
Russ
Good to see you building and blogging again.  Your boat looks great.
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
Ken:
Thanks. I have been building all along, but not on this model. I am glad t be back at this model though. I hope to get it completed this summer.
Russ
