Shelby Cobra Coupe by DocRob - Model Factory Hiro - 1/12 - multi-media - Le Mans
16 minutes ago, Canute said:
Riveting parts? WOW, I haven't had to do that since I built an old Bowser/English locomotive kit. They did include a riveting tool in the kit for peening over the rivets.  You two are heroes, in my book.
Well no, no riveting tool for the Cobra. There are about 300 to 400 tiny rivets made from cast white metal with the kit. They have different heads and diameters, but the ones, I have to apply in heavy doses now possess a 0,5 mm shaft, which means, there need to be numerous holes drilled with a 0,6 mm diameter. To add to that, most of the holes shouldn´t be drilled through, which makes it a bit more awkward. The tiny buggers will be glued in then with CA glue, not too easy with these little thingies, sometimes hard to pick with pointed tweezers.
Cheers Rob
Current builds:
                             Duchess of Kingston - paused
                             USS Arizona 1/350 Eduard
17 minutes ago, CDW said:
When it comes to something as small as those rivets, have you tried using a pointed dowel with some bees wax to hold the rivet rather than tweezers? My luck with super tiny parts and tweezers is terrible. The parts go flying off where I cannot find them. You have a long, tedious task in your future.
Tweezers can be awkward with these rivets, but I still prefer working with them. I also have a wax pencil, which should be similar to your bees wax method. The difficult part is releasing the tiny rivet from the wax. With tweezers this is guaranteed, one way or the other :D.
Cheers Rob
Current builds:
I dreaded the day, but it had to be done. I speak about final test fitting of the main components, in this case the body to bonnet fit. This is quite delicate, as so many parts and sub assemblies are involved and the process is painful with some loosened parts, etc. and takes hours.
First, I screwed the body to the chassis. All doors and internal parts are only fixed preliminary. Then I mounted the bonnet to it´s hinges on the chassis and got that:
When I force the bonnet down, it will more or less fit, but without locking it somehow, it will open like shown.
I tried to identify the protruding parts and attempted to look, where they interfere, not an easy business, with only two tiny openings to see through on the sides of the bonnet.
As I identified the possible culprits, I dabbed some liquid mask onto them and closed the bonnet and bingo got the interfering locations.
In an iterative process, I removed the material as much as I dared and now the bonnet is paper thin, where the front funnels sit. It closes a bit better now, but not near as perfect as it should. At some point, I have no more possibilities to enhance the fit, as I also thinned the part in front, where the hinges meet the bonnet, to raise the bonnet a tiny bit. I will make a final try and then, I will add two tiny bolts, which force the bonnet into place and can be removed to open the bonnet.
Cheers Rob
Edited by DocRob
Current builds:
2 hours ago, CDW said:
That looks like surgeons work, it’s so delicate. In the end all your tedious work will pay off.
I hope so Craig, there are limits about what I can further do. I may end with a bonnet, which not falls into place by itself, but needs a little push and two tiny rivets for fixing it closed. I could live with that. This is a very critical phase of the build and I don´t want to rush it, but I feel, in the end everything will come together sufficiently.
Cheers Rob
Current builds:
Since I doubt you can remove the motor and lower it, I think your solution is a good one.
This is one of the things that scares me with MFH kits, they are beautifully made yes, meticulous details and assemble much like the real thing... But if they are off in any way in the first sections, it shows up way down the line...
The interference issue seen here would have easily been handled with shaving the engine parts to lower the carb and intake profile just a few portions of a mm... Then it would make it an easier job to shave the bonnet to fit...
I know back seat driver and monday morning quarterbacking... But I have faith that You will get it right my friend...
You skills are far past anything I've seen before...
Quote:
Thank you Mark, I will not alter the fit of the engine, if I can find another way to solve the problem. The chassis engine combo is one unit now and there is no way to separate these without destruction.
Cheers Rob
Current builds:
Thank you Egilman and you are absolutely right. If there is something minor off, it will haunt you later. I had the same with the Crocker, where I had to seriously tweak some sub assemblies to get everything together.
With cars, it´s even more difficult, as tolerances are tight and there are more parts potentially obstructing involved.
One difficulty with these cars is, you can´t foresee all the possible implications, which can arise in earlier stages of the build and you can´t really test fit early on. You have to build as precisely as possible and hope for the best.
Thank you for believing into my trouble shooting skills. I´m sure, I can sort out the problem sufficiently, maybe with a bit of improvisation.
Cheers Rob
Current builds:
One of the MFH kits I wanted to acquire was the Porsche 917. After watching build videos and seeing the numerous fit issues with the doors and other body components, decided to pass on it. Some fairly extensive work is required to make that one come together although the end result can be magnificent. I am sure Rob will overcome this inconvenience with the Cobra very soon.
I read about the issues with the 917 as well Craig. I think, it´s very difficult to produce extremely high detailed kits and then everything has to fit under the hood literally. The resin bodies are thicker than the real thing and everything has to be assembled absolutely error free with tightest tolerances.
I was about to buy the actual re released Alfa Romeo Tipo 33 Stradale, but shied away, because of the swing doors and huge bonnet and rear body.
The only log about an Alfa build was a series of YT-videos, actually a double build. With both, the rear end wasn´t fully closed and that put me off.
I hope F1 cars are a bit more forgiving, as I plan to build some soon from my stash. At least, there are no working doors or bonnets to take into consideration.
Current builds:
Food for thought on the hood closing.   You're right about destroying things to remove the engine.   How thick is hood?  Maybe sanding the inside over the intakes?  Worse case... file/sand down the injector intakes and paint with chrome paint.    Just some thoughts.
Thank you for your thoughts ,Mark, I already sanded and grinded the bonnet paper thin (the last pic of post #65), where it obstructs. The intakes are made from aluminum with an insert of stainless steel tube. I will not reduce the height of these.
It looks worse on the pictures, but with only a tiny bit of force, I can push the bonnet into place and there, I will secure it with two nearly invisible aluminum rivets of 0,5 mm diameter.
Cheers Rob
Current builds:
Poco a poco (little by little, like they say here where I live. I forgot to include the engine firewall into my final? assembly check. Getting everything together with the firewall, is extremely delicate, like a 3D puzzle, but after a lot of shuffling and breaking some pats off, it fits.
Next, I reworked the areas of the bonnet, which connect with the chassis hinges for a better fit. Some modifications of the existing parts were needed.
I also tested, how I could fit my first vac formed window in place with double sided transparent adhesive tape, which didn´t look promising at all. I need some better tape and luckily my wife flies to Berlin next week, where it is easier to get hold of better stuff.
Finally, I found another method to lower the obstructing first cylinder funnels a tiny bit for a better bonnet fit.
I removed the PE seal? under the aluminum funnel with a sharp blade and deepened the holes, which accept the funnels first with a 2 mm drill bit, then the outer diameter with a 3 mm drill bit (left side without PE and drilled out).
As you can see, the front left funnel sits a bit less than a millimeter deeper, than the others. Not a lot, but it sure helps.
I reglued the funnels and the rivets besides and like the result. You have to know, that something is missing to find it.
Cheers Rob
Current builds:
Thank you Craig, I hope the fix will allow a good fit along all the other measures I took.
The Februar kit is not a rumor anymore. It´s published on the MFH site.
https://www.modelfactoryhiro.com/pic-labo/llimg/12_131_000.jpg
Cheers Rob
Edited by DocRob
Current builds:
Cheers Rob
Thanks! Will wait to see what gets offered in March and following months. The Fiat doesn't interest me.
16 hours ago, CDW said:
Thank you for showing, Craig. The tape, I used was the only I could find on my island. It´s thin and transparent, but when applied not transparent enough to let the body color look through undisturbed. I will check the tape you mentioned, but as it´s black, I can only use it for the tailgate, where the frame is black.
It is difficult to find good double sided tapes here, even through the big A. Many articles doesn´t get sent here, but my wife is in Berlin next week and I will use my chance.
Cheers Rob
Current builds:
I'm glad you got the bonnet to fit properly when closed.   Looks like a perfect fix..
Thank you Mark, I hope that solved the fit issues sufficiently, but even with all the test fitting, I can´t tell for sure, if everything is perfect, until the final assembly. With my backup idea of adding two tiny aluminum rivets, I feel save enough now, to continue with other areas, which need to be addressed before I take out the airbrush.
Cheers Rob
Current builds:
51 minutes ago, Javlin said:
She looking good Rob and we see the real job comes in handy here also tools tools tools w/precision .;)
Lots of tools, Kevin. My bench is cluttered with them in the middle of this build. I even think about an in between clean up :D.
Cheers Rob
Current builds:
Today, I prepared all the parts, which will be added to the firewall. Again lots of cleanup work and naturally drilling holes for mounting the parts and adding tubes and hoses later.
Besides, I added tiny magnets to the rear hatch and the doors. The magnets have a diameter of 2 mm and are 1 mm thick. The doors were pre-drilled with a 2 mm drill bit and cautiously finished with a 2 mm milling cutter, to not drill through the door with the drill bits front cone. You can see the magnet shine through in the doors side view, it was close.
The magnets will definitely help, to keep the doors in aligned in good position when closed.
Cheers Rob
Current builds:
Thank you Alan, the Cobra Coupe build is indeed a complex affair, but that shouldn´t put you off, building these type of kits. The Crocker motorcycle, I built, was a thorough enjoyable project and very rewarding. The Cobra or similar full bodied cars with doors and bonnets are not the best choice for beginning with MFH kits.
I learn so many new techniques through the builds, often collected from fellow modelers build logs, that I like to share my experiences as well.
Cheers Rob
Current builds:
Hopefully these are the last preparations before entering the painting stage, but as often, there was one step back, before advancing. I had to remove the already installed internal framework and internal rear view mirror, because they would have interfered with masking the inside of the body later.
I finalized cutting the transparent air scoop vac parts with a pair of fine scissors, sanded them to fit and dry fitted them for drilling holes for the rivets. The first side, I drilled with a 0,6 mm DSPIAE drill bit, which tended to lift up the clear part, when drilling through. I changed to a Tamiya 0,6 mm drill bit for side two and got much better results. No lifting and dramatically less burr, which is a pain to remove with these clear vac parts.
When you compare the drill bits, the Tamiya is of the classic HSS style and angles, where the DSPIAE bit is like all the other PCB board drill bits and not good for drilling thin materials, as it "eats" into the material and leaves a lot of burr.
Cheers Rob
Current builds:
The painting stage has finally begun :D. I cleaned all the resin body parts in warm soapy water with a large brush and sponge first and then primed everything with Mr. Surfacer 1500 grey.
After drying, I sprayed the white sections with Tamiya´s XF white (bonnet inside and firewall and small parts of the main body)
These areas got masked then. Finally, I sprayed two jars of Tamiya´s excellent LP-5 semi gloss black onto the inside of the wheel wells...
... and the inside and window framing of the body.
Some interior parts got also sprayed during that session. Next will be an intense masking session for the interior and a lot of praying, there are no paint lifts after.
Cheers Rob
Edited by DocRob
Current builds:
