Hello dear forum members, I'm new to scratch building and would like to build my first ship in POF style.  Regarding my project: I am building the La Palme 1744 on a scale of 1:36, it is the first Corvette of a 3-series, its sister ships are the L' Anémone (1747) and the L' Amarante (Dec. 1747) whose plans were drawn up by Joseph-  Louis Ollivier, who was only 15 when he began construction.  I use the monograph "L' AMARANTE" by Gérard Delacroix as a template.  Well I hope that I get your support with tips and tricks, as well as constructive criticism.
Greetings Tobias
Member of the:  http://www.arbeitskreis-historischer-schiffbau.de/
On the workbench:
Corvette La Palme (L'Amarante) from 1744 POF based on plans by G.Delacroix
https://modelshipworld.com/topic/32046-la-palme-by-tobias-136-pof/
LE ROCHEFORT - Harbor yacht from 1787 1:36 by Tobias (monograph by G.Delacroix)
https://modelshipworld.com/topic/34810-le-rochefort-1787-by-tobias-136-harbor-yacht-from-ancre-monograph/
Le Coureur - Kit from CAF with the plans from Ancre
https://modelshipworld.com/topic/29843-le-coureur-1776-by-tobias-caf-148/
Greetings Tobias
On the workbench:
A couple more pictures.  Construction of the rear end
Greetings Tobias
On the workbench:
My first 6 frames were unfortunately for the wood stove, I had milled them wrong.  To date, I have completed half of the frames.
Greetings Tobias
On the workbench:
You're off to a great start, Tobias.
Oh Tobias, I hate you so much 🤪
I love the lines of La Palme's big sister - the Frégate de VIII Renommee. I'd love to build her one day, but for now I don't have enough space and some other projects blocking my workbench, that need to be finished.. And now you introduce me to a mini-Renommee! I immediately fell in love and will follow your build log with great interest and - in parallel - look for plans.
The French might have had bad luck with their navy in the 18th century, but their ships looked damn fine!
Hello Strelok, thank you for your interest, yes I thought long and hard about which ship to start with. My selection of monographs is not large, but not small either. La Renommee was my second mono I bought and was shortlisted.
Greetings Tobias
On the workbench:
On 5/13/2022 at 9:11 PM, allanyed said:
Beautiful workmanship!!   I never realized the joints of the keel on French and English ships were completely different with the French being horizontal and the English being vertical.   I wonder why or if one was stronger than the other.
Allan
According to Brian Lavery, the english used their way because it was stronger, the french used their way because the english way leaked more.
Ein kleines aber feines Update, ein kleiner Turm aus Rahmen. 1-34 sind fertig, also sind 2/3 fertig und es müssen nur noch 18 Rahmen gebaut werden.
Ein paar Bilder, wie ich die Rahmen baue. Vom Aufkleben der Papiervorlage bis zum fertigen Rahmen. Als Werkzeuge werden eine Dekupiersäge, ein Tellerschleifer, ein Spindelschleifer und eine kleine Oberfräse verwendet. Zuerst kopiere ich die Pläne und schneide den Rahmen grob aus, dann glätte ich die Papierschnipsel und fixiere sie. Jetzt geht es ans Sägen und dann schleife ich sie. Kleine Fräsarbeiten am Unterholz für den Kiel. Dann wird alles verleimt und jede Hälfte flach geschliffen. Jetzt schleife ich die Hälften auf dem Spindelschleifer vor und kann sie nach dem Entgraten der Kanten wieder verleimen. Dann spanne ich es fest zusammen und nach einer Trocknungszeit kann es wieder mit dem Spindelschleifer geschliffen werden.
Edited by Tobias
Greetings Tobias
On the workbench:
Thank you for your interest and your likes.  Now I have started to grind the frames to size and to fit them in the shipyard.
Greetings Tobias
On the workbench:
Done, all built frames pre-ground and fitted.  Spant 34-50 is still to be built, then the game starts all over again.  I wish you a nice evening.
Greetings Tobias
On the workbench:
Good evening everyone, thank you for your interest and your likes.
The last frames still have to be built and then the scaffolding is in place.
Greetings Tobias
On the workbench:
Greetings Tobias
On the workbench:
Love the "helper" sitting there patiently..  The framing is coming along nicely.
Sunny holiday greetings from Croatia.  The work in the shipyard will probably have to rest for a few days.  The Admiralty and I needed this after 2 years of Corona.
Thanks for your comments and likes, much appreciated.
Greetings Tobias
On the workbench:
We've been back from vacation since Sunday night and I went back to work at Wert on Tuesday evening.
I managed to finish the last 6 frames, a small milestone in a mega project.  in the next few evenings, the bow and the nail picture of the frames are due, as well as the filler pieces and many small things.  I'll keep you posted until then.
Thank you for looking.
Greetings Tobias
On the workbench:
The first frame is drilled and fitted with brass square bolts, the top 3 or 6 bolts are tree nails according to the monograph.  I then burnished the bolts and treated one side with tung oil.
Thank you for stopping by.
Tobias
Greetings Tobias
On the workbench:
Hello Marslav, the blackening of brass or copper is achieved with a special agent (blueing agent) I use Baristol but there are better see attached picture.  I use the tung oil so that the black cannot soak into the wood.
Greetings Tobias
On the workbench:
Outstanding work Sir! Your shop is beautiful. I’m guessing you were a woodworker long before a model ship builder. 😀
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
Hello David, I am a trained car mechanic with a technical degree, so nothing with wood, but I love working with wood.  My entry into the hobby was also only last year in January with the Essex whaler kit and from June last year Le Coureur by CAF.  The Admiralsbau has been on my mind ever since, so I decided to start with La Palme.
Greetings Tobias
On the workbench:
Day 2:
Measure the hole pattern of the frame exactly, mark, drill holes, insert bolts, file off bolts (first use a file, smooth with 240 grit sandpaper and then polish with abrasive wool), blacken bolts and then come the upper tree nails at the end.
Exactly in that order.  Working time per frame about 1 hour.  I've definitely been busy for a very long time.
If we now imagine the following:
You won't see half of it because it disappears under the planks and the other half will probably be cut away if I open the side, i.e. 3 frames then a whole one again, etc. But I know that they are there. Well we'll see.
Thank you all again for all the likes and comments.
Greetings Tobias
On the workbench:
Day 3:
4 more frames are added, I decided to use the square bolts in the upper area as well and not tree nails.  The tree nails are just a relief to make it easier to saw out the gunports later.  In the area of these openings I will drill the holes, but I will not use anything to retrofit them if necessary after opening them.
Greetings Tobias
On the workbench:
