coppering Trials...
here for comparing....
the upper Portion of this Trial sample Shows unflattend "nailheads" but I think that appearence would be too much dominating the nails
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
very nice work on the copper tiles.........gouing to give a nice look to your hull.    If I were to vote,  I would pick the semi flattened ones......on the actual ship hull,  they would probably be indented slightly,  so the round of the rivets would not be as prominant.
whatever you choose good sir,  would look good  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Nils
And still you prefer to do it the hard way… But those are very encouraging trials!
Perhaps you could find a way to reduce the diameter of the ‘nail heads’. On the Amati sheets they are about 0,5mm and according to that link to "mini sail Switzerland" they should even be as small as 0,2mm. And I would use the flattened version as the shipbuilders were most probably looking for a smooth skin rather than something like a badly shaved hedgehog. That’s also the reason why I find Caldercraft’s copper sheets less convincing than Amati’s.
Keep up the good work!
Cheers
Peter
Thanks Popeye, thanks Peter
it gives me a better Feeling if in General the sample is not disliked by my fellow builders. I shall try a Little improvement and am meanwhile happy that this copper tape for tiffany glass work is self adhesive, (good sticking !) priceworthy, good suitable for embossing work and easy to handle because it has a protection foil on the backside, that can be left on until the final Moment for attachment Comes. I`ll see what can be done about getting the hedgehog a better shave (smile)
Nils
Current builds
-Lightship Elbe 1
Completed
Trials for coppering now completed,
started with coppering yesterday (pic. lot 18), simultaniously started with the ruddersystem (pic. lot 19), because that shall be fitted when the coppering is finished
Nils
Lot 18
shall probably follow the flattend verion
after 6 Trials made up my mind....
beginning with starboard side
not so accurate, as industrial made plates, but therefore selfmade
the copperline was drawn with a soft pencil
it turned out best results when following the planking pattern...
i am pleased in not using CA glue, that allways messes up the fingertips
Startpreparation bottom Stern on port side
the sternpost is 4,5 mm wide, the rudder will be 4mm (would be 256 mm on actual ship)
view from aft
Current builds
-Lightship Elbe 1
Completed
Pegasus, build log Picture lot 19
Beginning with the rudder System....
started with a Trial sample on the rudderblade hinges, the rudder was made from 4 bars 4,5 x 4,5mm, fitted after coppering the rudder
These hinge parts will be cut off, they go to the hull, after coppering
the ruddershaft goes through all the decks
self explaining
Current builds
-Lightship Elbe 1
Completed
superb job Nils.......the copper plates look just right...;)   the rudder is going to look splendid as well........the ship looks great over all!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Nils
That copper is looking fine :) and you work really fast. That way you will finish your scratch built Pegasus long before I finish my kit. :blink:
Cheers
Peter
Peter,
you may be right, but there are still so many fine Details to be done. Next to the rigging sometime this year I would also intend to make a full suit of sails of which I have no plans yet.
But in the meantime there Needs to be a lot more work on the hull. Regarding to the coppering, which I completed today I shall go for the rudder now (a double nail capline on the copperline is not attached yet) to provide a neat horizontal finish to the coppering. It went so well, doing the "plates" from tape, actually 4-5 in row at a time, I could hardly believe the Speed myself. Also I have a prototype of a brass Investment casting of the figurehead under way, am expecting it curiously next week, if it works out well.
Nils
Current builds
-Lightship Elbe 1
Completed
Nice coppering... even coppered the open side.  Very well done, Nils.
Very clean copper work Nils.
Michael
part 21 of build log
The rudder
Nils
Current builds
-Lightship Elbe 1
Completed
now..........THAT looks georgious!   I love the way the rudder came out.......fantastic workmanship!  the copper seams fit really well ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
A very well done on the rudder....post-76-0-37895100-1376005615.gifpost-76-0-37895100-1376005615.gifpost-76-0-37895100-1376005615.gif
Hi Nils,
I advise that you do the rudder before anything else. You really should have done it long ago, as the hull will need to be turned upside-down to drill several of the bolt holes more easily - it can be done the right way up, but it's a lot more difficult.
:cheers:  Danny
Hi Danny,
just a Little Feedback as to your reminder (thanks again) advice with the time of rudder mounting. Have meantime mounted the rudder but did coppering for Rudder and hull first in order to to do hinge strappings on the copper. Had no Trouble with handling the hull, not even any broken off 0,5mm drill for all those mini holes in the straps.
Nils
Current builds
-Lightship Elbe 1
Completed
  • 2 months later...
Thanks for your birthday greetings Anja,
Nils
Current builds
-Lightship Elbe 1
Completed
  • 5 months later...
Pictures vanished...
To all who missed the the Pictures when dropping in to my HMS Pegasus Build log from part 1 to part 17
I discovered recently that most of the Pictures had disappeared, but they are now all replaced due to a backup I had fortunately made
Nils
Current builds
-Lightship Elbe 1
Completed
B.E.
I hope that soon a Little Progress can be achieved with my HMS Pegasus Swan Class. I am suffering now for for several weeks already from a painfull pinched nerve in neck, shoulder and arm area, and visiting the doctors did not bring help to date. But this gave me time to think about what sequences were to be done next with my build, at least in my mind
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you B.E.
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks for your wishes Dirk,
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Crackers,
thanks for all the "likes" when dropping into and exploring the Pegasus build log. I hope you like the scratch build from Amati plan.
It was because of the lost Pictures in MSW that I replaced them with an update in the last days. Probably you overlooked that Anjas birthday greetings were from Oct. 2013, so it swam up with the replacement announcement today.
Sorry to admit, I have`nt been busy with this build reasonably since then, but hope to reactivate it with more Progress soon
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils,
Doctors? What would they know? (They are OK for SOME things ;) .)
Go to a Remedial Masseur - he/she will have you back at the workbench in a matter of hours :) .
I used to have chronic shoulder pain - years of it. The Masseur fixed me in less than five minutes. I wish I'd seen him years earlier :D .
:cheers:  Danny
Cheers, Danny
Thanks Danny,
after there was no other help, that was my thought as well, I have 6 fixed apointments with such a masseur but no beginn terminated before first April week
Nils
Current builds
-Lightship Elbe 1
Completed
sorry to hear of your problem.....I know how painful it can be.   I used to go to a chiropractor once a year for adjustments.   I haven't been for quite a while now.........I think I wore the kink out.  hope to see you back at the table soon  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye,
yes I have seen the chiropractor already, but he is a bit afraid that it could be a prolapsed intervertebral disc, so nothing was done in that direction. But I am hoping that next weeks appointment with a good masseur shall bring relief.
Nils
Current builds
-Lightship Elbe 1
Completed
