It does not seem much, but the bridge structure, lots of clean up needed on the supports, wood deck down with a clear coat and masked for later painting. My plan is to pretty much have every structure painted before adding to the hull.  When I did it the first time I paid no where near as much attention so this time it will work better I hope. 2 days work !
Greg
I haven't commented on this build earlier Greg, but i have been lurking and watching this build come together.  You have become a real whiz with PE; some really nice detail you're adding in this (re)build.
cheers
Pat
4 hours ago, RGL said:
Foremast in progress
Greg, what is that tool your using for the mast? It looks like a multi-purpose benchtop vice of some type...
Quote:
She is  coming on a  treat  Greg   -  some  lovely  detail work mate.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
So using my mule, I’m trying to figure how how to do the dazzle pattern. One thing for someone on a computer, another for a mutt like me
 It’s about getting the angles right, so each square seems to be about 10mm which would make sense as it’s a digital render. I need to get some 10mm Tamiya masking tape (it’s the best tape as it doesn’t bleed) and I should be good to go. As I’m on nightshift this week I can’t get to the store unfortunately
Edited by RGL
Greg
Good luck Greg, that will be a difficult pattern to mimic.  Certainly looks effective.
Merry Christmas
Pat
