4 hours ago, Hubac's Historian said:
There are quite a number of MSW builders named Mark, who are doing remarkable things, here:  Mark Taylor, Mark (SJ Soane), Mark Tiedens, and I am also a Marc.  The work you are doing here, Mark, is very inspiring.  I personally have ambitions of eventually building a large and complex fully framed model, like this, someday.  Presently, I haven’t yet done anything like that, but it is comforting to realize what can be achieved by jumping right in there.  I really appreciate your willingness to share the learning process - both for its triumphs and frustrations.
You are doing an incredible job!
Hi Marc thanks for the really nice comment mate and I have to say I'm very surprised by the overall reaction to this build.  I just try my best and thats pretty much all I can say.  Please remember that I have pretty much built this ship twice over so far with the amount of things that I have made incorrectly.
I think that the choice of ship for anyone's first POF build is critical - I chose Le Rochefort after much research and also have messaged people like Mark Taylor for advice.  It would be so easy to try and build something bristling with cannon but that would have been far too much for me.
I have in my building arsenal a fantastic book by Adrian Sorolla which is basically a step by step building guide.  I also have Gerard Delacroix on this forum who made the fantastic monograph that I work from - oh and the many fantastic builders on this forum who give me the best advice.  It's not one of those things that you do on your own and making mistakes is just part of the process it would seem. Typing this out has made me think that I really ought to join the NRG if only to put a few coins in their coffers.
I actually managed to get some more frames in today which wasn't planned but you've got to take the time when its available!
I've now raised frames 16 - 23 and they seem to have gone in nice and straight.  There were no real issues it was just a case of repeating what I have already done.
The floor chocks with the limber channel start to rise at frame 20 so there are a lot of bespoke pieces to be made.  The rise starts off very slight and becomes much more pronounced as you move towards the stern.  These chocks also rotate their limber channel 180 degree's at frame 23.  I missed this until it was too late so mine will have to rotate at frame 25.  Some you win and some you loose I guess.
Cheers Mark
Hi Mark,
Le Rochefort is on my list :)
It's really nice looking vessel.
...but what you are showing to us here is pure modellers porn 😜😆
Extremely precise work... just wow!
It's going to be world class model for sure!
I will follow your log and once in a while I'll pinch some of your photos to my "library" if you don't mind of course 🙃
It will be great addition and reference for future build.
Good luck!
Cheers,
Matt
Hi Matt and thanks for the comment mate 👍
I've now finished raising the frames to the stern so thats all 32 frames installed.  All was going well up to frame 28 but when I put the last 4 frames in I could see that they were leaning slightly over to the starboard side.  Once again this was my fault as the aperture that I had cut on the assembly board was incorrect.  So they all came out with some alcohol and I did what Greg suggested and started at the transom and worked my way forward.  This produced a much better result.
I'm glad to say that they all seem to be nicely vertical and square!  I did have to make a couple of small wedges to fit between the last frame and the fashion pieces.  There was a small gap due to my incorrect shaping of the mating faces.  I can live with that though if I'm honest.
Cheers Mark
Hi No Idea, very much enjoyed reviewing your progress to date.  I can't believe that this is your first scratch build, as everyone has said your work is so clean and precise.   I especially appreciate you sharing how you do some of the basic wood working, that often seems to be 'assumed knowledge' and seeing what you've done here definitely has shown that it might just be possible at some point in the future to attempt something like this.  Will be watching closely from here on in as this will surely be a beauty.
Cheers,
Jason
In the shipyard:
Hi druxey and Beef Wellington 🙂
Thanks both for the really nice comments and I'll try and post some more of how I work my problems out.  I have created myself a real problem now;  I should have filled the gap underneath the transom and behind the last frame before I installed frame 32.  I was so focused on getting the frames in correctly this stage completely slipped my mind.  So I now have the unenviable task of shaping this block to the correct shape and then sliding it into place.  I'll give it a go and post my progress.
Cheers Mark
Hi All
Things seem to have gone ok with the making of the solid piece that fits under the transom.
I did the usual of cutting out templates making sure that the grain was correct before roughly shaping the parts and gluing them together.  The angle between the transom and the last frame is slightly under 90 degrees; I don't know how everyone else takes the angles from either the ship or plans but I use a sliding bevel.  I transferred this angle to a face sander and cut the top edge first but I forgot to take a photo of this step.
I then I had to think about how to cut the taper at the rear keeping it square to the face.  In the end I used double sided tape and fixed it to a metal block.  This did the trick nicely and worked out the shape by taking measurements from the plan and scribing it as I went along.
It's made now but I just need to rough shape it a bit first on the outside and also cut the recess on the inside.
Cheers Mark
Looks great from here.
Hi Hubac's Historian, Mark and Greg;  thanks for the comments 👍
I hadn't even made a wooden scarf joint until I started this build as my other two builds were both POB kits.  Before that I had no real experience using wood.
I did a tool room apprenticeship many years ago which was all metal work which I now see has stood me in good stead for model ship building.  Everything back then had to be machined extremely accurately or it went in the bin which would not have pleased the foreman.  This was before CAD or CNC so everything was made manually by hand.  Would you believe that back then titanium was so rare that if we were given a small piece to machine, we had to collect the swarf and hand it in at the end of the working day 🤣
I always thought that was a rumor but after all these years it was true.
I can believe it, yes!  I remember buying my first pair of titanium eyeglass frames, which were wonderful in every way, but EXPENSIVE for the times.  At least I got about six years out of that pair.
I would certainly agree that that experience has been beneficial for you.  Disciplined best practices, taught from the outset, instill a rigorous approach.  My woodworking apprenticeship was administered by a man who insisted I mill material to the nearest thousandth of an inch, as I did the final planing on a KUNDIG sanding machine.  His point was not that those tolerances were critical to the work we were doing, but that paying attention to the process was.
David was forever reminding me to think things through, in order to avoid “negative pre-determinants.”
Edited by Hubac's Historian
I've now roughed out this piece and glued it into place.  It will get its final shape when I fair the outside of the hull.  I'm not entirely happy with it but its my fault for not thinking ahead.  A very small additional triangular piece had to be made for both sides to make the transition from the block to the sternpost smooth.
I did have difficulty recessing the inside of the piece because it was difficult to hold due to its shape.  In hindsight what I should have done was put a couple of screws into it where it wouldn't notice and then clamp onto the screws.  They could have then been simply removed before gluing.  I'll save that one for next time!
I think my build will slow down for a bit now as my next job is to fair the inside of the hull.  I think that this job is going to take quite a long time to get right but I'm looking forward to it.  Once the hull has been faired inside I'll have a go at making the keelson, stemson and sternson.
Cheers Mark
Thanks druxey for the encouragement 👍  I know that my next build is at least a couple of years away so I can get lots of experience and advice in the mean time.
The fairing of the inside is going well; in fact I think its starting to look really beautiful inside.  I've been sanding for hours and I've got quite a few more before its done.  I'll try and get some pictures up tomorrow but wow are my fingers sore from all of the sanding 😂
Hi Everyone
I've now faired the inside of the hull which really does take hours.  My hands and fingers are killing me they are so sore 😂  I wouldn't mind but I was using blocks too!!!  I have learnt not to leave any frame chocks protruding too far into the hull; thats another one for next time too!  I didn't have many places where I needed to remove too much material.  It was more about lining the frames up correctly - please remember though I do have scale on my side as these frames are thick.  How you builders do this at 1/48 scale must make the process so much harder and more precise in the first place.
I have to say its a lovely job to do especially when you get down to some finer papers such as 320 and 400 grit.  You can just feel that things are starting to be right - it's hard to explain.  I've stopped at 400 grit as I'm sure that the interior is going to get a bit bashed around before it needs a final finish.
I'm not sure what you all use for a final finish but I'm thinking wire wool is probably the way to go when I get around to that stage.
The next job is to make the keelson and I will make a start on that tricky piece next weekend.
Mark - BTW I think I should say thanks for all of the likes too its quite humbling to be honest.
Thanks druxey - I've just looked on line and found lots of bronze wool.  I didn't even know that this stuff was available until then!  In the past I've used fine scotch bright pads but I don't think that they will give the fine polished finish that I would like on this boxwood.  I'll order some up and do a few experiments with it.
1 hour ago, druxey said:
Just lovely, If you are planning on wire wool, try to get bronze not steel. Steel will leave tiny particles that will eventually form rust spots.
But cant steel wire wool be removed by a magnet? Or will it leave particles even if a magnet is moved over the surface?
If you're planking, then there's no need to make it mirror smooth because it will be hidden and also glue doesn't seem to work too well on those kind of surfaces.
As for the likes... I like what I'm seeing.  It's very well done.
Yes, Hartron, a magnet will remove most steel wool particles, but some become embedded in the wood surface.
Lovely job of fairing the hull. As you said, you can feel when it's fair and it's a real knuckle buster! And yes, leaving those spacers just a little wide create way too much extra work.
You may wish to rethink the steel/bronze wool finish. I think 240 grit or so looks great. The steel wool creates an almost unnatural polish to the wood but maybe try it on some scrap to see what you think.
Edited by dvm27
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Thanks everyone for the tips - I'm glad to say that my hands are feeling much better this weekend 😀
I can't actually do any making this weekend as I forgot to go the the printers and get my plans reproduced for the keelson.  I'm no good at drawing or tracing so I'll leave any machining to next weekend when I have a good set of copies.  My wife has volunteered to sort this out for me while I'm away at work next week.
I've noticed on a few build logs that people would like to see more posts about how things are done by the builders themselves.  So today I prepared the wood ready for next weekend.  The scantlings tell me that the keelson is 270mm thick and that the stemson and sternson are 243mm thick.  So at a scale of 1/24 I need two pieces of wood the first being 11.25mm thick and the other 10.125mm.  This is a big model and very wood hungry so I needed quite large pieces of wood to start with.  The material I chose was just over 13mm wide so the first thing I needed to do was bring this thickness down on the bandsaw.
I machined one piece down to roughly 11.5mm and the other to 10.5mm.  Can I just say at this point I'm not going to talk about workshop safety at all.  I trust that everyone looks after their own fingers and eyes appropriately.  In all of the pictures the machines are stationary 👍
Next they were run through the thickness sander and I only needed to use fine grit paper as I didn't need to take that much more off.
Then I ran them through the table saw to give myself nice straight edges and also make them square.  If like me you have one piece that has no straight edges, just make up a simple sled using toggle clamps and voila its sorted.
So now I have two pieces of wood at the correct dimensions ready for when I get my plans next weekend.  The time taken was about and hour to do this including the clean up afterwards.
I hope that his has been useful to someone  - Mark
Noidea
Not only is the framing some of the best to be seen here at MSW, ESPECIALLY, for a first project like this, your step by step photos are going to help a lot of people.
Thanks for taking the time to document and share.
Allan
PLEASE take 30 SECONDS and sign up for the epic Nelson/Trafalgar project if you would like to see it made into a TV series.   Click on http://trafalgar.tv   There is no cost other than the 30 seconds of your time.  THANK YOU
Current Build - Charles Galley - Scratch 1:64
Edited by allanyed
Hi Allan thanks mate 👍  I wasn't going to document this build as its my first POF but I'm really glad that I have.  Not only do I get lots of great advice its actually given me something to look back at too.
I've now made a start on the keelson and as per usual I glued the templates to the wood that I had previously made ready.  Next I roughed out their outer shape which didn't take too long.  I've decided to start on the keelson part that goes over both of the master frames.
I milled out the rebates and also cut the scarf joints too.  This is not difficult to do - but I took all of my measurements especially the depth of the cuts from the original plans.  I find that I get better results doing this rather than just milling to the template lines.
The keelson fits - oh boy does it fit in fact I struggled to get it back off of the frames when I needed too.  Now it doesn't fit quite correctly at the moment as there is a gap of about 1mm - 1.5mm between it and the frame chocks.  I've tracked this down to the frame rebates being slightly too high which also has the knock on effect of raising the final position of the stemson.
I don't think that this will be a problem as I just need to sand the high spots lower, but you just know that it's one of those jobs which is going to take ages to get a good fit.  I'm going to get this part right before moving on to anything else.  Adrian Sorolla has this exact same issue in his book and he solves this issue by packing the gaps with slivers of wood.  I may have to do this too but I'll try and reduce it first by sanding.
Mark, I think several people are glad you did: I know I am. 👍
Edited by bruce d
stupid spelling mistakes
STAY SAFE
current builds:
