You may find that once the sides of the boxing joint are sanded and horseshoe plates applied, it will look fine.
I hope you are right, druxey!   Paul, yes, I made the clamps--credit goes to Ed Tosti, you can find them on his build log for Naiad.
While most of my work this week has been on Oneida, I have spent some time slowly sanding the bollard timbers to fay to the stem.
They need to match the concave taper of the upper stem--
Still some work needed, but they are getting close.   The overall width is constant now at the head and foot of the assembly--
Once I have them tapered correctly to the stem, I'll start roughly beveling them forward, and at the foot where they meet the lower apron.
Ron
Ron,
This is one of the most difficult jobs, at least it always has been for me.   Another build brought this up yesterday for a different ship, but the solutions varied.  Chisels and sand paper, belt sander and hand sanding, plane and sanding.   Did you hand sand with sanding sticks or ????
I agree that Ed's mini wooden hand screw clamps are a joy to use.
Love your workmanship!!!!
Allan
Thanks, Allan.   The taper of the stem and bollard timbers is being sanded by hand, with that sanding block you can see on the left in the first photo.   I have a sanding drum in my full size drill press down in the basement, but I only use that for roughing the basic curve of the pieces after cutting them out, and I don't trust myself with chisels for this work, so it's slow going.
It's taken me a while to wrap my head around these pieces, trying to visualize what the end shape is, compared to the lines on the paper pattern, and how they need to fit with the stem, lower apron, rabbet and rest of the hawse timbers.
Ron
Hi Ron - can you teach me how to be as careful and precise as you are? As with your Oneida log I really appreciate the explanations and descriptions you provide of your process. I always learn a lot reading through your logs. Very impressive work here
hamilton
  • 3 months later...
Hi there,
Just found this log and since both volumes of Euryalus sits on my shelf I thought it useful to bring a chair and a bowl of popcorn to follow along here.
Looks like you off to a good start Ron. Nice and neat work this far.
Keep it up!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Ron,   I have been following Matiz' build log on Euryalus.  If you have not already been doing so, maybe give it a look see.  His work is spectacular plus some good questions and comments have arisen during his build.
I am looking forward to seeing your progress updates 😀
Allan
  • 2 months later...
By the way Ron, did you get hold of all the plans needed?
In an early post you said you were lacking vol #1 plans.
Happy modelling!
Håkan
Previous builds
Billing Boats Wasa
Gallery:
  • 4 months later...
I have a little bit more work to show.   Final shaping is not done, but I've glued together some of the pieces that make up the bow and stern framing--
The bow assembly-
The sternposts and deadwood assembly--
421488634_Euryalus20220528BSternpostandDeadwood.JPG.a1804a1f799072c8d5f4b8c9a27f60ac.JPG
And the rough cutting out of the bollard timbers and hawse pieces--
582653887_Euryalus20220528CBollardandHawsePieces.JPG.0ef35cf0b05fd83c90a791c71bb9bdb3.JPG
Ron
Thanks Rick.
Continuing with rough shaping of the Bollard and Hawse timbers, they are glued together, and sanded.  After they are close to the right shape, they will be separated and will be filed to form the correct gaps between them.  To the left, the first cant frame "Z (Forward)" is also cut out--616877013_Euryalus20220612ABollardAssembly.JPG.3997f3cfb763c4cd036b3c507167e327.JPG
The second cant frame "Z (After)" is made up of two pieces each, with a chock.  This is my first time building a chocked frame, and the chocks need to be skewed to accommodate the inner and outer bevels of the frame--
1374152531_Euryalus20220612BFirstFrameAssembly.JPG.b094a5686e2b32e497edc867da8940d3.JPG
  The skewed chock is made oversize and glued to the first piece--
Then it is sanded flush on the side without the paper pattern--
991194748_Euryalus20220612DSkewedChockSanded.JPG.998d90cc5f8d4edec567cffd3e3789e5.JPG
Here are the frames with the second piece ready to be glued.  However, I discovered that the upper starboard futtock (the one on the left in the photo) is misshapen.  The paper pattern became distorted when I glued it down.  I had had to lift and reposition it on the wood billet, and during that process it warped.  I will need to make some more paper copies, and cut another one--371219852_Euryalus20220612EZAFrame.JPG.377072f475dbf5753ae9398ebc742c73.JPG
Ron
Edited by rlb
Nice work, Ron. After a few POF models I changed my sequence when assembling frames. I now glue the butt joints of the futtocks together over the pattern, allow to dry then fit the chock by using the assembled frame as a template. A slightly off chock can affect the final shape of the frame so fitting the chock to it's opening insures this doesn't happen.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
That's smart, Greg.  On this frame I'm using the paper copy underneath to make sure my frame keeps the right shape, and finessing the chock cut-out on the second futtock if the chock is slightly off.  I'll experiment with other methods as I go forward.
Ron
Edited by rlb
I realized as I was rough shaping the glued together Bollard and Hawse timbers, that I would need the first one or two cant frames to be installed temporarily in place to check the correct angles, amount of wood to remove, etc.   Going a bit further than the first frames, Zf (forward), and Za (aft), I cut out ALL the forward cant frame pieces--
8957897_Euryalus20220620ACantFramePieces1.JPG.7957787631b52264f463e5a6d748c7f0.JPG1028968078_Euryalus20220620BCantFramePieces2.JPG.ff8e3df55f87c23b7cc801b84a9dc71a.JPG
1823560558_Euryalus20220620CCantFramePieces3.JPG.d9b91f503e52d117ad858e8790800021.JPG
In between other tasks, I'll assemble these.  But to get on with the Bollard and Hawse timbers, I temporarily glued up the first frame Zf.  As I fit the glued together and roughly shaped group of Bollard and Hawse timbers between the stem and this first frame I realized I had removed too much material from the starboard group.   It wasn't going to mate to the first frame satisfactorily.  The port group was more salvageable.  The two groups of timbers were separated, and I would try again, one at a time with the timbers, and the Zf frame--
1897300273_Euryalus20220620DBollardTimbersSeparated.JPG.9ddb59a1dec2a6ab6c61cd3422ffb629.JPG
Having the Zf frame in place, the required shape of the Bollard and Hawse timbers finally clicked in my mind.  The angle to the keel (deadwood to be precise) of the Zf frame (55.24 degrees) is the key to all the Bollard and Hawse timbers, and if you cut (sand) that angle correctly into the "foot" of each Bollard and Hawse timber, the rest of the shaping of them follows.  I started with the Bollard timbers.  When I had the correct "foot", I lightly glued them to the stem, then on to the next Hawse timber, lightly gluing each in place to the previous one, as it fit.  All the "first try" starboard timbers had to be thrown out and recut (indeed, the outer starboard Hawse timber needed multiple tries), but only one of the port timbers.  Here they are in place--
723215519_Euryalus20220620ENewBollardTimbers1.JPG.b9808334eef24d86e7c1e2034488bba3.JPG2142417973_Euryalus20220620FNewBollardTimbers2.JPG.5d9d7796f4e635b022b3d0f87b72ab5e.JPG
They look very ragged and inconsistently sized, but they fit right at the foot, which is what, I think, seems to matter.  We'll see, I wouldn't be surprised if I have redo them again!
The two glued together groups were separated back off of the stem and first frame, and some further rough shaping done--
1985663881_Euryalus20220620GNewBollardTimbersShaped.JPG.6c8db9e3b22e7182e7bd9c5820cca9f1.JPG
At this point they were marked (oh so crudely!) for the locations of the gaps, and will now be separated into individual pieces again to file those gaps into the timbers--
1472262855_Euryalus20220620HBollardTimbersGapMarking.JPG.e1dd6645bf4cef5ac825ba1a39b00359.JPG
Edited by rlb
Unfortunately, I mismeasured the location of the gaps, and didn't realize it until I had filed them into one set of timbers.  On to the third try.  I felt like I wasted precious wood, with the way they are curved, and as they are some of the largest timbers on the ship.  The most disheartening was re-making the Bollard timber, as that has to have a concave taper to match the stem.  It was not fun to make that timber 3 times.  I hope I've got it now, though I won't be 100% sure until I have more of the cant frames mocked up, and I finalize the rabbet.  The rabbet seems to need extra shaping to transition to the foot of the Bollard timber and the bearding line.   We will see.
The rejected timbers are in front, and the temporarily glued together Bollard and Hawse timbers (with their gaps) sitting in place between the first cant frame and the stem--
The masking tape is just holding the group of timbers against the stem.   The timbers still need a lot of fairing, and some adjustments to the length of some of the upper gaps.  The isopropyl alcohol in the background was heavily used over the last couple weeks, as the timbers were glued together for rough shaping, unglued to make the gaps, and glued back together, unglued to make fixes, reglued again, etc.
Ron
Welcome to the bollard scrap pile club Ron! Nobody (except perhaps Druxey) nails them the first time. I cut the air spaces on my Byrnes table saw after the hawse and bollard timbers were "spot-welded" to each other with a few pinpoint dabs of yellow glue. The air spaces were then marked in pencil and the timbers separated. Then the Byrnes saw blade was raised 1/2" (scale) and the recess cut freehand.
Edited by dvm27
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Greg,
Yes, that was humbling.  I think I understand what you did, but I'm not sure.  In any event, though I have a Byrne's saw now, I never would have thought to use it for the air spaces; so much to learn!  I'm sure it was much more precise and uniform than my hand filing.
Ron
Edited by rlb
1 hour ago, rlb said:
Greg,
Ron
As long as you are only removing a section of the surface face it is more accurate than hand filing for sure.
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Producing these timbers involves a large learning curve if you have not done these before, so don'r beat yourself up over them. Every good model-maker has a scrap box for a reason! Keep at it and you will get there.
