McLaren M8B - Accurate Miniatures - 1:24 Scale
CDW
Here's what the aftermarket tire sidewall decal looks like in place. As is true with most all aftermarket decal sheets, each and every decal on the sheet must be carefully cut out individually as they are not "die cut" on the sheet. Three more to go.
The kit comes with molded plastic racing harness buckles as well as material for the belts. I made my own belts in the color I wanted and used only the supplied buckles.
IMG_1962.thumb.jpg.f3923737af0a437400529f7f9f6960fd.jpgIMG_1961.thumb.jpg.be9f148e4788e47ad7aa3cb5051f4fa4.jpg
Link to comment
Share on other sites
My kit version is for the 1970 edition McLaren. However, the kit contains parts to backdate this version to the 1969 version which had a high wing rather than the shorter wing struts seen in the previous photos on my last post.
With Imagna's help, I learned my kit instructions showed the installation of parts that interfered with the optional installation of the high wing struts found in the 1969 team McLaren version which I want to model.
Pictured are my kit instructions and then the photos of my kit with the correct long struts installed for the high wing. Note that I needed to make my own bracing rods that run from the roll bar to the long wing struts. My kit did not include bracing rods long enough for the high wing struts, but it's no big deal to make a longer pair of rods from styrene rod stock in the correct diameter.
IMG_1973.thumb.jpg.be824dd29049755cc635e49630f58536.jpgIMG_1974.thumb.jpg.064325d12cd98e53cde37d9b9491d700.jpgIMG_1975.thumb.jpg.302deccf5a4b67e996870b8eb4f55998.jpgIMG_1984.thumb.jpg.997bd8f4789a23e0ac282dc659b267c9.jpgIMG_1985.thumb.jpg.197a83824674c9d5b6709d08cd0d574d.jpgIMG_1986.thumb.jpg.a5dfe0de0b3433ab4834d69c55f65d56.jpg
If you decide to build the high wing 1969 version like I did, leave out part numbers C53, C56, and C57, and attach the longer set of struts directly on top of the rear axle hubs.
Link to comment
Now it looks like the 1969 team car Craig.
It's surprising that they supply the proper struts so you can still build the older car but not the parts or instructions from the original kit so that you can make the choice. Too bad you didn't have some tiny brass tubing and rod laying about. That would have made quick easy work of the retrofit.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Craig, that looks really awesome!  I have to say, I have been a little partial to the orange color as well as the high wing.  Hope you don't mind if I end up going that route on mine as well.
Those blue line tire decals look awesome.  Did you get the 1/24 version?  You mentioned that they looked a little big, but they seem quite nice.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Yes, the decals are 1:24, but the tire sidewall decals are WAY too big. You'll have to cut them to reduce the radius of the circle. A good decal solvent like Solvaset will make them lay down just fine, because after you cut the circle and reduce the radius, it will leave the decal a little "puckered".
No problem at all on the color/version you choose. Do anything you like.
Link to comment
Even if you choose to build one of the 1969 team cars Mike, You can still choose either Bruce's #4 car or the spare car, (Which is also the 1970 car you have after it was sold to Lothar Motschenbacher). The 1970 #11 Motschenbacher car was the 1969 #1 and #3 spare team car. It was driven as #1 by Dan Gurney at Michigan and #3 by Chris Amon at Laguna Seca it was also driven in four other races by Denny Hulme and once by Bruce McLaren.
With some slight body work, you could also build the 1970 M8D team cars and have an entirely different looking car but still on the McLaren orange. Unfortunately this is the same car that Bruce was killed in while testing for the 1970 season.
  image.jpeg.1f0f6ac1f6a492122c47daae58c7048b.jpegimage.jpeg.410e176b3648af5c315aad89eb5bf287.jpeg
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
coming along very nicely since I last looked in :)   again....your paint work is amazing!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Looks like a jungle back there. My backyard trees are all evergreen and the smallest is at least 60 feet tall and the tallest over 120 feet. That little trimmer and ladder would not be of much use!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
There's a row of trees and vegetation that grows along the back fence line between me and my commercial property neighbor. I've got bamboo back there that rivals anything you ever saw in Vietnam. What you see is as high as this climber is going to climb and the wife says I have no business doing that, even.
Women...what do they know? 😄
Link to comment
They know enough to rule the roost with an iron fist!:blink:
I climbed up on roofs and stuff like that as recently as a couple of years ago but I suspect that anything over one story would be possible suicide these days unless I made some special precautions.
Bamboo is the one plant I do not have in my yard. A couple of houses ago the neighbor had Bamboo and it was all I could do to keep it at bay each year! That stuff makes Blackberry easy to deal with. It's too bad it is so hard to handle. I would have loved to plant it between my house and my neighbor to the south. Our dining room windows look directly at his half renovated wreck of a house, or would if I had not planted tall Arborvitae along the property line several years ago. Bamboo would have been perfect and by now would be three stories tall. The Arborvitae is only 15-18 feet right now.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
3 hours ago, CDW said:
It is weird how bamboo sheds it’s bark like a lizard sheds it’s skin.
That is how it grows so quickly.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
looks like an international orange........I have some  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
