This will be one very finely lined model Keith; your preparation, as with your work, is simply outstanding.
cheers
Pat
beautiful jobstart on the planking Keith,
I like thr lines of your yacht
nicely done
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Druxey, John, Pat and Nils for your supportive comments and thanks, as ever, to all of you who have left likes or just paid a visit.
And so on with the planking.
I started off by drawing a series of parallel lines on the hull. These act as a guide for judging the symmetry of planking on both sides of the hull.
The previous two builds consumed a whole leaf of my antique mahogany table so I dug out the second leaf from the back of the garage. I calculate that this second leaf plus the centre section will amply suffice for the remainder of my modelling career.
I cut it into 3" inch planks on my full size table saw before moving on to the Byrnes saw to cut it down further to .700" x .220" strips. I chose .220" as the nominal width of the planks because .250" seemed a little wide and .200" seemed a little narrow - very scientific!
I then cut a supply of planks sufficient to get a good start. I decided to make the planks nominally 1/16" thick (thin enough to bend easily while thick enough to give me a reasonable sanding margin). I ripped them over thickness and sanded them to thickness using my improvised drum sander.
My worry about hull sanding allowance made me stay cautiously a little above the 0.625" target plank thickness.
The table isn't wide enough to allow continuous planking runs so each rise takes 2 planks per side.
I am gluing the planks with waterproof PVA glue on both the back side and on the edges. The planks are pinned in place with cork notice board pins. These are "nailed" into pre drilled holes in the frames - quite a laborious task.
The first plank above (or is that below?) the previously installed plywood strake is parallel. I plan to install a number of parallel planks and then start shaping planks as I progress. Using my usual "suck it and see" approach.
I have managed to get the first 2 runs completed on both sides - 8 planks in total.
Obviously I have to give the glue time to dry before removing the pins so this makes the process a 2 planks per side per day job. At least I have plenty of time for tea breaks.
That's all for now folks.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
 It's a supportive wife that allows her husband to ripsaw the dinning room furniture for his ship modeling hobby.:)
 That table has given it's all for some beautiful hulls and is doing so again, good on ya ole table.
Keith.  The legs had woodworm - that is the table not the wife! That said she is looking a bit grubby today.
18 hours ago, wefalck said:
nothing matches that old-time mahagony
Eberhard. The only downside is it tends to be quite brittle when cut into thin strips. Otherwise it is lovely to work with.
4 hours ago, Veszett Roka said:
wouldn't you need to sand down the edges to a little V shape
Veszett. Yes you are correct - I sand a bevel on one edge of each plank to get a tight fit against the adjacent plank.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Our local Solid Waste Disposal Site, aka “The Dump” has a large section where visitors can take away items thrown away by others.  The stuff is free.  They have one entire building full of furniture.   Next time I go there I’ll have to see if I can find any mahogany.  It’s probably all veneer but Duluth does have a large number of old very large homes, once residences to wealthy families, so maybe I’ll strike gold.
Roger
If the antique wood is a little brittle, you may be able to restore pliability as the veneer folk do: a very dilute solution of glycerin in water. Spray the cut strips and let them dry between sheets of plain newsprint under weight for a couple of days. (It may take longer in regions of higher humidity as it takes longer for the water content to evaporate out.)
Edited by druxey
Druxey - thank you for the tip. it only tends to be a problem where the curvature is quite pronounced and I haven't bothered to try and pre bend using heat / steam. That said your suggestion could be very useful for the deckhouses.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
John, Roger, Ian, Veszett and Druxey thank you for commenting.
Just a brief update:-
I got to the 3rd row of planks before the planks began to run out at the stern. This necessitated a wedge being inserted. Just visible between the second and third planks in the next photo.
I did however continue with parallel planks.
In the boiler room area I needed to start aligning the plank edges using stainless steel clothes pegs where alignment proved to be unsatisfactory.
DSC02655.thumb.JPG.29a756bbb1fef5350bb0c903aa94d741.JPGDSC02656.thumb.JPG.06ecaa156520a13e5cb0c5858bfff3f6.JPG
Having included the wedge between the 2nd and 3rd planks the 4th plank went on as a parallel plank without a further wedge.
I am now on layer 7 and probably near the end of parallel planking. At maximum beam I am going to have to start adding more width (which in practice means narrowing the planks at stem and stern).
I am checking the symmetry of the planks (with callipers) on an ongoing basis. The green lines also help me judge the symmetry. As yet everything is looking good.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Love the colour of those planks Keith.  The planks are sitting really nicely.
cheers
Pat
15 hours ago, Mark Pearse said:
And that's a nice hammer.
Yes, and it's older than I am, in better working order and more useful. My father's and maybe even my grandfathers.
You're making it appear easy.
Mark - that may be because I am doing the easy bit first.🙂
John, Ian, Pat, Veszett, Rick. It is still early days for the planking. Plenty of opportunity to make a mess.
Thank you to everyone for the likes.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Nice start on the planking, Keith!  For me, there's always a level of inner tension when planking begins.  Not only does the hull define the vessel, but it's also one of the most scrutinized elements.  I know this will turn out fantastic.
Gary
Completed Scratch Builds
Enjoyed catching up - you are making great progress; a testament to the careful preparation on the frames. Very good to see wood recycled... I made a bed 40 years ago, now retired from service, from wood salvaged from a skip (dumpster)  - I'm still finding use for the wood from it now.
Edited by FlyingFish
Andy
'You're gonna need a bigger boat!'
Completed Build: Orca from the film 'Jaws'.
Current Build: Sailing Trawler Vigilance BM76
Thanks Andy. I make a bed every morning but according to the wife if I practice long enough I will eventually get it right. I know this sounds like a funny story but her comment just happens to be true.
Andy, Tom, Druxey, Gary - thank you all for your supportive comments.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
8 hours ago, TBlack said:
I’d be happy to show you my technique when next I’m in the Old Country!
Tom - thanks for the offer but I fear the pupil is the problem:-
To relay the full conversation.
Wife - if you had someone who despite being instructed many times, still failed to do a task correctly, what would you do?
Me - I think I would impress upon them the reason for the task and the consequences of doing it wrong. Then I would show them how to do it again while emphasising the outcome for themselves if their performance continues to be inadequate.
Wife - Right I will show you how to make the bed one last time!
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
