Glen, you always get stage fright at about this point in you SIB builds and they always turn out great. Just relax and breathe through your eyelids. ;)
Current Builds:  1870's Sternwheeler, Lula
Completed: 1880s Floating Steam Donkey Pile Driver
What Keith said, Glen.  Hang in there.
The assembled vessel looks great Glen, very nicely thought through and executed.
cheers
Pat
So true, Keith!  I'm hoping to avoid another horse pucky moment!
Got the braces strung and threaded yesterday.  They are tied to the yard ends then strung thru tiny eye bolts along the sides of the deck, over the bow, and thru the bowsprit.  The brace threads are long and extend thru the neck of the bottle so I can adjust the yards angles after insertion.
Edited by Glen McGuire
Today I worked on the sails.  The pics show the basic process steps.  They are made from muslin and the thread for the bolt ropes and reef bands is fly-tying thread again.
I've still got to make some anchors, add the ship's boats and maybe some misc deck fittings.  Getting very close!  I know the bottom halves of the hull will fit inside the bottle easily.  Not sure about the top with all the sails, yards, and crow's nests.  I have a feeling it's going to be another tight squeeze!
45 minutes ago, Ian_Grant said:
Would fly-tying thread work for ratlines on a 1/150 ship or is it too thin? Asking for a friend. He knows nothing about fly fishing - is it easily tied into compact knots? What kind of glue to lock them?
I think it would work well.  I used regular thread for my 1/120 CSS Alabama ratlines and in hindsight, it looks a little thick.  With the fly-tying thread for these bottle projects, I use 2 thicknesses.  The pic below shows the 2 thicknesses I use next to a piece of regular all-purpose thread.  The black fly-tying thread (72 denier) is the thinnest and I use it for the ratlines.  The camel colored (136 denier) is almost twice as thick (believe it or not) and I use it for the the braces.  I believe the 136D would be good for raltines at 1/150 scale.
I get them from Amazon for about $7 per spool.  As far as knot tying, it is definitely tedious.  It helps to have some very fine point tweezers and super magnifying reading glasses.  But they do tie into very nice knots and once I get going, it actually goes pretty smoothly.  Afterwards, I put a small drop of CA glue on the knot to lock it in then clip the excess strands with cuticle trimmers (highly recommended tool for thread this small).  Very secure knot.
 Glen, the ship is a little beauty. I love the sails, they turned out great and hang well from the yards.
Thank you, Keith!  I went just a shade darker this time and I like it better than my previous efforts.
Looking great Glen! Had you considered using SilkSpan for your sails? It would overcome the “problem” (if you can call it that) of the relatively open weave of your current sails. Regardless, this is an outstanding build.
Hey Grant, I looked into silkspan after the success you had with your Amati Hannah sails.  I was going to order some from Sig but they were out of stock on the light and medium.  I tried a couple of local hobby stores here in Austin and they didn't even know what I was talking about.  I just checked the Sig site again and they are still out.  So if I could find some I would definitely give it a try.
The boat is afloat!  In preparation for trying to put the ship in the bottle, I practiced breathing thru my eyelids as @Keith Black recommended.  I think it helped.
I got the epoxy resin water poured into the bottle.  But it also highlighted another mistake on my part.  My earlier measurement of the inside bottle height was off by 1/8”.  This meant I was not able to put as much “water” inside the bottle as planned.  So the sea is a little shallow, but at least I figured that out before I poured the epoxy and inserted the ship!
The next step was inserting the 2 halves of the lower hull and gluing them together.  Both fit inside rather easily and I had no problem joining them inside the bottle.
The real moment of truth was the next step – smashing down all the masts, yards, and sails and pushing the top half of the mast into the bottle.  I made all 3 the mast hinges with slightly different angles so they would lie down next to each other rather than on top of each other. This proved crucial as there was zero room to spare.  Part of the challenge was the crow’s nests taking up more space than simple mast tops.
After quite a bit of starting/stopping/adjusting/nudging/and gentle persuasion, it finally passed thru the neck and into the bottle.  And the best part was that I heard no pops nor did I feel any snaps!  So I was pretty confident I had not broken anything.
After a huge sigh of relief, I added epoxy to the top of the bottom half of the hull and laid the top half in place.  I let that sit overnight and then raised the masts the next morning.
Everything was intact and the top of the main mast cleared the inside top of the bottle by about 1mm!!  Another huge sigh of relief.   The 3-piece ship idea actually worked!!!
If anyone would like to see the full insertion process for the top half of the ship, I made about a 4-minute video and posted it here: https://www.youtube.com/watch?v=WO8o8WckMl4
Congratulations on getting it bottle and intact along with nothing damaged.   I think most of following along are having a sigh of relief with you.
 Glen, fantastic job! The video wore me out. I kept saying to myself, square peg, round hole, square peg, round hole till she finally popped through. :)
Great work Glen! Loved the video too - must have taken a lot of editing to remove all the swearing and cursing……………
I’m glad it was only 4 minutes long though - I don’t think I could have held my breath much longer!
That is a great analogy, Keith!
I could not believe the video was only 4 minutes long when I looked at it afterwards.  It seriously felt like it took a half hour to get that dang thing inside the bottle!
5 hours ago, Dave_E said:
I just watched your video with 3 grandchildren who wanted to watch how you get a ship in the bottle. 👍😀
That is so cool, Dave!!  Now I'm really glad I edited out all the swearing and cursing like Grant said!  😃
Well, heck.  I thought the drama was over.  But noooooooo, the palm-to-forehead slaps keep piling up on this project!  I got up this morning feeling smug about my work, took an admiring look at the ship resting snug and secure inside the bottle, and began snipping the pull threads below the bowsprit.  And then I realized I had forgotten to attach the ship's boats before putting the whole thing in the bottle.  Yet another dodo moment.  Ugh.  Ugh.  Ugh.
Fortunately, it was not too difficult to put the little devils in place on top of the crutch.  Then I added some texture and whitecaps to the water.
With that, the work inside the bottle is officially complete!  Now it's back to the display to finish things up.  On the homestretch now!!
 Glen, she looks terrific. You know, had the ships' boats been attached before going through the neck things may not have folded up enough to get everything through. It all worked out for the best and it all looks great.
Edited by Keith Black
What a terrific achievement Glen, she looks great in her 'glass' home.  This has been another fascinating build to follow, and you have set your 'benchmark' very high for the follow-on build  :)
cheers
Pat
Super nice.   Kudos and applause.
great job, looks marvilis
That is an excellent point, Keith.  One that I had not considered.  I went back to the video and did a screenshot (see below).  It looks like I had plenty of room for 1 boat on the starboard side but maybe not on the port.  Perhaps it was a blessing in disguise!
Thank you, Pat!  And thanks especially for adding extra pressure to the next project!!
Great job again Glen. I think Keith may have been right. Perhaps you should change your story to, “in a rare moment of brilliance, I decided to add the boats separately”.  😉
I look forward to seeing the final display.
Just caught up with your log and watched your insertion video.  Wow!  You're really getting good at this SIB stuff Glen!  I was getting very nervous watching you scrunch down the masts and sails and push it into the bottle.  Almost like you needed to spray some WD-40 or other lubricant (not going there!) to get it in.  Glad it all worked out!
One thing I realized at the end of your video is that having such an angled bowsprit could have made things much more difficult if the bottle had a longer neck.  Looked like you had just enough room to be able to tilt the hull to get it in.  Something for me to consider if I ever get around to trying to scratch a SIB build.
A question for you if you don't mind.  Did you let the resin water dry and then glue the bottom half of the hull on top?  Or did you put the lower half of the hull in while the resin was drying which served to anchor it?  In my mothballed SIB build, I was trying to figure out what way made the most sense.  I was concerned that it the hull slipped into the wet resin, I'd have resin on the hull in places I didn't want it.  I've seen others insert the hull first, then pour the resin into the bottle letting it settle in around the hull.  That avoids the issue of accidentally dropping the hull into the resin, but seems like it could be tricky pouring the resin and having it settle equally around the hull.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   CLC Annapolis Wherry  Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
LOL!!!
You are absolutely correct, Mike.  The bowsprit on this ship had a much higher angle than my previous builds.  I noticed that right away and had the same concern as you.  I did some early test fitting to see what impact the sharp angle might have on the insertion process and was prepared to lower it if necessary.  Fortunately, I was able to keep the same angle as I had originally planned.  But to your point, had the bottle's neck been any longer I would have been forced to take some artistic license.
You are correct again.  And all the concerns you mention are the reason I've done it that way for the last four builds (along with haunting memories of my Amati Hannah disaster when my ship sank in the soft acrylic paint water).  As I know you are aware, it's difficult trying to place the hull in it's exact position with tweezers or whatever you are using for grasping.  I've found it so much easier (and less stressful) to just drop the ship anywhere inside the bottle, add epoxy to the dry resin, and then move the ship onto the epoxy.
As for pouring the resin once the ship is inside the bottle, I know there are some very skilled people out there that do it that way.  For me, there's just too many things that can go wrong.  And I believe most of those things would be almost impossible to recover from.
Thanks for your all thoughtful comments, Mike.  I always appreciate your insight.
